Old Aug 01, 2011, 09:04 AM
Gloucester Ma
Joined Dec 2002
Signal wire needed on CC BEC ?
I have run out of channels in my CCPM 450 clone and would like to use a Castle BEC. The Gyro gain plug has only a signal wire so I am wondering if I can pull the red and black pins from the castle plug and put them into this one. Is there any reason the signal wire needs to go to the receiver? I will make an adapter to use if I ever need to use the PC. I prefer using an adapter only while not flying rather than a Y connector in-flight.
A Monell is offline Find More Posts by A Monell
Old Aug 01, 2011, 11:15 PM
Lee Estingoy
Overland Park, Kansas, United States
Joined May 2003
The signal wire is not required for in flight use on the CC BEC. It is there for Castle Link purposes only.
Your solution sounds very neat and tidy, but most would just put a small Y adapter in there....
Lee
lestingoy is offline Find More Posts by lestingoy
Discussion Connection Advice on CC BEC natss Batteries and Chargers 1 Jul 20, 2011 02:40 PM
Discussion Which wires on ESC going to motor are positive/negative and signal wire? cannondale1974 Power Systems 11 May 15, 2011 10:57 AM
Wanted CC BEC Pro or CC BEC needed lmopar69 Aircraft - Electric - Power Systems (FS/W) 1 Mar 20, 2011 02:10 AM
Discussion Is the built in 5A BEC on CC ICE 100 as powerful as the CC BEC on 6s? cleansho93 Electric Ducted Fan Jet Talk 12 Mar 15, 2011 04:53 PM
Discussion Is the built in 5A BEC on CC ICE 100 as powerful as the CC BEC on 6s? cleansho93 Foamy EDFs 0 Mar 15, 2011 01:29 AM
