Old Jan 05, 2013, 11:19 AM
Canada, ON, Toronto
Joined Jan 2013
OcCre Mississippi R/C Steam Conversion
Hello,
I'm new here. I just built a Midwest Launch and built the steam engine and I'm hooked on live steam R/C!
I now have a few projects in the queue...
One of which is the OcCre steamboat, which I bought for a steal on the Model Expo site.
I will be using one Graham horizontal engine and a separate engine to power a generator to light it up (if there's room in the hull).
Has anyone converted this kit to R/C and live steam?
SteamSurge is offline Find More Posts by SteamSurge
Old Jan 05, 2013, 03:50 PM
Just call me "Mo"
mogogear's Avatar
NE PDX OR
Joined Aug 2008
Welcome and congratulations!! Graham horizontal? I am sure you could configure it to lay down - maybe you mean their slide valve vertical?
Sounds like you will be busy in the shop--have fun ! Dual engines is adventurous!
Sorry- I am unfamiliar with the paddle boat you are mentioning
mogogear is offline Find More Posts by mogogear
Old Jan 05, 2013, 07:54 PM
Shanghai'd Expat
herrmill's Avatar
Xiaoshan, China
Joined Jun 2006
If thats the 1:80 scale display model shown below you'll be best served by leaving it on the shelf as a static build. Its far too top heavy with too shallow a hull to convert to RC.
http://www.modelexpo-online.com/prod...ITEMNO=OC14003
If I were you, I'd forgo the frustration & consider going with a kit designed for RC like Dumas Creole Queen. You may need to alter the hull & deepen it to carry the added displacement of a steam plant. Here are some references to look over towards your next project.
Dumas Creole Queen
http://www.rcgroups.com/forums/showthread.php?t=1455915
http://www.rcgroups.com/forums/showthread.php?t=913031
Scratch Sternwheeler
http://www.rcgroups.com/forums/showthread.php?t=1445625
Good Reference Site:
http://www.paddleducks.co.uk
herrmill is offline Find More Posts by herrmill
Old Jan 06, 2013, 07:23 AM
Damp and Dizzy member
Brooks's Avatar
Bozeman, Montana, United States
Joined Aug 2003
Perhaps if you made a new, deeper hull you'd achieve the displacement you need. Boilers are heavy. You will need to calculate the weight of the superstructure, motor, boiler, burner, gas tank, etc.. If you convert the weight to grams, you will know how much displacement you need, using conversion of 1 gram = 1 cc of water. Then, length x width x depth of the hull will give you the cc's of displacement. To increase displacement, increase the depth.
eg.: A 24"x6"x2" hull would support about 4.5kg. A Maccsteam 3.5" boiler+burner+water weights about 2kg.
These boats were top heavy in real life. They were sensitive to cross winds, and models are likely to be sensitive also. There have been many successful river steamer models, though. Search for John Fryant's work on the web, he's a master.
My guess is that you'd need a much bigger boat (4 foot hull?) to support the steam stuff and a steam generator. With a ~ 2' hull, you will be limited in the weight you can carry.
You might get some ideas from my A.J.Goddard thread, a simpler sternwheeler than a Mississippi river steamboat.
http://www.rcgroups.com/forums/showthread.php?t=1153159
Brooks is offline Find More Posts by Brooks
Old Jan 06, 2013, 11:33 AM
Canada, ON, Toronto
Joined Jan 2013
Thank you for your comments!
I'll try to modify the hull of the OcCre model because I prefer the exposed horizontal engine. I will use the Graham HM1. After further thought, will stick with one engine, as it would be overkill power-wise and heavier to have 2 engines.
Will keep everyone posted. The kit won't arrive for another month or so it seems...
Old Jan 06, 2013, 11:51 AM
Canada, ON, Toronto
Joined Jan 2013
So if a 24"x6"x2" hull would support about 4.5kg. A Maccsteam 3.5" boiler+burner+water weights about 2kg.
It just may work without deepening the hull. The engine weighs 3.75 ounces. The R/C equipment is negligible...you can use plastic tubing for steam instead of copper, with clamps on each end.
