Old Aug 20, 2015, 11:23 AM
crasher47 is offline
Find More Posts by crasher47
Joined Mar 2013
One way clutch kaput
Crashed my 550L a few weeks ago. Now all the one way clutch does is free spool. It won't grab. Took it apart and can't see any damage. What happens to these things?
crasher47 is offline Find More Posts by crasher47
Old Aug 20, 2015, 11:34 AM
JetPlaneFlyer is online now
Grumpy old git.. Who me?
JetPlaneFlyer's Avatar
Aberdeen
Joined Mar 2006
Often it's not the one-way bearing as such, the bearing can break free and spin in the housing. I had exactly this happen to my Trex 600 pro which I pretty sure uses the same one way bearing and same housing. Green Loctite should be used to fix it in place .
If it is the bearing I guess it's possible that the ramps or rollers got damaged. You can usually tell by turning the bearing by hand if it's working ok.
JetPlaneFlyer is online now Find More Posts by JetPlaneFlyer
Old Aug 20, 2015, 12:28 PM
Joined Mar 2013
Thanks, JPF. I took it apart and I guess the rollers must be damaged. It feels as though there may be slightly too much clearance between the flanged sleeve and the roller assembly. The roller assembly is snug in the housing. I guess I'll order a new roller assembly.
Sold [SOLD] - Align One-way 8mm/10mm one way tool Wynn1427 Aircraft - Electric - Helis (FS/W) 0 Aug 16, 2015 11:23 PM
One way clutch for Corona Orion_V Electric Heli Talk 7 Jul 16, 2003 05:37 PM
Corona One Way Clutch For Sale Hivoltage Aircraft - Electric - Airplanes (FS/W) 1 Mar 10, 2003 08:47 PM
Corona One Way Clutch Upgrade Hivoltage Electric Heli Talk 5 Mar 10, 2003 01:39 PM
"NEW" MS Composit Hornet One-Way Clutch In Stock Now Tailrtr Electric Heli Talk 0 Sep 28, 2002 11:51 PM
