Old Dec 01, 2005, 03:55 PM
jfcgnv is offline
Find More Posts by jfcgnv
Gainesville Fl.
Joined Mar 2003
Tiny motors
I have a small coreless motor from MTM in Germany it is 22 mm long and has a dia. of 16 mm. Two wires coming out of the back. It was the motor from their Colbrini power system. A great littly motor and gear box, my problem is I need a replacement motor and MTM is no longer in business. Does anyone know if I can get a replacement motor and where?
John C
jfcgnv is offline Find More Posts by jfcgnv
Old Dec 01, 2005, 04:32 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
That's a DC5-2.4 motor, made by CIK in Japan I think. I have one of the same propulsion sets. Mike had a nice CNC machined adapter made up that adapted a Maxon planetary 4:1 gearbox to this motor. See the Micro Threads index which has a link to a thread on the DC5-2.4 and Firefly motors.
Anyway, you can buy the motor from Dave Lewis (in Florida like you) at www.homefly.com for $27. It's listed under "motors". WES in Germany and Sky Hooks and Rigging in Canada also have them, but shipping would be considerable. Dave has free shipping if the order is over $50, or $2 if less than $50, and he's right near you.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
Old Dec 01, 2005, 05:45 PM
jfcgnv is offline
Gainesville Fl.
Joined Mar 2003
Gordon, Thanks for the quick reply. I have done business both with Sky hooks and With Homefly. The DC5-2.4 motor is smaller than the one I need replaced. It measures 18mm X 10 mm I need 22mm X 16 mm. I think the DC5-2.4 motor is low voltage ( around 3 volts Max). The motor I need is 6 to 9 volts.
I agree the little adapter and gear box from MTM is a great little jewel. All i need now is to find a motor to use. The DC5-2.4 looks like the adapter will fit, however I am worried about the power output and voltage. I don't want to burn up another one. Using three Lipo's resulted in my delima. The little motor ran fine on two.
John C
Old Dec 01, 2005, 06:58 PM
Boston, Mass
Joined May 2001
Did you find the thread on these motors?
http://www.rcgroups.com/forums/showt...hreadid=125589
Since you said you have a Kolibri from MTM I did not check the dimensions that you posted versus the DC5-2.4. You might look at the picture in the above thread. When I ordered the Kolibri from Mike that's what I got, and it is a DC5-2.4. If yours has different dimensions it might be some variation from Mike that I didn't know about.
Gordon
Old Dec 01, 2005, 08:04 PM
jfcgnv is offline
Gainesville Fl.
Joined Mar 2003
I will order a DC5-2.4 and let you know if it fits my gearbox. After reading the thread it seems that 7.4 volts and 1 amp is ideal.
John
Old Dec 05, 2005, 07:15 PM
jfcgnv is offline
Gainesville Fl.
Joined Mar 2003
Gordon, I got my new DC5 2.4 motors from Dave at Homefly today. You are correct it is a DC5 2.4 that Was on the colbrini from MTM. All I have to do now is pull the pinion gear from my bad motors shaft. I guess my next purchase will be a gear puller. Do you have a scorce for the motor pinion? It is really a small buger.
John C
For Sale Mikes Tiny Motors sckow Aircraft - Electric - Power Systems (FS/W) 0 Jun 03, 2006 10:20 PM
Discussion Tiny motors using 14mm Stators from Colorado/Travan Tape Drives evdo Electric Motor Design and Construction 21 May 04, 2006 12:36 PM
4 tiny motors for RFFS-100??? phuffstatler Scratchbuilt Indoor and Micro Models 1 Apr 24, 2003 04:39 PM
Know anything about tiny motors? Help! Monouk Scratchbuilt Indoor and Micro Models 1 Mar 07, 2003 09:08 PM
