Old Jan 16, 2012, 12:16 PM
antonlubo's Avatar
East SF bay
Joined Apr 2007
Futaba tx
I have a Futaba T10CAP, that I find quite useful. I was wondering about how to set the endpoint adjustment to a negative for altitude hold and auto leveling, as mentioned in the users manual for the Hoverfly. There are a couple of three position switches on the tx, one I have dedicated to auto leveling, though I can't seem to get a negative number in the setup. Probably a simple fix, though I can't seem to get my brain around it...Tony
antonlubo is offline Find More Posts by antonlubo
Old Jan 16, 2012, 12:32 PM
antonlubo's Avatar
East SF bay
Joined Apr 2007
I think I have it figured out. ...Tony
Old Jan 16, 2012, 01:17 PM
Who's got the Tx ?
Boeing744's Avatar
United Kingdom, Whitchurch
Joined Jul 2010
Futaba endpoints
Hi
If the 10C is the same as my 9C then you set one endpoint with the switch up to whatever value you require, then flip the switch down and set the other endpoint to your required value. the + and - really refer to the switch positions. Check the travel on the servo page if you have one and you will see the travel is up and down about the centre line indicating positive and negative values around centre.
Boeing744 is offline Find More Posts by Boeing744
Old Jan 16, 2012, 01:48 PM
France
Joined Dec 2006
You better have to select a two position switch for autoleveling or altitude hold, not a three positions one. Th ethree position is needed for the GPS (normal, PH, RH)
alain
gweleps is offline Find More Posts by gweleps
Old Jan 16, 2012, 03:53 PM
antonlubo's Avatar
East SF bay
Joined Apr 2007
alain
Thanks, I read wrong, you're right. Tony
For Sale Futaba 6EX 2.4 tx / FP-TK-FSS rx module / UltraMicro Tx Ice Aircraft - General - Radio Equipment (FS/W) 2 Jul 19, 2012 04:33 PM
Eflite Blade TX/4in1 AND Futaba 4NBL TX/RX gargoyle7 Non R/C Items (FS/W) 4 Oct 30, 2011 07:26 PM
Sold Futaba 6EX 2.4 tx / FP-TK-FSS tx module / UltraMicro Tx Ice Aircraft - General - Radio Equipment (FS/W) 3 Aug 01, 2011 07:13 AM
For Sale Futaba 6EX 2.4 tx / FP-TK-FSS rx module / UltraMicro Tx Ice Aircraft - General - Radio Equipment (FS/W) 1 Jul 07, 2011 09:26 AM
For Sale Futaba 7CAP TX Futaba Soft TX case and Futaba neck Strap ch38 millerhill Aircraft - General - Radio Equipment (FS/W) 4 Dec 06, 2007 01:58 PM
