Old Jun 05, 2015, 10:29 AM
pencon is offline
Find More Posts by pencon
Joined Dec 2008
Originally Posted by D_FAST View Post
i dont really have a problem with burning.
None of my bows are longer then 6 in" therefor i can cut on 3-6 amps
Now if you intended on using them more then 3 times, CA around the edges is a great idea, as the board will tend to delaminate over time, from removing and replacing add pressure when cutting around them.
That's why I cut the more delicate templates out of .010 aluminum flashing from the hardware store . Cuts easily with scissors and there's almost no sanding required , no delaminating and you can use them as many times as you need to .
pencon is offline Find More Posts by pencon
Old Jun 28, 2015, 12:45 PM
James Rhodes is offline
Find More Posts by James Rhodes
Joined Jun 2015
Flash back to the past. I use to work those thing and love to watch them fly. Softshell29 where di you get your model from and what scale is it?
James Rhodes is offline Find More Posts by James Rhodes
Build Log F-106 Delta Dart... DanSavage Electric Ducted Fan Jet Talk 270 Mar 23, 2012 05:58 PM
Build Log F-106 Delta Dart jgmtens Pusher Prop Jet Models 50 Jul 31, 2007 03:55 PM
Discussion Aero Ace F-106 Delta Dart sr71fan Scratchbuilt Indoor and Micro Models 7 Apr 10, 2007 01:37 AM
Question F-106 Delta Dart Aceshigh84 Electric Ducted Fan Jet Talk 18 Jan 20, 2007 04:10 PM
F-106 Delta Dart dirtdiver Electric Plane Talk 22 Dec 22, 2002 09:17 AM
