Old Jul 31, 2013, 09:41 AM
United States, OH, Columbus
Joined Jun 2006
Parkzone BF109 rolled uncontrollably and burned in
I recently purchased a used Parkzone BF 109 on here and i went to fly it for the first time the other day. I hand launched it without at 3/4 throttle like I do all my other PZ warbirds and it begain to roll Uncontrollably to a height of about 50 to 75 feet kept rotating out of control and went in nose first about 75 yards away. It felt like I had no control. The CG was right. The control direction was right, The prop was on correctly. The battery has 5 cycles and was fully charged. It rolled so fast it was as if the ailerons were full deflection. The ailerons were full deflection post crash but I dont know if I put that in to stop the roll or if they malfuctioned that way. The only thing i didnt do was range check the receiver but it is a brand new AR 400 I bought from the LHS. It has the stock PZ motor. The Old 30 amp ESC was destroyed in the crash. I hooked everything back up to a EFlite 40 amp pro ESC and everything seems to work fine. My question is. Was this torque roll that built up. Or was it malfunctioning equipment? The only Parkzone plane I ever crashed was the Icon a5 when I put the prop on backwards. I ordered a new kit and I don't want this to happen again. Thanks in advance. Pat
skypig#232 is offline Find More Posts by skypig#232
Old Jul 31, 2013, 10:54 AM
Field of Dreams Flyer
Mikemynameis's Avatar
San Pedro,Ca
Joined Sep 2004
Did you buy it used or maybe the wing was warped or had a twist in it. Something you should check
Mikemynameis is online now Find More Posts by Mikemynameis
Old Jul 31, 2013, 11:29 AM
Joined Jun 2006
Bf 109 burn in
I did buy it used. How would I tell? The ailerons look ok. I jus t range checked the receiver and I quit at 65 paces.
Old Jul 31, 2013, 11:43 AM
San Pedro,Ca
Joined Sep 2004
Look at the wing at the tips and see if there flat . Check both wings. If one tip is higer or lower then the other then thats your problem. Or maybe your using little or to much ailerons or not enough expo . You might what to post this in the Parkzone 109 thread and see what other people say
http://www.rcgroups.com/forums/showt...parkzon+bf+109
Old Jul 31, 2013, 12:07 PM
Joined Aug 2003
whith ailerons at nuetral /matched wing and aileron te at in board end . check what
you have at the outer end ,dont expect te to macth tip there which is normal.
but the difference should be the same at both tips.
esc/bec part may have failed and caused that
mdugas is online now Find More Posts by mdugas
Old Jul 31, 2013, 12:29 PM
San Pedro,Ca
Joined Sep 2004
Ya listen to him not me I know nothing
Old Jul 31, 2013, 12:31 PM
Joined Jun 2006
Thanks guys ill post it in the 109 thread as well
For Sale Ahead Nero Burning ROM 5.5 Burning Software in Original Box innoplastic Non R/C Items (FS/W) 0 Jun 11, 2013 12:53 AM
Sold Parkzone BF109 BNF kmc189 Aircraft - Electric - Airplanes (FS/W) 3 Mar 27, 2013 08:41 PM
Discussion Help - The roll servo on our X468 XT keeps burning out vividas Multirotor Electronics 5 Mar 15, 2013 05:42 PM
For Sale Parkzone BF109 in Brisbane, Australia Timws Aircraft - Electric - Airplanes (FS/W) 0 Sep 03, 2012 07:33 AM
Discussion P51 BL vs. BF109 in a dogfight (parkzone) Staudacher600 Electric Warbirds 10 Jun 11, 2010 06:32 PM
