Old Feb 10, 2015, 03:02 PM
Italy, Piedmont, Asti
Joined Aug 2014
Originally Posted by xandrios View Post
Dell Poweredge 6650 (ASTN 7000245) PSU voltage control OVP mod to 16.5V.
Stock OVP(over voltage protection) for the 6650 PSU is around 13.3V.
This simple mod will raise the OVP to 16.5V.
Remove the 5 screws as indicated to remove the back panel.
Locate the leftmost connector on the daughterboard.
Add a 1k resistor in series with the Grey wire.
Voltage will now be adjustable from 3.3V-16.5V(OVP).
There is no UVP on this unit so voltage can be adjusted down to 3.3V at the full 72 amps of current.
I suggest staying below 15.6V as the output capacitors are rated at 16V.
Tested at 15.5v and 72A.
A higher value resistor can raise OVP to above 20V.
The output caps will need to be replaced if voltage goes above 16V !!
Two of these PSUs(at 15.5V) in series(31V) should max out any charger available and will max out most 120V outlets at full power !!
http://www.revolectrix.com/Calculators_main.htm
Do this mod at your own risk !!
Hi
I bought two of these PSU on purpose in order to change the Vout but I have not understood how.
I connected a 1K resistor as shown in the post but then, to be able to change the Vout, what should I do?
mgaproduction is offline Find More Posts by mgaproduction
Old Feb 11, 2015, 10:05 AM
United States, NY, Syracuse
Joined Dec 2011
H p dps1200
Looking for thoughts as to why I am seeing this variation from 2 different digital multimeters.
PS 1 modified floated - Meter A reads this PS at 12.23v Meter B reads at 10.8v
PS 2 no mod - Meter A reads this PS at 12.25v and Meter B reads at 12.4v
Similarly when the jumper is added for series and 24v, Meter A reads 24.49v and Meter B reads 23.8v.
If I check voltages on batteries both meters read similar voltages, both in the 12v and 24v ranges.
Only when checking the floated PS does Meter B read 1.4v lower than Meter A.
Also, when I plug in 2 different chargers, they show voltage in at 12.33v and 12.38v from the floated PS.
Again, only the one meter and only on the floated PS shows a lower voltage. Can anyone explain this? Thanks in advance.
rags963 is offline Find More Posts by rags963
Old Feb 11, 2015, 06:00 PM
Joined Feb 2015
Puh, huge thread here.
Actually i found this thread cause i'm trying to start/modify and use a DL580 G3 1300W PSU
to power my 12V audio system. Bought this 2 days ago from ebay for 24€ includes shipping.
At the moment i'm reading and reading but the pages will not end. Okay, have to buy a C19 connector but that should not be the problem, also the start connection to PS_ON and PSKILL should work.
Only thing i didn't read so far is if OVP could be disabled.
So i may ask the question to xandrios or any other who knows this. Did you do the job to deactivate the OVP and drive the Voltage to 14.2 V ?
There was a post (#751) from hawkeyefile who wanted to trick the ATM Controller but after this the idea was never seen...
So, if you know a solution to drive the psu to 14+ V it would be great to let me know.
Otherwise maybe an idea that can help me?
Regards
Daimonion
daimonion1980 is offline Find More Posts by daimonion1980
Old Feb 11, 2015, 06:38 PM
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
xandrios is long gone from this thread.
I do not recall a specific step-by-step on raising the voltage on these particular supplies.
He did get it to 13.2V but did not ever manage to get the OVP disabled as far as I know.
Useful posts are:
495
524
539
579 xandrios states it can be done
599 he gives general instructions
612
613
633 xandrios says he got it to 13.2V but could not disable OVP
John
Otherwise maybe a idea can help me.
Regards
Daimonion
jj604 is offline Find More Posts by jj604
Old Feb 11, 2015, 06:41 PM
Joined Feb 2015
Ah okay, thought he is still here. At the moment i'm at post #1516.
So nothing new information will come? I can stop reading. Puh
Old Feb 11, 2015, 09:32 PM
ueber30's Avatar
Deutschland, HE, Großalmerode
Joined Jul 2011
Hello.
I use 2 Poweredge 2800 to feed my PL8.
