Old Sep 29, 2013, 06:22 PM
Joined May 2011
Hey I know it's not good but that can sometimes take a few days before I reply to mail.
Because I have a lot of work and FPVlongrange is a hobby and therefore it may take a few days between I read the mail.
Regards John
John Jensen is offline Find More Posts by John Jensen
Old Nov 24, 2013, 01:08 PM
Enjoying life through flight
Joined Mar 2012
Hello,
I have recently purchased the UHF repeater system and it is not working with my EzUHF.
I have programmed the repeater to 8ch and I am using my Spektrum Radio/Receiver.
I know that all of the wiring is correct, but no matter what I do, my EzUHF will not correctly startup. When I power on the EzUHF, it just starts beeping, signaling that it is not receiving a good PPM signal from the repeater.
Here are more details of my setup:
There are four wires coming out of the ezuhf cable. I have connected the red one to the yellow signal wire on the repeater, and the white wire on the ezuhf cable to the black wire on the repeater system. I know that this is the correct assignment of cables as I have tested where each cable does goes with a multimeter. I have tried switched modes on the repeater to both 8ch and 9ch, but neither works.
I know that this whole problem is not because of the ezuhf because it works fine when it is connected directly to my Spektrum Dx18.
Any help would be appreciated.
Best,
George
BigEast is offline Find More Posts by BigEast
Old Jan 01, 2014, 04:16 PM
Joined May 2011
Hi Happy New Year to all
The problems with Ez is that they have changed little on how PPM stream should be.
I have changed a bit in the software and now it works with Ez again.
If anyone has one they would like to have obdateret please send an email and I will say what you need to do.
Regards John
Old Jan 17, 2014, 02:04 PM
crazytaz's Avatar
New Zealand, Bay Of Plenty, Tauranga
Joined Dec 2008
Why can you not just take the PPM output from your RX and connect it directly to the PPM in on the EzUhf Unit ... why the need for the converter ..is it just for people with out PPM capable Rx ?
crazytaz is offline Find More Posts by crazytaz
Old May 02, 2014, 09:43 AM
iw28's Avatar
Denmark Copenhagen Hvidovre
Joined Nov 2009
Is it just me, or is this just a device that takes PWM from a normal receiver and summarize the PWM into PPM, a socalled PWM to PPM converter which goes further to the UHF system.
I think it can be made by using a simple atmega from an Arduino, or if you want a absolut low latency delay you could use an FPGA to operate all the inputs parallel and therefor eliminating the latency delay.
Easy tutorial of how to make a PWM to PPM converter using arduino.
http://www.rcgroups.com/forums/showthread.php?t=1000132
iw28 is offline Find More Posts by iw28
Old May 02, 2014, 08:58 PM
fliteline dave's Avatar
Canada, BC, Fort St. John
Joined Jan 2011
ya what's up
same question
fliteline dave is offline Find More Posts by fliteline dave
Old May 03, 2014, 02:48 PM
crazytaz's Avatar
Joined Dec 2008
Originally Posted by fliteline dave View Post
same question
Yeah ! Just what I said .. LOL
Yippee! DRAGON LINK - New V2, Professional Grade Long Range FPV System, Always in Stock ! JettPilot FPV Equipment 31275 Today 11:02 PM
Question UHF System Can connect to the 7 Channels Radio System ? RanDavari FPV Talk 7 Nov 15, 2011 10:04 AM
Suggestion Flyinjrc74 repeatedly abusing the feedback system. flyer368 Site Suggestions / Complaints 1 Nov 11, 2011 01:22 PM
Discussion Alternative to expensive UHF system fpvguy FPV Talk 1 Sep 19, 2011 11:32 PM
Discussion How do I switch off 2.4 Ghz system when I only want to use UHF system? Voguna FPV Talk 1 Oct 07, 2010 06:16 AM
