Old Mar 15, 2013, 11:28 AM
bluffman's Avatar
Joined Sep 2003
Build Log
Fuse connectors
I have a fosa with the six pin connector glued into the fuse, is there anyway to find out what the hot and signal connections are, without taking the connection out of the fuse. Ian
bluffman is offline Find More Posts by bluffman
Old Mar 15, 2013, 11:31 AM
Eggcellent...
tewatson's Avatar
United States, CA, Orange
Joined Oct 2006
Unplug the RX connectors and ring them out with an ohmmeter or continuity tester.
Tom
tewatson is offline Find More Posts by tewatson
Old Mar 15, 2013, 12:30 PM
Win=span\massXpractice+lu ck
webbsolution's Avatar
Joined Jul 2007
When I am testing those connectors on other pilots fuses I make a female MPX connector complete with all 4 signal wires + servo female connectors and plug in servos - then note on a piece of paper which one of the 4 on the fuse is an active signal pole - takes longer to make the plug than to determine the signal though
TWatsons approach is faster but I like to wiggle and basically ensure my signal to the servo is good etc so I keep a spare test plug in my kit.
I use it on my wings as well for my Xplorers since I use an MPX connector there as well but in the last 4 years I have never had a connection fail on me.
webbsolution is offline Find More Posts by webbsolution
Old Mar 15, 2013, 12:35 PM
F3B
satinet's Avatar
Warwickshire, England
Joined Sep 2006
Tom
yep, just use a multimeter and stick one probe on/in a pin of the green connector and one probe in/on a servo pin until you get no resistance shown.
satinet is online now Find More Posts by satinet
Old Mar 15, 2013, 01:14 PM
bluffman's Avatar
Joined Sep 2003
Cool thanks guys I will do that tonight, then make a wire diagram
Old Mar 17, 2013, 08:31 PM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Here's a tip:
When you do what is suggested above, if you have the mating connector unsoldered, plug that into the fuse plug.
Its easier to hit the right pin that way on the MPX connector, and you get the "real" map of what you need to solder up to, not a mirror image.
Don't be tempted to check the pins with the plane powered up.
Unplug the leads from the Rx and do it that way.
Its the safest!
R,
Target
target is offline Find More Posts by target
Old Mar 17, 2013, 09:26 PM
bluffman's Avatar
Joined Sep 2003
Thanks target, I have removed one side out of the fuse to check the connections,
Old Mar 18, 2013, 07:56 AM
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
That is another way to do it as well.
R,
Target
Old Mar 18, 2013, 02:38 PM
F3B
satinet's Avatar
Joined Sep 2006
Assuming both sides are the same
Old Mar 18, 2013, 04:15 PM
bluffman's Avatar
Joined Sep 2003
Yeah I will remove the other side also just in case they went connected the same
Deans 2 & 3 pin connectors and Multiplex Connectors SOLD Mikemynameis Non R/C Items (FS/W) 1 Jan 02, 2013 02:21 PM
Wanted Wing to fuse wiring connectors BrianSmith Aircraft - Sailplanes (FS/W) 4 May 02, 2009 08:50 AM
Discussion How to align wing and fuse connectors? moreil Hand Launch 1 Jan 14, 2006 04:20 PM
wing-fuse connectors avie Electric Plane Talk 2 Apr 24, 2004 07:32 PM
SS fuse connector thingy mod Puget Sound Flyer Parkflyers 1 Apr 12, 2004 11:58 PM
