Old Nov 03, 2011, 06:48 AM
Wanton construction
Pouncer's Avatar
Stockholm Sweden
Joined Sep 2006
Question
E-Flite BL 180 outrunner equivalent?
Hi all,
I'm looking for an outrunner of similar specs to the E-Flite 180 (the link is to the 2300 kV, there's a 3000 kV as well, as found in the UM Stryker).
Anyone with experience of HK outrunners in the 5-10 gram range?
This one or maybe this one?
And a 5 Amp ESC with a 4.2 V BEC?
I'm looking into scratch-building a Stryker with cheap components with this receiver and these servos, the Rx can handle 5 V input but I worry about the servos as they are rated for 4.2 V max.
Pouncer is offline Find More Posts by Pouncer
Old Nov 03, 2011, 06:59 AM
everynameistaken's Avatar
United States, RI
Joined Feb 2006
Originally Posted by Pouncer View Post
Hi all,
This is probably the exact same thing:
http://www.headsuprc.com/servlet/the...0-Sport/Detail
I have used these with good results. I think these are a little "hotter" than the eflite 180 as well.
everynameistaken is offline Find More Posts by everynameistaken
Old Nov 03, 2011, 11:20 AM
Ego varius quis.
Cheesehead's Avatar
Wisconsin
Joined Nov 2003
The AP05 is a little less powerful than the Park 180, and roughly on par with the low-kV version in the Beast. (It's also several grams lighter.) Very nice motor, and the thrust per watt is very good for the size.
The C10 seems to measure well and weighs about the same, and the "10 gram" 1811 brushless (which I'm told weighs closer to thirteen?) is good on three cells. I've never seen the "1306" listed above, though it looks very nice, too. (There's also the ADH50XL, which is available in a very low kV variant. Decisisions, decisions...)
It would be nice to compile information on all of these motors. Aside from the 1811 and AP05, there's not a lot of useful data.
Cheesehead is offline Find More Posts by Cheesehead
Old Nov 03, 2011, 05:29 PM
4000 posts?!
micro_builder's Avatar
United States, TX, Fort Worth
Joined Jan 2005
I've got this one in my scratch built micro Stryker. Running it on 3S through a Turnigy Plush 6A ESC, AR6300 RX and HKs linear servos. Other than the bearings being a bit faulty, its worked great, gets the plane up to at least 70mph.
Nick
micro_builder is online now Find More Posts by micro_builder
Old Nov 03, 2011, 08:13 PM
It's a Great Day to Fly
LenBFP's Avatar
Melbourne Beach, Florida
Joined Jan 2002
The AP05
http://www.hobbyking.com/hobbyking/s...tor_5_4g_.html
is half the weight of the "10" gram motor, and about equivalent to the beast motor.
I like it a lot. I like the 10 gram motor a lot too, but it is twice the weight and really needs bigger batteries than the AP05 which I run with Hyperion 180mah 2S batteries. I use a stripped down 6 gram/6 amp (don't really need the amps but it works good with high kv motors) and solder the motor leads directly to the controller. If the plane is light and fast I will use the 5x4.3 GWS.
I use these servos and although they say 1S, so far they work fine on 5 volts.
http://www.hobbyking.com/hobbyking/s...ght_Left_.html
Len
LenBFP is offline Find More Posts by LenBFP
Old Nov 03, 2011, 08:41 PM
Ego varius quis.
Cheesehead's Avatar
Wisconsin
Joined Nov 2003
Does anyone here know where I can find thrust measurements for the less popular motors? The "1811" motor is very nice, but from what I've read, efficiency is only optimal if used on three cells.
Old Nov 04, 2011, 12:42 AM
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
my 1811 works fine on 2 cells, with a 300mah pack , i get around 8 minutes of sport flying on a 4 ounce model.
derk is offline Find More Posts by derk
Old Nov 04, 2011, 09:32 PM
Same Day Delivery
mike3976's Avatar
Economy, Pa.
Joined Mar 2002
http://www.rcgroups.com/forums/showt...t+mod+s+thread
LotS OF INFO ON THE AP-05
mike3976 is offline Find More Posts by mike3976
Old Nov 04, 2011, 10:57 PM
Ego varius quis.
Cheesehead's Avatar
Wisconsin
Joined Nov 2003
I saw a plot showing efficiency increasing from 60% to 80% on three cells and a reduction in propeller size. Of course, this is only beneficial at higher flight speeds, but it's interesting to consider regardless, and allows for interesting possibilities with gearing.
Old Jan 23, 2012, 07:47 AM
road wart
racie34's Avatar
United States, CT, Stonington
Joined Aug 2003
is the micro stryker motor 10grs? 3000 kv?
racie34 is offline Find More Posts by racie34
Old Jan 23, 2012, 11:08 AM
West of California Speedway, East of LaLa, North of Disneyland
Joined May 2001
That looks exactly like the LCD 10 gram motor that HK sells.
Look here for data:
http://home.comcast.net/~gordon-johnson/lcd.htm
356Jim is offline Find More Posts by 356Jim
Wanted e-flite Park 180 Outrunner Damaged Motor Cecil M Wethy Aircraft - Electric - Power Systems (FS/W) 1 May 13, 2011 07:39 AM
Help! E-Flite BL 450 Outrunner, what other motor is the same?? big_poppa4904 Power Systems 13 Mar 28, 2011 07:11 PM
Build Log Park Scale S.E.5a with E-Flite 180 outrunner ZRS4 Parkflyers 3 Aug 16, 2008 01:05 AM
Sold E-flite 22-Amp BL ESC Combo with the E-flite park 450 pnp 890kv outrunner. hobby-plane-rc Aircraft - Electric - Power Systems (FS/W) 2 May 08, 2008 10:13 PM
For Sale E-Flite 15 BL Outrunner & Multiplex BL 480/6D Triptykon Aircraft - Electric - Power Systems (FS/W) 0 Sep 08, 2006 04:09 PM
