Old Oct 27, 2011, 08:46 PM
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
Build Log
F89 mkI Scorpian
I started the build of Wm. Brown's rendition of my F89 Scorpian.
Using my cut files for the fuse formers, Wm generated a great set of drawings plus a short kit of beautifully laser cut parts. The cutting was done by Manzano Laser. I received the kit about a month ago but home work took precedence.
I always start with the wings as that is the part I dislike building the most, especially the shaping of the leading edge. Now that I am this far I will put them aside until I decide what to do about retracts. I've been looking at the E-Flite electric retracts (.15-.25 size) and they look real slick. Does anybody have any comments about them?
My existing F89 weighs in at 78 oz and I guessing the new F89 will be about 90 oz with the retracts and scale tip tanks if I stay with 4S batteries.
I will be using twin 70mm fans and HET motors and I thinking I'll go to either 5S or 6S batts to get the weight down. I would like to use Wemo MF480's but they seem to be scarce so I'm open to suggestions.
The new wing has a span of 50.5 inches, just a hair bigger than my original. At 90 oz., the new F89 will have a wing loading of 30 oz/sq.ft. The existing F89 has a wing loading of 26 oz/sq.ft. The 30 oz/sq.ft. wing load scares me which is why I will go to either 5 or 6S.
Here's a pic showing the new wing and the original
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Oct 27, 2011, 09:57 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
use HET 6904's they will pull a few more amps ,but make more watts ...and sound better. if you really want it to sound nice use the Efflux R/C all alloy fans ,there is vid of it in my Draken thread.
AIR SALLY is online now Find More Posts by AIR SALLY
Old Oct 27, 2011, 10:53 PM
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
retracts
I have had good luck with these retracts.
Bob
bruff is online now Find More Posts by bruff
Old Oct 28, 2011, 08:23 AM
Joined Sep 2000
Guys,
Thanks for the info.
BRUFF,
Is there a separate nose retract? At the price shown, they are certainly worth a try.
Old Oct 28, 2011, 11:04 AM
EDF Jet Jam 2015 , May 28-31
Kevin Cox's Avatar
St. Louis Intl, Missouri, United States
Joined Jan 1997
Looks great Larry and William!
Kevin Cox is offline Find More Posts by Kevin Cox
Old Oct 30, 2011, 10:40 AM
Wichita, KS
Joined Apr 2003
Larry
Glad you have started, I will have to hump to keep up. I am working the tooling for the vac formed inlets right now. Have not started building mine yet, but the work table is ready
Wm
William E Brown is offline Find More Posts by William E Brown
Old Oct 30, 2011, 11:26 AM
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Originally Posted by Larry Dudeck View Post
Guys,
BRUFF,
I was modifying one for nose gear but found this http://www.nitroplanes.com/60p-t28-frontretract.html . Bought one so far it works fine.
Bob
Old Oct 30, 2011, 07:52 PM
Joined Sep 2000
Bob,
Can I just use a "Y" or perhaps a "W" wiring harness to connect the three servos? Then do I just plug the whole thing into the retract channel?
Never had retracts so I'm in new territory.
Do the mains come with struts or is that something I have to provide?
Thanks for your help.
Old Oct 30, 2011, 09:02 PM
EDF all the way!
bruff's Avatar
Gilbert, Az
Joined Jun 1999
Yes, just wire them all to one channel. Horizon sell a three to one servo extension for their retracts.
Bob
Old Nov 08, 2011, 07:56 PM
Joined Sep 2000
Bob,
Some progress on the F89...
I decided to finish building the wing and tip tanks, small models in of themselves. The tanks are ~ 20" long by 2.6" in diameter or scale 20 ft x 32". They are removable, they will be held on either with magnets or velcro, to help both in transportation as well as some of the dicey landings I've been known to make.
Sheeting is 1/32nd balsa
Still need to buy a set of retracts.
Old Nov 11, 2011, 01:37 PM
Joined Sep 2000
Started on the left half of the fuse, working from the front to the back. Mounted the WM400/HET3W.
Laser cutting is very nice, even on the plywood parts
Old Nov 11, 2011, 02:38 PM
Kevin Cox's Avatar
Joined Jan 1997
Nice work Larry.
Old Nov 12, 2011, 12:32 AM
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Nice Larry! I may have to give one of these a try.
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Nov 12, 2011, 06:46 AM
Da' Cajun
Boogie_'s Avatar
Lake Charles, Louisiana
Joined Jun 2009
Good stuff Larry!!
Watchin' this one close.
Julian
Boogie_ is online now Find More Posts by Boogie_
Old Nov 12, 2011, 10:23 AM
Joined Sep 2000
Gents,
Thanks for the comments.
This is a builder's kit so I wouldn't recommend it to someone who has never tackled a project like this before but you guys would enjoy this one.
This morning I'm installing the ducting then add the last of the formers, then the stringers. Once that is done I can take this side off the board and go over all of the glue joints. For plywood to plywood I'm using "super-phatic", graciously supplied by Wm. Brown
Question F89 Scorpian Larry Dudeck Electric Ducted Fan Jet Talk 124 Dec 20, 2014 10:34 AM
Wanted H9 PTS Mustang mkI wings RedStarArmy Aircraft - Fuel - Airplanes (FS/W) 0 May 18, 2011 05:55 PM
Discussion Kiel Kraft Scorpian goes electric Snorks Vintage & Old-Timer Designs 19 Sep 17, 2007 04:43 PM
Discussion Kiel Kraft Scorpian Snorks Vintage & Old-Timer Designs 0 Aug 01, 2007 01:09 PM
Discussion Is the Scorpian the Answer? Snorks Vintage & Old-Timer Designs 3 Oct 07, 2006 11:20 PM
