Old Jul 26, 2012, 08:30 PM
cdina36315 is offline
Find More Posts by cdina36315
Good thing we brought the glue
USA, NY, Carmel
Joined Feb 2008
64mm motor recommondation ?
Hi,
Can anyone recommend a reasonably priced motor for a 64mm EDF ?
I would like to use it with my 3 cell 1300 bats.
I currently have a Turnigy 4400 in one of my jets, which I love and it was pretty cheap at the time. But can't find them anymore.
Motors confuse the hell out of me. Seems like there are $15 to $50 ones, with the same specs.
Not looking for super speed, just good power and good flight time.
cdina36315 is offline Find More Posts by cdina36315
Old Jul 26, 2012, 09:19 PM
VIDEOPRO is offline
Find More Posts by VIDEOPRO
VIDEOPRO's Avatar
Central Maryland
Joined Apr 2008
Originally Posted by cdina36315 View Post
Hi,
All depends on what jet your using it in and weight of the jet. What size esc you have as well. How many blades you want to use to push the airframe with.
I have an F-18 64mm that weighs in around 560 grams without the battery. It has a 2615 4800kv motor and flys on a Turnigy 2200mah 3s 35c battery really well. It has the GWS 6 blade fan. I have a Thunderbird 54amp esc as this set up pulls about 40 amps. Get around 4 1/2 minutes flight at 3/4 to full throttle. This is very easily hand launched.
VIDEOPRO is offline Find More Posts by VIDEOPRO
Old Jul 27, 2012, 08:37 AM
Joe 1320 is offline
Find More Posts by Joe 1320
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
Hi,
What is the C rating of the lipo? That goes a long way toward figuring out what motor to use.
Joe 1320 is offline Find More Posts by Joe 1320
Old Jul 27, 2012, 01:04 PM
USA, NY, Carmel
Joined Feb 2008
Hi,
I have a bunch of the Turnigy 1300Mah bats, with a C rating of 25 -35.
Maybe this will help. I currently have the Great Planes L-39 with stock 55mm fan and stock ESC. I am using the Turnigy 4400 motor in it with the 1300 Bats.
I consider this a perfect setup. Lots of power and good flight time.
So I am trying to find a motor to replace the Turnigy 4400, since I can no longer find them.
Though I would like this motor for my F-22 with stock single 64mm fan and ESC.
I may be naive, but I figure if this motor is really good in the 55mm it should be good in the 64mm.
Any input would be appreciated. I assume kind of assume most stock 64mm setups are similar, so just looking for a good motor to replace the stock motor, which is pretty lame.
Old Jul 27, 2012, 01:15 PM
ex-racr is offline
Find More Posts by ex-racr
AKA Terry Till
ex-racr's Avatar
Alexandria, VA
Joined Apr 2002
This motor is the right kv:
http://www.donsrc.com/cart/index.php...&product_id=93
Don is a very good person to buy from.
If you want cheaper, I don't have an answer for you.
Terry
ex-racr is offline Find More Posts by ex-racr
Old Jul 27, 2012, 03:33 PM
solentlife is offline
Find More Posts by solentlife
222 km/hr Parkjet flyer
solentlife's Avatar
Latvia, Ventspils pilsēta, Ventspils
Joined Jan 2010
Go on Hobby King site and look at the EDF Brushless motors ... the 2615 ... 2810 range are all designed for 55 - 64mm EDF use. They range from 3800 up to 5000kv ...... the optimum one as I have found with a 6 blade standard stock 64mm is the 2810 4300KV ... if you go higher KV then you need to cut back on blade count as the amps go up dramatically.
I currently use the 2810 4300kv in my 64mm T45 and it is a beaut on a 3S ... but 4S is a high amp ticket.
Nigel
solentlife is offline Find More Posts by solentlife
Old Jul 27, 2012, 03:40 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Hi,
hobbypartz has a line of EDF motors that are right here in the states. Free shipping too if you order is at least $50. a 4800 kV is a sweet setup for 64mm fans but it will consume over 35 amps, it will be a bit much for your current lipos.
http://www.hobbypartz.com/edfmotors.html
Old Jul 27, 2012, 07:12 PM
VIDEOPRO is offline
VIDEOPRO's Avatar
Central Maryland
Joined Apr 2008
For your 1300 mah 25c-35c batteries your best bet would be the 4300kv motor and a 5 blade fan to keep the amp draw within your battery spec and would most likley be safe for the stock esc already in the jet.
Here: http://www.hobbyking.com/hobbyking/s...r_55_64mm.html
Old Jul 27, 2012, 07:52 PM
USA, NY, Carmel
Joined Feb 2008
Thanks a lot guys,
All of your comments make sense.
I ordered 2 of the Exceed 4300's, from Hobby Partz, since they are closer and the price seemed the same as HobbyKing.
Old Jul 28, 2012, 09:35 AM
solentlife's Avatar
Joined Jan 2010
Good choice ... the problem with EDF is that to get more thrust is a game of mix and match. With a prop plane - you get pretty goods ground indication of change ... with EDF it is not so obvious at times.
I would suggest not to be tempted to go up in kv or blade ... until happy with present and then glean info from all sorts of sources about possible combos of motor / fan etc. One part out of synch and you could be draining a batt in short space ... get it right and battery is happy.
I speak from my own learning curve and STILL mixing / matching to get best combo.
Nigel
Old Aug 02, 2012, 07:33 PM
USA, NY, Carmel
Joined Feb 2008
Hey is it normal for HobbyPartz to not provide information as to when their items ship.
I placed the order last Friday. They sent the automated confirmation.
And nothing since (4 business days later).
I asked for an update yesterday and no reply today.
So far I am having a real bad experience.
Old Aug 02, 2012, 07:50 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
I've never had a problem with Hobbypartz, that's not saying that it couldn't happen. I order so much from so many different sources, I really don't remember if hobbyparts sends a notice of shipping.
Did you try the live chat? It works 9-7, Monday - Friday. You could get on there right now as it's before 9PM eastern and they are on Pacific time.
Old Aug 02, 2012, 07:54 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
I went back and looked at a previous order, yes... they send a shipping confirmation e-mail. I would hit the live chat.
Old Aug 02, 2012, 08:08 PM
USA, NY, Carmel
Joined Feb 2008
I sent another inquiry tonight and they replied pretty quickly. But I also said if the order hasn't shipped yet, to cancel it.
I don't mind waiting for shipping, but I am not waiting four plus days to process the order. So they cancelled it.
Looks like I am going to order from Hobby King. I know sounds ridiculous, but I have little patience.
Old Aug 02, 2012, 08:12 PM
Joe 1320 is offline
Joe 1320's Avatar
Joined Feb 2006
Oh boy..... you think hobby king will be quicker? Plan on seeing your motor in several weeks.
Sold 2627 4200kv EDF motor 55/64mm Fans $15 Shipped Johnnymeg Aircraft - Electric - Jets (FS/W) 2 Jul 02, 2012 03:33 PM
Wanted WTB. 64mm edf with motor TMAC4123 Aircraft - Electric - Jets (FS/W) 1 Jun 27, 2012 04:01 PM
For Sale 64MM brushless motors hi2nr Aircraft - Electric - Power Systems (FS/W) 0 Jun 22, 2012 02:23 PM
Wanted 64mm EDF, Motor, ESC acetech09 Aircraft - Electric - Power Systems (FS/W) 1 Jun 12, 2012 03:39 PM
