Old Feb 20, 2009, 05:12 PM
Nederlander is offline
Find More Posts by Nederlander
Joined Feb 2009
DeWalt 24V Gearbox Build
I recently ordered the 24VDC DeWalt hammerdrill motor as seen on at least one robotics site. Their specs show it at 2HP and 20K rpm free. I ordered mine from a local tool repair service on Monday and had it on my doorstep Tuesday. With tax and shipping it came to $71.80. Since this will be used on a fully submerged prop I am designing around a 2:1 reduction box. The press fit gear on the shaft was determined to be a 32 Dia pitch, 14 1/2 degree gear. Going to my favorite supplier of gears with whom I've had a relationship going back a good fifteen years, Stock Drive Products, I found a brass gear with hub #A 1B 2-N32040 of 40 teeth with a 1/4inch bore. The motor gear is 19 teeth. This will give just over the desired ratio. The shaft will be here by the end of the week and the bearings will come from Boca. I will report back with photos and such when the project is complete.
Nederlander is offline Find More Posts by Nederlander
Old Feb 20, 2009, 11:39 PM
Amp Abuser is offline
Find More Posts by Amp Abuser
Amp Abuser's Avatar
Joined Dec 2007
What are you going to use the motor in? Prop size and such.
Here are the spec's for this motor.
DeWalt Part Number 389010-00
Voltage 24vdc (can be overvolted)
Nominal Torque 94.5 in-lbs
Torque at stall 192 in-lbs
Torque Constant: 1.5 ozf-in/Amp
No-load Current: 2.6 Amps
Nominal Amperage 68 Amps
Stall Current: 190 Amps
RPM 21,000 ungeared
Angular-velocity Constant 880 RPM/v
Output gear 19 Teeth
Gearbox BPDGFGD24
Size 4.8" long x 2.25" dia
Weight 25.60oz or 1.600 Lbs
Armature Resistance: 0.095 Ohms
Peak Power: 2 HP
Peak Effeciency: 81%
$57.99
http://www.robotmarketplace.com/prod..._ungeared.html
Amp Abuser is offline Find More Posts by Amp Abuser
Old Feb 21, 2009, 03:01 AM
Joined Feb 2009
"What are you going to use the motor in? Prop size and such."
Building a 1/6th scale Baby Bootlegger. Haven't determined prop size yet as I didn't realize the Prop Shop had gone under and I haven't had time to research all of the new prop manufacturers.
Discussion need help with gearbox build horatio Ornithopters 0 Aug 12, 2008 11:01 PM
Sold Dewalt 36v packs, build kits snaggle213 Aircraft - Electric - Batteries & Chargers (FS/W) 4 Mar 09, 2008 04:41 PM
