Old Mar 02, 2003, 03:53 PM
Don Leitz is offline
Find More Posts by Don Leitz
West Chester, OH USA
Joined Jan 2000
HS-81 vs Hs-85 current draw?
Hi All,
I am finishing up a Waco Bipe that I have had laying around for awhile. I will be using a Kontronic Easy 4000 ESC with 10 cells powering four servos. I have used this ESC in other 10 cell/4 servo applications with good results using HS-81 or HS-55 servos. I had intended to use HS-81 servos all around on this plane, but discovered that I was one servo short. However, I do have a HS-85 servo from a deceased plane that I could use. My concern is that since this is a higher torque servo that is basically the same size as an HS-81, I suspect that it will draw more current. The specs on Hitec's website don't include any current draws, so I'm wondering if anyone knows if indeed the HS-85s draw more current (in which case I'll buy another HS-81), or not.
TIA,
Don
Don Leitz is offline Find More Posts by Don Leitz
Old Mar 03, 2003, 03:40 AM
Wright Flyer is offline
Find More Posts by Wright Flyer
(aka Cliff Lawson)
Wright Flyer's Avatar
United Kingdom, Essex
Joined Oct 2001
Just a thought but rather than buying another servo you could get a uBEC for around the same amount - it's a battery eliminator that operates separate from your ESC and has a MUCH higher current sourcing ability than the low spec BEC circuit in most ESC's. Obviously the more cells you have the harder a BEC has to work and at 10 cells a uBEC could be the safe choice (it's often used in e-helis where there are LOADS of cells and also loads of 4.8V electronics to be powered).
Cliff
Wright Flyer is offline Find More Posts by Wright Flyer
Old Mar 03, 2003, 05:08 AM
Haldor is offline
Find More Posts by Haldor
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
The HS85 has higher torque but this comes from longer transition time, not more input power. I'd say they consume about the same.
Haldor is offline Find More Posts by Haldor
Old Mar 03, 2003, 02:19 PM
Joined Jan 2000
Cliff,
The UBEC is intriquing. I do intend to buy a couple of them to replace RX packs in a 14 cell and 16 cell plane. I hate having to remember to charge the RX packs the night before flying.
Haldor,
I checked the Hitec website again, and you are right - the HS-85 is slower. Given that information, I think I'll be alright to leave the HS-85 installed. BTW - I was wrong about the model of ESC - it's a Sun 4000, not the older Easy 4000. I believe the BEC capacity was upgraded in the Sun ESCs. Thanks for your help.
Regards,
Don
Old Sep 16, 2003, 10:58 AM
Kevin Murray is offline
Find More Posts by Kevin Murray
Kevin Murray's Avatar
USA, NC, Greenville
Joined Dec 1999
servocity.com lists the idle and stalled draw in all of the HiTec servos. In the spec part on each servo's page.
Kevin Murray is offline Find More Posts by Kevin Murray
Case size of hs-81 vs hs-85 windsox Slope 18 Nov 03, 2004 09:35 AM
HS-56 current draw PGR Hitec/Multiplex USA 1 Aug 19, 2004 02:16 PM
Current draw on the Hitec HS-81 servos. larsen2000 Electric Heli Talk 1 Aug 03, 2004 06:03 PM
FS: 2 hs 85 BB's, 2 HS 81 MG's foss1997 Aircraft - Electric - Airplanes (FS/W) 2 Jul 31, 2003 04:52 PM
Current draw on Hitec HS-50 Servos Stormbringer Electric Plane Talk 4 Apr 22, 2001 10:31 PM
