Old Jul 17, 2013, 03:00 PM
RyanNX211's Avatar
Upper Arlington, Ohio
Joined Dec 2007
Klass Kote
In an overseas magazine, I saw some tests where the builder successfully covered darker colors with lighter ones. E.g.: model was black and then trimmed with white over the black. No bleed thru or see thru and no primer was used.
Has anyone tried this?
How well does it work over decals?
RyanNX211 is online now Find More Posts by RyanNX211
Old Jul 17, 2013, 07:29 PM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Lots of info. 2 part epoxy, IMO it would be thick and probably cover in one coat. Look here.
And reviews
hoppy is offline Find More Posts by hoppy
Old Jul 18, 2013, 01:47 PM
RyanNX211's Avatar
Joined Dec 2007
I can google. I was looking for personal experience from the people on this board.
Old Jul 18, 2013, 02:53 PM
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Ok.
Old Jul 24, 2013, 08:38 AM
jhaywood's Avatar
United States, VA, Suffolk
Joined Nov 2007
I have not used Klass Kote, but I have used plenty of Epoxy hobby paints, K&B and HobbyPoxy. I could get lighter to cover darker, but I always tried to avoid it. One, it was extra weight, and two it led to a really thick paint film.
jhaywood is offline Find More Posts by jhaywood
Old Jul 25, 2013, 07:43 AM
Hamburger Eatin' Fool
TomCrump's Avatar
Traverse City, Michigan
Joined Dec 2005
I've done it, too. Problems can arise, as the dark color "tints" the lighter color.
Sometimes you have no choice, for instance, when a model is dark, but has light colored trim.
My Stuka was painted in green. The markings and whitewash were painted over it.
This model is painted with Warbird Colors, not KK.
Klass Kote is a high hide paint. As such, what you suggest is possible. I would do it only for trim, however, not over large areas.
TomCrump is online now Find More Posts by TomCrump
Old Jul 25, 2013, 10:07 AM
jhaywood's Avatar
Joined Nov 2007
I always try to put the light colors on first then mask off what will show as the light color, then spray the dark color.
Old Sep 09, 2013, 09:55 PM
Missileer Extraordinaire
Mel Duval's Avatar
Joined Jun 2001
Klass kote is very much like K&B Superpoxy. It is compatible as noted on the KK website. We have used white over red several times for trim with no issues and no primer needed. It works very well and you can put the mixed unused paint in the fridge for recoating in the next day or so. IMHO it is very good paint.....
EDIT: Have not used it over decals....
Mel Duval is offline Find More Posts by Mel Duval
Old Feb 25, 2014, 02:00 PM
USA, OH, cambridge
Joined Sep 2001
If it is the same paint as K&B, you can clear decals. BUT you must dust on the first couple of coats of clear. Decals are not all the same so do a test panel first if possible. I have even used dry transfers under K&B without disolving them.
fgroza is offline Find More Posts by fgroza
Old Mar 24, 2014, 08:55 AM
Florida
Joined Dec 2001
I've used Klass Kote several times and my experience is that the light colors don't cover that well. The first couple times I was stupid and ended up with thick coats until I got coverage. Then I used silver as a barrier and ended up needing less of the lighter color which means lighter finish.
CafeenMan is offline Find More Posts by CafeenMan
Discussion klass kote rotccapt Painting and Finishing Tips 2 Jun 25, 2008 09:25 PM
For Sale Klass Kote Paint! HogCrewChief Aircraft - General - Miscellaneous (FS/W) 0 Feb 02, 2008 05:27 PM
Klass Kote Epoxy Paint now in Canada eldoren Scale Fuel Planes 0 Aug 03, 2005 12:21 PM
anyone use KLASS KOTE epoxy? jeff262 Scale Kit/Scratch Built 1 Apr 04, 2005 04:07 PM
Klass Kote rorywquin Fuel Plane Talk 0 May 10, 2004 03:30 AM
