Old Jan 25, 2016, 09:11 AM
jackerbes is offline
Find More Posts by jackerbes
Jack
USA, ME, Ellsworth
Joined May 2008
The moderators here have refused to make the following thread a sticky thread, they seem to think that we Blu Baby 33/KFm wing/Tony65x55 aficianados are not deserving of that. So a couple of the regulars have gathered up the info and made a thread that contains just about every link anyone would ever want about those things:
** Tony65x55 ** planes and plans. - www.rcgroups.com/forums/showthread.php?t=997484
And post #5 in that thread has an list of a few of the power systems used on the BB 33, and as you read through the thread, you'll find other have posted the details of their power systems. :
Blu-Baby Motor/ESC/Prop Combos - www.rcgroups.com/forums/showthread.php?t=997484
Many of the newer builders here have not added the details of their power systems to that thread. If any of them should read this consider it a polite request to help the newbies here out by posting a brief list of their power system components for the various builds to that thread.
This is a quick and easy way to add it is a post with this info:
BB 33 (or whatever build it was) and wing type
Motor:
ESC:
Prop:
If you want to flesh it out you can include any or all of the following bits of info:
AUW at maiden:
Power System Details
Motor:
Kv:
Weight of motor:
Battery: (cell count and capacity)
Prop:
ESC:
Electronics
TX:
RX:
Servos:
And thanks in advance for the help if you do that!
Jack
jackerbes is offline Find More Posts by jackerbes
Old Jan 25, 2016, 11:59 AM
JohnsPop is offline
Find More Posts by JohnsPop
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
Jim_W, where does your plane balance with the battery that far forward? If it balances in the right spot, you might want to check the incidence of your wing and your horizontal stab. Maybe one of those is a little out of wack making it fly funny and not being actually tail heavy. Just a thought. Looks good!
JohnsPop is offline Find More Posts by JohnsPop
Old Jan 25, 2016, 12:00 PM
JohnsPop is offline
JohnsPop's Avatar
LaGrange, GA
Joined Jun 2009
And the rest of us GREATLY appreciate y'all doing that and all the great support y'all give to everyone asking questions here!
Old Jan 25, 2016, 06:24 PM
Jim_W is offline
Find More Posts by Jim_W
Jim
North Alabama
Joined Mar 2004
You could be right as it is difficult (for me) to get incidence spot on with my scratch building skillz!
It balances in the same place all my other BB's have CG'd, at the highest point of the airfoil or about 1/3rd the chord from the LE.
Also, I'm satisfied that this green foam wing is "shapeshifting" due to its lack of rigidity!
I'm gonna give it another flight or two if the weather ever cooperates again. I've cut another slot in the fuse for the battery and it's as close as I can get it regarding CG. If it still acts crazy I'll cut my losses and move along.
Jim_W is offline Find More Posts by Jim_W
Old Jan 27, 2016, 12:16 PM
springer is offline
Find More Posts by springer
treefinder
springer's Avatar
SE MI
Finally got a low wind and snow day! had to get the latest BB42 out for video: here's the result, she's a floater!
BluBaby42 v (2 min 51 sec)
springer is offline Find More Posts by springer
Old Jan 27, 2016, 12:30 PM
Jim_W is offline
Jim
North Alabama
Joined Mar 2004
https://vimeo.com/153261793
Nice job! Flies great! Which wing? UC, KFM ????
Old Jan 27, 2016, 12:31 PM
bz1mcr is offline
Find More Posts by bz1mcr
AKA Don
United States, FL, Naples
Joined Dec 2002
Very nice video Mike. And, nice flying!
bz1mcr is offline Find More Posts by bz1mcr
Old Jan 27, 2016, 12:37 PM
springer is offline
treefinder
springer's Avatar
SE MI
Thanks guys. The wing is KFM5a, Undercambered with fwd 40% double thickness. It has a 1/4" spar at the step on bottom, and another spar at the LE that is sanded to form the airfoil curves. I have heard several times that Undercambered wings don't like ailerons, but this guy handles the two features just fine.
Old Jan 27, 2016, 01:49 PM
Yachtie04 is offline
Find More Posts by Yachtie04
Australia, QLD, Waterford West
Joined Jun 2014
Looks like your new BB is flying very nicely. Congratualtions on a successful flight!
Don't go hanging it up in one of those trees there though!
Yachtie04 is offline Find More Posts by Yachtie04
Old Feb 22, 2016, 11:32 AM
zukiguy is offline
Find More Posts by zukiguy
Joined Nov 2015
I built a 33" last night after finding some suitable 1/2" thick foam at Dollar Tree. The blue section is made up a 'kneeling pad' and the rest is plain DTF. I added a bamboo skewer spar just in case.
zukiguy is offline Find More Posts by zukiguy
Old Feb 22, 2016, 12:17 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Looks like it has a chance to fly! What is the AUW and the power system?
Jack
Old Feb 22, 2016, 04:34 PM
zukiguy is offline
Joined Nov 2015
About 7-8 Oz. without the battery, waiting for a new lipo to come in, hobbyking says they weigh 80 grams (under 3 oz) so probably 11-12 oz total.
Motor is a turnigy park 250, rated for 8 amps at 2s voltage, I'm guessing less than 50 watts without any measuring equipment and a 7x4 apc prop. Esc is a turnigy plush 10 amp. Battery will be a 1300 amp 2s zippy flight max.
Old Feb 22, 2016, 04:43 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Sounds like everything is on track for a smooth maiden. Good luck with it!
Jack
Old Feb 28, 2016, 02:56 PM
ourbluehorizon is offline
Find More Posts by ourbluehorizon
UK, Ballymena, Ballymena
Joined Aug 2008
24 inch
Called mine the Micro Cub AUW 64 grams,
3 mm depron
1s lipo 200 mah
Receiver and servo brick http://www.banggood.com/WLtoys-F929-...-p-930768.html
Prop http://www.banggood.com/WLtoys-F929-...-p-947009.html
Motor http://www.banggood.com/WLtoys-F929-...-p-930767.html
Radio is the taranis with the module
Video
Micro Cub (2 min 51 sec)
ourbluehorizon is offline Find More Posts by ourbluehorizon
Old Feb 28, 2016, 03:28 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Congrats on the successful build and maiden!
It looks like it was pretty windy and gusting as you flew, is that not so? From that long period of hovering as 2:00 to 2:30 or so, it looked like the flight speed was matched to the head wind. That gave a good long close up of it.
And I think you got away with a cross wind launch at the start too.
Congrats again!
Jack
Video Blu-Baby Primary Trainer Tony65x55 Electric Plane Talk 0 May 05, 2007 06:05 AM
Chosing Trainer...Kit?Plans?RTF? Seared Ice Fuel Plane Talk 49 Aug 16, 2004 11:50 AM
Which SPAD Trainer to build?? Plans? VBSuperMaxx SPAD - Simple Plastic Airplane Designs 12 May 05, 2004 09:19 PM
Sold FS: Fireball 550 Trainer "PLANS" Rudderman98 Aircraft - Electric - Airplanes (FS/W) 4 Dec 05, 2002 07:38 PM