With no load they have 23.98v. When i push 700w or more the voltage drops to 23.5v.
I read many posts but i cant find something for the poweredge2800 to push the voltage...
Is there a way to set the voltage higher?
If someone intrested... The 2 dells have only 58.9
db. In 1m range.
Regards Uwe
ueber30 is offline Find More Posts by ueber30
Old Feb 12, 2015, 07:20 AM
West Virginia
Joined Apr 2010
Uwe,
I'm very new to this but I have a 2850 that may or may not be similar to your model.
Here is the pinout's for that model. http://www.rcgroups.com/forums/showp...&postcount=513
I have a 2850 and connecting the current share A2 with positive gives a slight bump in voltage. I'm not sure if yours is the exactly the same so do so at your own risk. http://www.rcgroups.com/forums/showt...B#post27667927
If that doesn't work maybe one of the internal pots is like the 2850. https://sites.google.com/site/tjingu...ects/server-ps
Dialed_In is offline Find More Posts by Dialed_In
Old Feb 12, 2015, 12:29 PM
ueber30's Avatar
Joined Jul 2011
Hello...
my own risk but it works
I set a Jumper from A2 to Positiv Pole and the voltage jumps from 11.98 to 13.17v.
is this OK or a Problem with the OVP.
Best Regards Uwe
Old Feb 13, 2015, 12:13 PM
West Virginia
Joined Apr 2010
I'm glad it worked .
Sorry I can't help with the OVP question. My voltage only jumped up to 12.57V.
Old Feb 15, 2015, 03:36 AM
Joined Jan 2015
Hello, I've been using your guid to convert this dell JD200. Well, whenever I tried to solder the 100k resistor into the daughterboard for the ovp mod I messed up and just wound up removing the entire daughter board from the unit by desoldering it. What should I do? Is there a work around? I'm using this unit to power a bitcoin miner, which take the 6 pin PciE cables like you see on the graphics cards and stuff, and I'm trying to get max Amy of WATTS out of this thing. Any help is greatly appreciated Thx : )
Jsep87 is offline Find More Posts by Jsep87
Old Feb 15, 2015, 05:14 PM
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
If you can't resolder it to the motherboard then I guess it is time to buy another power supply.
I must add...I just don't understand why people think it is so important to up the voltage on these. Me? I leave them as designed as I feel little 'ol me is not qualified enough to redesign these things.
Rick
rampman is online now Find More Posts by rampman
Old Feb 17, 2015, 04:55 PM
Joined Dec 2011
any suggestions to add a filter capacitor to a dps-1200fba ? type and voltage needed?
willc.
shalom72c is offline Find More Posts by shalom72c
Old Feb 17, 2015, 08:27 PM
Joined Sep 2014
if you cant resoilder you have to buy another....i killed mine by removing turn on sense pin. sucks.....what do you need to have voltage above 14.3 for?
150 db is offline Find More Posts by 150 db
Old Feb 23, 2015, 10:06 AM
Joined Sep 2014
besides the JD200 an KD175 what are some other supplys i can get 14+v out of thhem? neeed high amperage.....i dont like how the dell poweredge 1850s are.
any help is help....thanks!
Old Mar 01, 2015, 07:51 PM
Joined Sep 2014
I just got ones of these also...you have to look at the last pic on that post. It says 2 pins....I only have. 1k pot an only gives me 13.68-14.3v stable. After that it climbs uneven crazy an jumps butt does go to 16v. I need help with the suppy also. I need 12.0-15v
Originally Posted by mgaproduction View Post
Hi
Alert Need advice on high grade power supply for ISL-8 Byron Betterly Batteries and Chargers 7 Dec 07, 2003 09:31 PM
12volt, 9amp power supply for sale Paul Susbauer Aircraft - Electric - Airplanes (FS/W) 1 Dec 03, 2003 01:44 PM
12volt wallwart power supply reading 14.6 ? (help) power Batteries and Chargers 4 Sep 09, 2003 05:21 PM
Where to Get A Quality Power Supply? Joe Elston Batteries and Chargers 4 Apr 29, 2003 03:09 PM
High end charger and power supply for sale! Very new. ted616 Aircraft - Electric - Airplanes (FS/W) 6 Dec 03, 2002 12:31 AM
