Old Sep 01, 2011, 03:31 PM
QTRPILOT is offline
Find More Posts by QTRPILOT
Joined Sep 2011
New guy here, have a few questions.
Hey guys, I'm new here. (you can just skip the boring introduction and scroll down to my question lol) I decided to start flying my planes again and finish building a 31 year old unfinished plane my father once started.
I have a Carl Goldberg anniversary edition Piper J-3 with a .46 engine, I had this one for 12 years and it never let me down. I must have crashed it over 7 times and it's still perfect. I'm going to cover it again.
I also have a Chinese made Cessna 182, complete piece of crap. As soon as it took off the wing snapped. That one has a .40 engine and is being repaired.
I have a glider too with an electric motor, in case you need it. Haven't flown it yet.
I also had a few trainers which I crashed and destroyed lol.
And this plane. I can't remember what it's called. Acrobat something. My father built it when he was 17. He never was able to fly it because he couldn't afford an engine or servos and it stayed forever in my grandfather's house until a couple years ago that I took it home with me.
The wings and fuselage are already built. I just need to put the electronics, an engine and cover the wings and a few finishing touches.
So here comes my question. I have a barely used .40 engine (remember the Cessna?) that I could put in it. I pretty much have everything to have it flying but I'm tired of petrol engines. I want to make it an electric plane.
What brushless motor would you recommend for it? I don't want to over power it. The balsa wood has dried over the years and I don't want to over stress it. I want an engine with enough power to fly without worries.
I don't want an expensive engine either, the cheaper, the better but I don't want bad quality one either.
Oh and what battery would you recommend me for it?
Thanks and sorry for the long intro lol.
QTRPILOT is offline Find More Posts by QTRPILOT
Old Sep 01, 2011, 10:04 PM
ray foley is offline
Find More Posts by ray foley
volare est vivere
ray foley's Avatar
United States, OH, Toledo
Joined Jan 2005
hi there from Toledo
for a 40 size airplane, an Axi 412018, an 80 amp speed control, a 5s lipo 4000mah, an apc 15x8 eprop, a longer LG. This will give about 700 watts or so and is a known great package for this size airplane.
There are chinese knockoffs for fewer $$, caveat emptor.
ciao -rjf
ray foley is offline Find More Posts by ray foley
tmb55 is offline
Find More Posts by tmb55
2 no or knot 2 no!
BC, Canada
Joined Sep 2009
No expert advice from me, but seeing as no one else is replying I suspect that this motor or something similar would be a good choice.
http://www.hobbyking.com/hobbyking/s..._AXi_2820.html
add a 40-50 amp esc and 2200 mah lipo and 11x6 prop and go from there.
Perhaps you could add more info such as wing type/span and wieght of airframe.
After reading the above post ( lol same time) MAYBE THE NEXT SIZE UP MOTOR MIGHT BE A BETTER (oops caps) idea.
they say Suitable for the following model weights;
Trainer: up to 2.6kg
Warbird/Sport: 1.8kg
3D: 1.5kg
tmb55 is offline Find More Posts by tmb55
Old Sep 02, 2011, 07:03 AM
QTRPILOT is offline
Joined Sep 2011
Thanks for the help guys!
What do you think of this motor with this esc?
http://www.hobbyking.com/hobbyking/s...r_55_64mm.html
http://www.hobbyking.com/hobbyking/s...ontroller.html
Old Sep 02, 2011, 07:19 AM
3D-Dabbler is offline
Find More Posts by 3D-Dabbler
Just "hanging" Around
3D-Dabbler's Avatar
Richmond, VA
Joined Oct 2009
That is a motor for an EDF jet. It will not work for your purposes. The KV is too high.
If you provide a little more information people can be more helpful. What is the wing span and weight of the plane you want to fly? Is it a tail dragger? Is it a Sport Plane, 3D plane, something else? What is the prop clearance?
A picture would also be helpful.
3D-Dabbler is offline Find More Posts by 3D-Dabbler
Old Sep 02, 2011, 07:40 AM
eye4wings is offline
Find More Posts by eye4wings
...design-build-fly-publish...
eye4wings's Avatar
Ware, herts. U.K.
Joined Sep 2008
Also where are you in the world?
Links are fine but postage can be a killer if you live across the water (as I do) in UK.
There may be other outlets that can supply quicker.
eye4wings is offline Find More Posts by eye4wings
Old Sep 02, 2011, 08:00 AM
QTRPILOT is offline
Joined Sep 2011
I live in Qatar (middle east) no problems with shipping for me from the U.S. or the U.K.
I'm a pilot and can have them shipped to my hotel.
Sorry, should of given more info.
Wingspan is 46"
Fuselage is 35"
It's a tail dragger, sport plane. I will do some basic aerobatics with it but not too much. The plane is 31 years old and the balsa wood is pretty dried up. I don't wanna push it.
I believe it's made for a .40-.46 glow engine.
I'm not sure about weight.
Here is what I'm working with.
The motor Ray Foley recommended is a bit pricey for me.
And the one tmb55 recommend is in back order.
rafe_b is offline
Find More Posts by rafe_b
Joined Jan 2009
QTRPILOT: if you can give us the approximate weight of the airframe, the wingspan and chord (or wing area) -- we might be able to give a better recommendation for the power system. The Turnigy 35-42 recommended earlier is probably good for a sport flyer up to maybe four pounds or so.
rafe_b is offline Find More Posts by rafe_b
Old Sep 02, 2011, 08:07 AM
QTRPILOT is offline
Joined Sep 2011
I'm going to take it to my neighbor's and weigh it, my scale is broken
Old Sep 02, 2011, 08:18 AM
QTRPILOT is offline
Joined Sep 2011
Okay just weighted it. As seen in the picture above, it weighs exactly 600g. The wings weigh 240g and the fuselage 360g.
