Old Jul 15, 2009, 03:14 PM
urov is offline
Find More Posts by urov
Joined May 2009
Idea
Big Solar Powered Flying Wing design
I am currently in the planing stages of a project of mine, A solar powered flying wing. The two atttachments show part of the plans as they are to this point.
If anyone has any suggestions (airfoil, modifications, changes, etc.) please feel free to edit the pictures and or describe them in a post.
The build will be somewhat lie the 14ft 4lb wing somewhere in the flying wing section of this forum (forgot the ling sorry)
-Ben
UPDATE in post number 6 i think
urov is offline Find More Posts by urov
Old Jul 15, 2009, 03:16 PM
fly_boy99 is offline
Find More Posts by fly_boy99
Flying motor mount master
fly_boy99's Avatar
San Jose, California, United States
For a solar powered wing which I believe will be backed up by a lipo (who wouldn't eh?). You need more sweep to the wing and optimize the airfoil to be the most efficient.
I'm currently working on something for a UAV application where I am interested in duration and not so much speed.
fly_boy99 is offline Find More Posts by fly_boy99
Old Jul 15, 2009, 03:26 PM
urov is offline
Joined May 2009
So I should make it more pointy? eg. larger chord? or smaller tip chord (i dont want to do that one)?
For the airfoil, I was thinking maybe a mjz 1211? maybe a little modified to suit my needs.
haha, yes it will be backed by lipos
P.S. I too am more interested in duration than speed (UAV is a planned option for this aircraft)
Old Jul 15, 2009, 03:55 PM
urov is offline
Joined May 2009
by the way, what does the sweep do? -Never understood that...
Oh and also b4 I forget, the wing has a body i the center, which is about 40cm longer than then wing and that will hold the motor.
Propeller used will be 24"x12" folding prop.
Old Jul 15, 2009, 09:10 PM
djacob7 is offline
Find More Posts by djacob7
Knife cuts foam like its steel
United States, CA, Fremont
Joined Jan 2009
I understand that sweep provides yaw stability.
If the wing turns a bit to the right, let's say, then the left side will project more area to the relative wind than the right and that will turn the wing back to the left.
Just my .02 worth.
djacob7 is offline Find More Posts by djacob7
Old Jul 15, 2009, 09:26 PM
urov is offline
Joined May 2009
Alright, so ive done another one now with some sweep
Old Jul 15, 2009, 10:48 PM
djacob7 is offline
Joined Jan 2009
That TE sweep will also help point the nose down instead of using more weight to do so.
Old Jul 16, 2009, 08:45 AM
frednjess is offline
Find More Posts by frednjess
That Guy Who Flies Wings.
La Vista, Nebraska
Joined Mar 2007
Check out my monster. It's almost 2400 in^2, 8' wide and flies like a champ! Sounds like a great project! Good luck!
http://www.rcgroups.com/forums/showthread.php?t=998356
frednjess is offline Find More Posts by frednjess
Old Jul 20, 2009, 02:26 AM
urov is offline
Joined May 2009
UPDATE:
As of now, the plane has bee growing ad growing on the plan.
Current specs: (not to be extended anymore)
Span: 750cm
center chord: 180cm
tip chord: 135cm
Area: 11.8 m^2
Estimated final weight: 10kg (22lb)
Estimated Wing loading: 8g/dm^2 (2.779 oz/ft^2)
featuring 2 hacker A30-10L outrunners geared to either 4:1 or 5:1 (gottta see my end voltage (either 14 or 17V) powering 2 24"x12" folding props
Estimated max thrust: (combined) 5800g at full power pulling 45A (solar array capable of 50A)
Also on board: 3500g Depron (3mm) with carbon reinforcements; 2real time cams on pan and tilt (main with OSD), the other one following a digicam-also on pan and tilt); 2 Lipo batteries and 1 nicd receiver pack (6V)
What is the minimum power per pound again? -rule of thumb always escapes me... was it somethig like 50W per pound? If I am correct on this one, then to drive this plane 1000W would be neccesary, whilst only 400-500 are available. that would give me 25W per pound. I think due to the low speeds and wing loading, it should be possible to go with way less than 25W per lb right?
I the attached PDF are all the numbvers Ive been throwing together (amperages, weights etc) and some explanations including a (unfinished) plan.
The Airfoil will be a KFm 3 with 12% (thats 200 and something mm )
Now, I will only need some more money, and I should be good to go. (i think about 2000 to 2500 bucks will be necessary )
Once I start, I will post pictures and a building blog
-Ben
P.S. Did I mention that accorfig to NASAs FoilSim this plane would be capable of flying over 49500ft????? lol anyone done that b4? kidding aside, do you have to file a flight plan for that????
Old Jan 07, 2015, 09:25 AM
Omega8 is offline
Find More Posts by Omega8
Joined Jan 2013
Hi Urov,
Whatever happened to your solar project? Could you please post some pics? I Just started on a similar project and would love to know what you did. Thanks.
Omega8 is offline Find More Posts by Omega8
Light wind flying wing design help needed Skid_Mark Sailplane Talk 3 Jun 20, 2003 07:27 AM
Flying Wing Design Questions fritts Power Systems 9 Mar 26, 2002 08:19 PM
Flying Wing Design Questions fritts Parkflyers 0 Mar 18, 2002 01:27 PM
flying wing design bklein Foamies (Kits) 12 Feb 11, 2002 06:12 PM
