Old Today, 02:44 PM
UK, Greater London, London
Joined Aug 2010
I know........
New to planes, normally fly helis but this plane looked a blast to fly.. and it is...
But 6,000 +++ posts to look through to find the answer - looked at other sites but nothing really conclusive..
chubbylove is offline Find More Posts by chubbylove
Old Today, 02:54 PM
TurboRacer's Avatar
United States, CT, Waterbury
Joined Oct 2002
Well here - let me make it easy for you.
Hacker A30-10xl v3
4s 2200
50-60a ESC with an external 5v BEC unless you can find an ESC with 5-6v BEC built in.
New servos too because the increased speed/airflow will kill the stockers quick.
Then get ready to smile.
TurboRacer is online now Find More Posts by TurboRacer
Old Today, 03:03 PM
HedRick
HedRick's Avatar
United States, CT, East Haven
Joined Aug 2013
I have that exact setup, and it an absolute blast to fly. It hovers at 1/2 throttle.
HedRick is offline Find More Posts by HedRick
Old Today, 03:04 PM
HedRick
HedRick's Avatar
Joined Aug 2013
Originally Posted by dalecheek1 View Post
here we go again
hahahaha
Old Today, 03:09 PM
Joined Aug 2010
Hi,
Thank you all for your help....
Paul
Old Today, 03:24 PM
HedRick
HedRick's Avatar
Joined Aug 2013
Originally Posted by chubbylove View Post
Hi,
Paul
Chubby love, hahah!
Old Today, 03:35 PM
Gold Coast Coolangata, Australia
Joined Nov 2003
Hello, got my visionaire today - maidened - found it a bit slow in general flight mode - has anyone tried this plane on a 4s lipo? I know the esc can handle it...
what adjustment were needed..
In 3D mode its cool... just want a bit more speed..
Cheers, Paul..
Easiest/cheapest way to pick up a bit of speed while still maintaining good 3D flight is to change the stock 12x4 Eflite prop with an APC 11x5.5 Electric prop.
The only thing you need to do with this prop (other than balancing it) is to add a prop washer to the front, under the prop nut (any washer with ~8mm hole, 1.5-2mm thick will work fine).
The APC prop is a lot more eff and is much smoother/quieter. Runtimes and max amp draw is not significantly diff (actually, slightly better than the stock prop).
I recommend you try this prop before changing out the stock 3s power system.
TomC is offline Find More Posts by TomC
Old Today, 05:53 PM
United States, NC, Garner
Joined Nov 2012
VISIONAIRE SLOW BACKYARD FLYING (5 min 19 sec)
dalecheek1 is online now Find More Posts by dalecheek1
Old Today, 08:04 PM
Joined Jul 2005
I too have had very good luck with the APC 11x5.5 i like it better than the APC 12x6
deafmusicman is offline Find More Posts by deafmusicman
Discussion Parkzone's New Habu 2 EDF ChuckTseeker Foamy EDFs 4188 Jul 21, 2014 07:18 PM
For Sale New Parkzone S.E.5a w/ AR600 Rx - LPU Kevinfred Aircraft - Electric - Airplanes (FS/W) 1 Jul 12, 2012 12:26 AM
Sold New Parkzone S.E.5a w/ AR600 Rx - LPU Kevinfred Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Jun 23, 2012 09:10 AM
