Old May 02, 2013, 09:20 PM
United States, ME, Windham
Joined Sep 2010
.049 power equivalent
I would like to build a power pod for an Air Hogs Titan glider. Great Planes sells a power pod with a "550 Thrustmaster" motor, or it can be used with an .049 ic motor. So, if I were to build a power pod for the Titan glider, what motor/prop/battery combination would you recommend?
arbalest is offline Find More Posts by arbalest
Old May 02, 2013, 10:52 PM
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
An .049 is ~75-100W equivalent. A Blue/Silver Wonder 2730 motor from Hobby King would work well.. Kv (1300/1500/1700) would depend on what size prop and what voltage pack you wish to use.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old May 03, 2013, 01:50 PM
Joined Sep 2010
.049 equivalent
Doc, thanks. I assume the wattages you list are for 1s,2s or 3s packs? What would an appropriate prop be for leisurly flying a 48" span Air Hogs Titan?
Old May 03, 2013, 05:00 PM
Jack
USA, ME, Ellsworth
Joined May 2008
The wattage is 75W to 100W of input power. If you have a motor pulling 8A at 12V that is 96W or input power. Or if it is drawing 12A at 8V it is also 100W. Amps x Volts = Watts.
The Kv 1300/1500/1700 numbers are three different models of the Blue and Silver Wonder motors 24 gram motors. And the Kv 1300 motor turns at 1300 RPM for each volt of battery voltage, and the 1500 and 1700 turn at higher RPM per volt. Higher Kv motors use smaller props, lower Kv motor use larger but slower turning props.
You want to have mellow vintage type flying so you want larger, slower turning props. So you want the lowest Kv motor (1300 or so)
Here is some test data for the 1300 Kv 2730 motor that Dr Kiwi mentions. Pay attention to the test voltages, anything over 8.4V is a 3S pack, anything below that is 2S.
HXT - 2730-1300 (Silver Wonder) - http://www.flybrushless.com/motor/view/63
Look for a prop that will give you a thrust that is about 1/2 of the ready to fly weight of your plane.
More info here if it is the same plane:
Air hogs titan glider bashing/rc conversion thread!!! - http://www.rcgroups.com/forums/showthread.php?t=1246101
Jack
jackerbes is offline Find More Posts by jackerbes
Old May 03, 2013, 05:14 PM
Dr Kiwi's Avatar
Joined May 2003
Originally Posted by arbalest View Post
Doc, thanks.What would an appropriate prop be for leisurly flying a 48" span Air Hogs Titan?
What is the largest diameter prop that will fit? Given that, we can more easily recommend a suitable motor!
Old May 03, 2013, 08:21 PM
Canada
Joined Nov 2000
Best tested TD 0.49 ran up to 80 watts on 30% nitro.
Back when it was pertinent :-)
Hex 24 gramer / 2730 motor Can and Does spin a 7x6 prop at close to 10 A on 2 S....Effectively.. on an sub 8 ounce SEFF Combat Foamy, resulting in impressive verticals.
Weight as always, is the decider on performance
Lotsa 'in use' info in scratch built foamies forum ?
Bare is online now Find More Posts by Bare
Sold SIG POWER POD for Cox .049-.051 engines New in the Box | hobbyfun100 Aircraft - Sailplanes (FS/W) 3 Mar 11, 2013 09:12 AM
For Sale Vintage 1978 cox 049 gas power star cruiser ufo free flight free shipping tee681 Aircraft - General - Miscellaneous (FS/W) 1 Mar 06, 2013 02:15 PM
Wanted Efite Power 110 or equiv.. kepople Aircraft - Electric - Power Systems (FS/W) 3 Feb 06, 2008 03:03 PM
Wanted AXI 4130/16 , Eflite power 60, or Hacker Equiv tonyjambo Aircraft - Electric - Power Systems (FS/W) 0 Mar 05, 2007 01:08 PM
Sold AVEOX HIGH POWER BRUSHLESS 36/30/2 - Long Can - Equiv to B50L - Neu 15XX etc. Z06kal Aircraft - Electric - Power Systems (FS/W) 4 Jul 05, 2006 11:39 AM
