Old Today, 07:39 AM
keffe1 is offline
Find More Posts by keffe1
Deranged long range
Sweden, Uppsala County, Uppsala
Joined Aug 2013
FPV'd mine. Now I just have to try flying her FPV which I probably will do tonight. Tried to pirate in a picture but my f*****g phone tells me it's not a valid image file.
keffe1 is offline Find More Posts by keffe1
Old Today, 07:40 AM
Daedalus66 is online now
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Hobby King Skipper/Joysway Dragonfly
Forget flaperons. They are ineffective and unnecessary. If you feel the need for any such assistance, explore spoileron action (raising the ailerons about 20 degrees) to create extra drag. But be careful, as application of any kind of up or down elevon at speed will produce violent pitch up or pitch down. This sort of thing is interesting to play with but not helpful for normal flying.
If the model is landing too fast, that's simply a matter of piloting technique. It can be landed at very low speed within just a few feet. This type of landing has been called the "Polaris Plop", but can be done equally well with Skipper.
Best prop is APC 6x4.
Daedalus66 is online now Find More Posts by Daedalus66
Old Today, 02:30 PM
keffe1 is offline
Deranged long range
Joined Aug 2013
Right. Think I'm starting to get the hang of it now. Is it just me that finds the plane a bit underpowered? Actually, for a while I thought the prop was on the wrong way or something but that does not appear to be the case. The plane seems to consume amps in a way that is not in proportion to the thrust that comes out. It's even quite difficult to take off by throwing the plane and I have had aborted take-offs/crashes several times. Any ideas?
Anyway, re-maiden today but now as an FPV-plane which was fun.
Old Today, 08:07 PM
Mazzepa1 is online now
Find More Posts by Mazzepa1
This is kid stuff.
Mazzepa1's Avatar
USA, AR, Harrison
Joined Aug 2010
How does it sound? This may not help if you are not familiar with 2200KV motors, but at full throttle with a 6x4 prop on they almost scream, but not quite.
We are talking about the stock motor & prop on 3S, right? My stock Skipper w/a 1300mah, 3S battery will ROG easily so hand launch should be no problem.
Let's start at the beginning:
1. Looking from the nose of the plane at the motor, rotation should be CCW, prop lettering facing you.
2. ESC calibrated to give full output at max throttle stick position?
3. Prop adapter tight on shaft?
Mazzepa1 is online now Find More Posts by Mazzepa1
Old Today, 08:13 PM
zeeinbc is online now
Find More Posts by zeeinbc
Joined Jan 2015
keffe: can you post some images of the FPV setup.
I'm still trying to figure out where to put the camera and transmitter.
The transmitter gets quite hot, so i think It'll have to be outside the body, which means water.. any images you have would be awesome, I've seen a few so far, but I'm not sure I can fly with the camera up on a pod just yet, since most of my skipper landings end up with the nose going under for a second and then the whole thing popping back out!
I've lawndarted the skipper enough that its primary role right now is to push broken boats back to shore - so FPV would be fun
Skipper saves the day! sorta. (0 min 37 sec)
zeeinbc is online now Find More Posts by zeeinbc
Help! Can anyone Help Me out? Hobby King Fiasco Demon 6 HobbyKing 55 Jan 12, 2013 07:19 PM
Sold Hobby King Multi-battery charging adapter for UMX-type batteries K_B Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 03, 2013 07:02 AM
Alert hobby king make magic hobby king just wash their dirty hand presa1200 HobbyKing 71 Jul 21, 2011 08:45 AM
For Sale orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 8 Mar 15, 2011 01:41 PM
Sold orange rx from hobby king and orange satilite from hobby king ZEROSKIN76 Aircraft - General - Radio Equipment (FS/W) 4 Feb 21, 2011 12:06 PM
