Old May 24, 2015, 02:13 AM
rocketnz is offline
Find More Posts by rocketnz
Australia, NSW, North Bondi
Joined Apr 2013
Originally Posted by gbmarsh View Post
Okay, so you've never bound the rx that was in the J3 before?
Cheers,
Geoff
Yes many moons ago, but you can only have one bound at a time right?
rocketnz is offline Find More Posts by rocketnz
Old May 24, 2015, 02:29 AM
Kilrah is online now
Find More Posts by Kilrah
Happy FPV flyer
Kilrah's Avatar
Switzerland
Joined Sep 2006
No.
A receiver can only be bound to one transmitter, but you can have as many receivers bound to a same transmitter.
Would be unmanageable if you had to rebind everytime you flew a different model.
You may be use to / confusing with Spektrum's "model match" system. That's a different thing and isn't available on older FrSky equipment. The new X series have something equivalent, but only when using a supporting radio.
Kilrah is online now Find More Posts by Kilrah
Old May 24, 2015, 02:41 AM
rocketnz is offline
Joined Apr 2013
Weird because i have a v8 frsly reciever and that has to be rebound all the time
Old May 24, 2015, 05:40 AM
nigelsheffield is offline
Find More Posts by nigelsheffield
United Kingdom, Horbury
Joined Oct 2007
The d8 bind once to tx and stay bound , as long as you use d8 mode on tx then that RX will always be connected no matter what model on tx you select.
It can catch you out if you are not vigilant in selecting correct model.
Never used a v series but I would think they are the same and should not lose bind by themselves.
nigelsheffield is offline Find More Posts by nigelsheffield
Old May 24, 2015, 05:42 AM
rocketnz is offline
Joined Apr 2013
Amazing been using it for two years and never ever knew that.
Old May 25, 2015, 07:26 AM
phil_g is offline
Find More Posts by phil_g
Who let the dogs out?
phil_g's Avatar
Pontefract, Yorkshire, UK
Joined Jul 2007
Originally Posted by rocketnz View Post
I have a v8 frsky receiver and that has to be rebound all the time
Sounds like its processor has a faulty eeprom or possibly firmware corruption... they should never lose the bind even if unused for long periods. Personally I wouldnt fly it in that state, I would just keep it as a 'tester'
Cheers
Phil
phil_g is offline Find More Posts by phil_g
Old May 28, 2015, 05:24 AM
cofl10011 is offline
Find More Posts by cofl10011
Rchelistuff
Romania, AR, Arad
Joined Nov 2012
Could any of you please measure the voltage on the module pins(plugged) so at least I have a starting point?
Tx in advance
cofl10011 is offline Find More Posts by cofl10011
Old May 28, 2015, 05:56 AM
Daedalus66 is online now
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
With the transmitter on you should see battery voltage between pins 3and 4 (counting from the top).
Pin 1 is the PPM signal and will show a lower voltage.
The raised plastic round the pins needs to be pretty much completely removed, not just "shaved" if the module is to fit flush with the back of the transmitter and click in place. The pins don't have much length engaging the sockets in the module, so it has to be right down in there. Take a good look for anything that might be preventing the module from seating properly.
Daedalus66 is online now Find More Posts by Daedalus66
Mini-Review The video for FrSky 2.4Ghz Chase Wu Radios 0 Dec 16, 2009 01:18 AM
Discussion Realflight G5 Combat so far so good! splitpilot Simulators 0 Nov 22, 2009 06:36 AM
Discussion So far... So good rikks Mini Helis 35 Feb 17, 2006 12:42 PM
Aerofly Deluxe so far so good! Gary Morris Simulators 5 Aug 19, 2005 07:23 AM
Schulze 18.46K v7.02 - so far, so good! Jason M Electric Heli Talk 4 Aug 11, 2002 01:25 AM