Landing gear weighs 100g. Still got to add the weight of the ailerons and rudder and the weight of the wings once covered. So approximately 800g fully assembled without electronics?
Old Sep 02, 2011, 09:04 AM
3D-Dabbler's Avatar
Richmond, VA
Joined Oct 2009
Ok, that is pretty light.
Here are some thoughts. A 70 gram motor on 3S should do it. Your KV should be around 1000 to 1100. Here are some options. I would only go to the heavier motors if the lighter one turns out to be underpowered.
A Torque 2830T/1095 or Torque 2818T/900 would do nicely with a ~35 - 45 amp ESC.
http://extremeflightrc.com/html/torque.html
An Omega 72 or Omega 103 with 35 - 45 amp ESC.
http://www.3dhobbyshop.com/Omega-103...r_p_15516.html
or from here
http://www.adchobbystore.com/Omega-1...tor_p_257.html
Hacker A30-28S or A30-16M with 35 amp ESC
http://www.aero-model.com/Hacker-Bru...30-16M-V2.aspx
http://www.aero-model.com/Hacker-Brushless-A30-28S.aspx
Old Sep 02, 2011, 09:22 AM
scirocco is online now
Find More Posts by scirocco
scirocco's Avatar
Australia, ACT, Kambah
Joined Feb 2001
if it was made for a .40 glow, I'd expect balance problems with a 70g motor. It looks like a fairly short nose model, so not much room to get batteries forward etc
A Turnigy G32 - in stock and $30 weighs about 220g, still a bit less than a .40 glow with muffler and throttle servo but in the ballpark.
On 3 cells and a 12x10 it drags my 4+lb Kadet LT-25 very nicely. If you couldn't fit a 12" prop, it would work well on 4 cells with as small as a 10x6 and still generate around 5lb static thrust - heaps for what you want to do
scirocco is online now Find More Posts by scirocco
Old Sep 02, 2011, 09:37 AM
3D-Dabbler's Avatar
Richmond, VA
Joined Oct 2009
Good point about balance although it seems awefully light to have been designed for a .40 glow.
Old Sep 02, 2011, 09:39 AM
eye4wings's Avatar
Ware, herts. U.K.
Joined Sep 2008
Okay, so you're probably going to land up with a plane weighing between 4.5 and 5 pounds - so multiply by 60 for a gentle sport / scale sort of performance and we arrive at a minimum of 300Watts power required.
So we're looking for a 400W motor (to give a safety margin) which puts the Turnigy mentioned above in the right area.
It so happens I was testing a similar motor (rebranded Turnigy) for a friend yesterday so I'll give you the results here...
http://www.giantcod.co.uk/xyh3548-11...-p-403281.html
I have just bought four of these for my next build and they have quite a high kV (revs/ volt applied) so can run on less LiPos.
On 3S the current was 43A on a 10" x 6" wooden prop and 37A on a 9" x 7", but it is revving very high and a propeller is more efficient (creates less drag and so on) at lower revs, so I then tested it on 2S batteries and could then run a 12" x 8" wood prop with current drawn 38A.
This would be a more useful setup than having a small prop screaming in your ears, but the current is a little close to the 40A limit so you may wish to drop the prop pitch to x 7".
This was the ESC I tested it with...
http://www.giantcod.co.uk/speed-cont...-p-405366.html
When looking at ESCs the word OPTO refers to a decoupling system used in the unit and means that you will need to purchase a separate BEC if you use that sort of ESC. for 2S or 3S setups an integral BEC is fine. Only for 4S and above does the heat given off by the BEC system cause a real problem dictating an OPTO ESC.
As has been mentioned though, with these cheap items quality control is non-existant so you may just be unlucky and get a dud. I always figured at that price give it a try though - it's not a lot to lose if you do get a bad one.
Because this motor has a fairly high kV you can afford to have a higher capacity battery as it only has two cells...
http://www.giantcod.co.uk/loong-tipp...-p-404445.html
Hope this is helpful.
Have fun - and enjoy your shopping!
Old Sep 02, 2011, 09:49 AM
QTRPILOT is offline
Joined Sep 2011
Okay I did some testing with some weighs and the centre of gravity is too far back with a 70g motor.
The Turnigy G32 seems to be the best match so far. I can fit a 12x10 propeller with no problems. If I need a bit more power I can switch to a 4 cell battery, right?
Is the ESC I posted any good? Or should I go with a 60-70A esc rather than a 55A?
Sorry for all the questions, I know about glow engines but don't know anything about brushless.
Thanks for all the help so far!
Question Have a few drivetrain questions zanek Racing Boats - Electric 16 Aug 11, 2011 12:14 PM
Discussion Noob here, few questions joepwn Multirotor Talk 11 Jul 13, 2011 08:14 PM
Discussion my first rc. have a few questions ballpeen Car Talk 2 Jun 29, 2011 09:30 AM
Discussion New Heli Pilot w/CX3 have a few questions sgilbert Coaxial Helicopters 7 Mar 23, 2011 11:04 AM
Newbie Here... I Have a few questions ? UKANCALLMEBUBBA Fuel Plane Talk 13 Jan 14, 2006 10:51 AM