Old Jan 13, 2013, 05:53 PM
Shanghai'd Expat
herrmill's Avatar
Xiaoshan, China
Joined Jun 2006
I see you are now considering the Creole Queen. Another option I failed to mention that will involve a lot of scratch building would be the Hartman Delta Queen. Its larger than the Dumas kit but only comes as a hull.
http://www.hartmanmodelboats.com
Here are photos of one that I had the chance to buy a few years back & wish that I had.
Old Jan 14, 2013, 02:06 AM
I SEE NO SHIPS
dunc2504's Avatar
Somerset England
Joined Feb 2007
Plastic tube for steam instead of copper ?
I don't think that is a good idea !
Some people use silicone fuel hose on the exhaust side , but I wouldn't like steam lines at 50+psi blowing off and venting hot steam all over the place.
Dunc2504
dunc2504 is offline Find More Posts by dunc2504
Old Jan 14, 2013, 07:27 PM
Brooks's Avatar
Joined Aug 2003
I've used silicon model airplane fuel hose for steam lines on my boats and on a coal-fired G-gauge loco. They worked fine for me. They can blow off, as Dunc said. The experience is not particularly dangerous since the steam stream cools so quickly: I once had a water sight glass give way on a model loco with my hand in the cab; no injury whatsoever. I was lucky regarding the glass, but the stream of steam caused no burns. The biggest risk is the surprize....you will likely jerk back your hand, and you may hit something.
Another risk is if the stream shoots water droplets into your eyes...but that exists for all steam operations, and you should always wear eye protection when steaming. I've gotten a squirt of steam and water in the face while bending over a loco during steamup when the safety let go unexpectedly. Wear eye protection.
If lines are blowing off, you can increase friction-grip by tying a constrictor knot around the silicon. Cotton-wrapped polyester carpet thread works great; available at any sewing shop.
Old Jan 14, 2013, 08:42 PM
Canada, ON, Toronto
Joined Jan 2013
You can also use clips at each end of the silicone fuel line, such as Dubro LXD751 at Tower Hobbies. I read about these here: http://www.panyo.com/project/index.htm
Old Jan 14, 2013, 08:43 PM
Canada, ON, Toronto
Joined Jan 2013
Thanks for letting me know. The Hartman is beautiful. Also thinking about the MS Chaperon... I don't love the look of the Dumas Creole Queen, and from what I've been reading, the quality is not as good as kits for OcCre or MS.
Old Jan 26, 2013, 11:16 PM
United States, OH, Maineville
Joined Oct 2008
Dumas Creole Queen
That Model Expo sternwheeler is a terrible looking creation designed by some European who doesn't know s - - - about riverboats. Get rid of it - or build it as a display model. A live steam riverboat will have to be larger. A Creole Queen model would work with a deepened hull - but the CQ isn't steam powered - she's a diesel-electric.
John Fryant is offline Find More Posts by John Fryant
Old Jan 27, 2013, 12:34 AM
hookpilot's Avatar
1/32nd Scale US Army Corps of Engineer Snagboat
Here's another scratch-built stern wheel build : After two years designing and building a 63" long, steam powered sternwheeler, the W.T. Preston, sea trials are soon to begin. The complete build log can be seen on Scale Ships 1/32nd Scale Model of W.T. Preston.
Snagboat Mike
hookpilot is offline Find More Posts by hookpilot
Old Jan 27, 2013, 09:46 AM
Canada, ON, Toronto
Joined Jan 2013
Wow, simply incredible, HookPilot!
I have returned the OcCre and the Model Shipways models.
Now working on a somewhat crazy side-wheeler, a version of this full-scale boat:
SIDEWHEELER24JUNE2011A.wmv (1 min 44 sec)
Old Jan 27, 2013, 03:18 PM
steamboatmodel's Avatar
Toronto, Canada
Joined Nov 2004
http://www.youtube.com/watch?v=QJAY6mkxTIg
Let us know what you find out about the engine and its valve gear?
Regards,
Gerald.
steamboatmodel is offline Find More Posts by steamboatmodel
For Sale Radio Shack Ricky Carmichael r/c motorcycle r/c bike stompjrkz400 Cars - Motorcycles (FS/W) 1 Dec 22, 2012 12:08 PM
New Product New R/C marine steam engine from PM misfitsailor Scale Boats 60 Feb 24, 2009 12:38 PM
Idea Historic R/C Steam Launch Lancer31 Scale Boats 29 Sep 21, 2007 06:42 PM
