Old May 27, 2015, 06:58 AM
ec121connie is offline
Find More Posts by ec121connie
CG =Airplanes .. COG's = Gears
United States, CA, Sacramento
Joined Dec 2005
F6F Park Flyer
I was looking for a project for a quiet park flier that would be easy to see, reasonably slow flying and and looked like an old WW2 fighter. I took a look at the materials I had on hand and this F6F is what I came up with.
45 inch span, OAL 32 1/2 inches and about 382 square inches of wing area. The wing and horizontal stab was placed near the thrust line. Over sized control surfaces to keep the kids happy and plenty of expo to tame it down for the old guy.
Iíve had good results with the equipment I buy from the folks at Heads Up R/C. I had these parts on hand
9G Servos
http://www.headsuphobby.com/Towerpro...ervo-B-510.htm
Receiver
http://www.headsuphobby.com/Power-Up...iver-G-656.htm
EMax 2220/10 and an 11x3.8 SF prop
http://www.headsuphobby.com/Emax-BL2...otor-D-211.htm
Sky Power 30amp ESC
http://www.headsuphobby.com/Sky-Powe...-BEC-H-100.htm
Batteries 1300mah 3 cell
http://www.headsuphobby.com/111v-130...tery-F-147.htm
I used a scaled up a 3 view to get the basic shapes and drew the patterns directly on the foam sheets. I used a thin maple spar for the wing and balsa for the hinge line on the stabs. The foam used was a combination of FFF and DTF. Painted with a brush using the Apple Barrel acrylics from Wally World.
The upper fuselage half has tabs that align the wing and stab as well as seat in pockets in the lower fuselage half. I think the wood workers would call it mortise and tenon construction.
The F6 weighed 9 ounces painted before electronics added. I didnít weigh it after assembly. Just took it to the park and turned it loose. Flies great and tools around at 1/2 throttle. Accelerates vertically out of a hover and rolls like a bandit when you put the stick hard over.
Overall, this was a fun project to build and itís a hoot to fly. I'm heading back to the garage to see what may be in the parts bin. Might need a Tony or Zero to keep the HellCat company
Regards,
Connie
ec121connie is offline Find More Posts by ec121connie
Old May 27, 2015, 09:15 AM
cbalgra is offline
Find More Posts by cbalgra
cbalgra's Avatar
Orange, CA
Joined Jun 2007
Looks real nice Connie.
cbalgra is offline Find More Posts by cbalgra
Old May 27, 2015, 06:12 PM
Joined Dec 2005
Thanks CB,
Fun to build and a blast to fly. Some times you just get lucky.
Regards,
Connie
Discussion Suggestions for wide fuselage park flyer frame/kit sjtrny Parkflyers 2 Dec 28, 2014 06:00 PM
Sold /// PRICE REDUCED /// Futaba R616FFM 6Ch 2.4GHz FASST Micro Park Flyer Rx modestmagi Aircraft - General - Radio Equipment (FS/W) 5 Dec 18, 2014 01:32 AM
Sold JR RG611b 6-ch DMSS park flyer Receiver Lowrider1960 Aircraft - General - Radio Equipment (FS/W) 2 Dec 15, 2014 03:10 PM
Discussion Great Planes F6F Hellcat EP Park Flyer ARF p-w Electric Warbirds 13 Dec 09, 2007 11:23 AM
