Old Dec 31, 2015, 10:54 PM
viperviper is offline
Find More Posts by viperviper
Antarctica
Joined Apr 2012
Originally Posted by Robert Belluomini View Post
Added a photo
you zip tie it? And your esc wiring is enough to reach the fan motor wires? any extension?
viperviper is offline Find More Posts by viperviper
Old Jan 01, 2016, 12:27 AM
Robert Belluomini is offline
Find More Posts by Robert Belluomini
EDF Jet Jam 2016, June 16 -19
Robert Belluomini's Avatar
United States, KY, Crestview Hills
Joined Dec 2000
No i mount it using the rubber mounts and yes i extend the leads between the esc and motor
Robert Belluomini is offline Find More Posts by Robert Belluomini
Old Jan 01, 2016, 12:28 AM
Antarctica
Joined Apr 2012
thanks Robert!
Old Jan 25, 2016, 12:04 AM
NR11 pete is offline
Find More Posts by NR11 pete
pete05
sydney australia
Joined Apr 2006
Has anyone modified the steering for the nose wheel, I have the version 3 and find the retracting action very unreliable.
NR11 pete is offline Find More Posts by NR11 pete
Old Jan 25, 2016, 12:08 AM
mhendrix is offline
Find More Posts by mhendrix
In thrust we trust.
mhendrix's Avatar
United States, FL, Tallahassee
Joined Jun 2013
You can make geometric adjustments to the horn/linkage if necessary. If the wheel isn't straight as it goes up, it will bind. For that reason (and independent steering trim) I have the steering on its own 8th channel that as soon as I flick the retract switch it disables the steering/rudder mix and centers it. Smooth sailing ever since. Good luck!
mhendrix is offline Find More Posts by mhendrix
Old Jan 25, 2016, 04:33 AM
pete05
sydney australia
Joined Apr 2006
I have moved the steering servo to the 7th channel and added a mix but it seems the link rod between the servo and the strut is to short to allow correct operation.
Old Jan 25, 2016, 06:47 AM
Joined Dec 2000
I have the Z bend on the servo arm going through the arm from top side. This helped to provide spacing between the steering arm and linkage.
The spring plate plays an important role when the gear cycles so check it too.
Here are the pics.
Old Jan 25, 2016, 05:16 PM
pete05
sydney australia
Joined Apr 2006
Thanks Robert I have mine set up the same, I see you have removed the retract door like me, I could never get it to close properly. When your nose wheel is down and straight is your servo horn at 90 deg to the servo? My link is not long enough to allow the servo horn to be at 90 deg.
Old Jan 25, 2016, 09:43 PM
Joined Dec 2000
No the arm is slightly forward
Discussion New 90mm Viper Jet Chris True Electric Ducted Fan Jet Talk 20 Nov 18, 2014 01:33 PM
Build Log FOAM Viper Jet MK2 with 90mm 12 blade EDF (made by Ysnk) ysnk Scratchbuilt EDFs 16 Sep 25, 2012 03:40 PM
Discussion Viper jet 90mm from hk balone10 Electric Ducted Fan Jet Talk 2 Mar 09, 2012 06:57 PM
