Old Jun 05, 2005, 11:57 PM
tridim is offline
Find More Posts by tridim
tridim's Avatar
Denver, CO
Joined Jan 2005
Oops.. I broke my Twist in half today.
Yep, I was flying cocky, low and fast.. I flew it into the ground trying to avoid a steel soccer goal. Oh well, I guess it happens to all of us eventually.
The wing popped off by design and didn't get a scratch. The only major damage is the fuse snapped right behind the canopy. I understand this is a common weak point in the Twist.
I've already epoxied it back together at the break. I'm just wondering if anyone has any repair tips for more strength because I don't trust epoxy alone. I'm thinking of screwing in some aluminum plates at the weak spots, behind the wing and canopy. Is fiberglass a good option? Adding an ounce or two isn't going to kill me. I need a bit more aft weight anyway.
Thanks.
tridim is offline Find More Posts by tridim
Old Jun 06, 2005, 07:43 AM
Bako is offline
Find More Posts by Bako
BAKO
Bako's Avatar
Tbilisi, Georgia
Joined Jul 2004
u need to take 3mm balsa sheet and use some CA to put this sheet on fuselage(where it was damaged) from inside. this helps. I made such thing and this place becames more strong, that other fuselage plzce. no need to use epoxy.
Bako is offline Find More Posts by Bako
Old Jun 07, 2005, 04:45 AM
Tomcat_CT is offline
Find More Posts by Tomcat_CT
Romania, Constantza
Joined Feb 2005
Bako is right.
I did this with an electric glider in which I snaped the whole front end thet comes before the leading edge of the wing.I used 1mm ply to fix it.
Eventually, if the fix isn't strong enough, you could ad someting under the airframe where it broke.You would get someting looking like an "U".
Tomcat_CT is offline Find More Posts by Tomcat_CT
Old Jun 07, 2005, 01:47 PM
tridim is offline
tridim's Avatar
Denver, CO
Joined Jan 2005
The reason I'm thinking of using aluminum is because the joints in question are butt joints. Simply two balsa sheet parts joined at the edges.. The only thing holding it together is a bead of glue (used to be hot glue, now epoxy). It seems really weak to me, and is not really span-able by wood reinforcements because the joints are at an angle. I can certainly beef up the normal joints with balsa gussets, but not the butt joints.
Old Jun 07, 2005, 01:59 PM
Bako is offline
BAKO
Bako's Avatar
Tbilisi, Georgia
Joined Jul 2004
what about fiberglass? maby it's best solution?
Old Jun 07, 2005, 04:14 PM
Trogdor is offline
Find More Posts by Trogdor
ElectriGlo Pilot
Trogdor's Avatar
Ashburn, Virginia, United States
Joined Dec 2003
When I ripped out my landing gear on a deadstick, I just fit the parts back after peeling off the covering around the wound. I then put on some 20min finishing epoxy (the runny stuff) over everything and laid some fiberglass tape (medium weight I think) over it on both sides.. Very strong and not so much weight. I've pancaked it good a few times since and totally bent the LG flat but its held up.
Trogdor is offline Find More Posts by Trogdor
Old Jun 07, 2005, 10:28 PM
tridim is offline
tridim's Avatar
Denver, CO
Joined Jan 2005
I did the same thing a few months ago and made the landing gear mod right afterwards. I've never used fiberglass just because I haven't had the need. I guess I should pick some up and give it a shot.
Old Jun 07, 2005, 11:03 PM
LuckyArmpit is offline
Find More Posts by LuckyArmpit
Rehab is for quitters
LuckyArmpit's Avatar
West Middlesex, PA, US
Joined Jun 2001
Use 30 minute epoxy thinned with denatured alcohol. Soak your piece of fiberglas in the epoxy and then apply to the affected area. I have done this
on my U Can Do's main gear (on the inside of the fuse) which would be the greatest load bearing point especially on landings. Aint broke yet.
Dave...
LuckyArmpit is offline Find More Posts by LuckyArmpit
Old Jun 08, 2005, 02:00 PM
R/C Flier268 is offline
Find More Posts by R/C Flier268
Joined Jun 2004
They all come with deah certificates the only question is who signs em'
R/C Flier268 is offline Find More Posts by R/C Flier268
Discussion Crashed My Plane In Lake today! Ultra Mini Stick On Floats - Pointers Anyone? djdaveq Electric Plane Talk 19 Oct 23, 2007 12:13 PM
Discussion Broke in my first RCV engine today desmobob Engines 5 Apr 22, 2006 03:06 PM
Sawed my Beaver in half today and put it out of it's misery! millerhill Parkflyers 27 Jul 28, 2005 10:33 PM
Just got my heli in the mail today.. night_flight Micro Helis 2 Feb 27, 2004 12:15 AM
Check out what happened to my Brushless in the air today!! Eco8gator Electric Heli Talk 4 Feb 24, 2002 02:52 PM
