Old Dec 02, 2012, 04:30 PM
LexusFPV is offline
Find More Posts by LexusFPV
TBS Crossfire or DragonLink?
Joined Feb 2011
Thanks for the those LINKS Stone1295
That first LINK you posted, that plane is over $~5,000++++
I'm looking for something more Hobby friendly, Hobby oriented....
That plane looks great, ....Great find!
If only I can make it from Scratch made
http://www.troybuiltmodels.com/items/PTERYX-UAV.html
Pteryx UAV assembly in winter (3 min 58 sec)
LexusFPV is offline Find More Posts by LexusFPV
Old Dec 02, 2012, 05:00 PM
Stone1295 is offline
Find More Posts by Stone1295
AMA 937634
Stone1295's Avatar
United States, AK, Anchorage
Joined Jan 2010
Yeah way too expensive but they're selling a complete aerial mapping solution complete with a parachute option!
-Mike
Stone1295 is offline Find More Posts by Stone1295
Old Dec 02, 2012, 05:04 PM
LexusFPV is offline
Joined Feb 2011
Do they sell just the PLANE itself?
I sort of like that Chile StarDust on their website....
Old Dec 02, 2012, 05:27 PM
AMA 937634
Stone1295's Avatar
Joined Jan 2010
I haven't found that anybody sells that particular plane. I've seen some photos of some students in Russia that were making a similar plane though.
If it's a good design it's bound to have been copied a couple of times. Somebody has one for sale someplace.
-Mike
Old Dec 02, 2012, 08:32 PM
Nodd is offline
Find More Posts by Nodd
Build something.
Nodd's Avatar
United States, CT, Fairfield
Joined Mar 2012
I still say you should have a go at building one. Lets take another look at one of the planes you first posted...
Here's how you could put together something similar...
Head to your local hobby shop & pick up some light plywood, maybe hit a hardware store for some foam board & a bottle of Gorilla Glue & you're in business. If you don't want to get involved in building a tail, maybe find some old beat up plane. Hack off the nose then sandwich the donor fuselage/tail between the plywood of your FPV pod, lots of glue & presto, you have a custom FPV fuselage.
Nodd is offline Find More Posts by Nodd
Old Dec 03, 2012, 09:08 AM
LexusFPV is offline
Joined Feb 2011
Wow!
Thank you soooooo MUCH Nodd
Looks sooooo easy NOW!!!!!!!!!!!!!!!!!!
Old Dec 07, 2012, 08:24 PM
LexusFPV is offline
Joined Feb 2011
Nodd,
any ideas on how to put Wings on?
If nylon screws are used, that would be great!
I hate rubber bands...they are never tight enough!
Old Dec 07, 2012, 10:41 PM
ddruck is offline
Find More Posts by ddruck
ddruck's Avatar
Canada, ON, Pickering
Joined Nov 2006
I have been watching the development of this plane from the start. It was designed by a kid in Russia, called Sodefi, he is quite a pro in molding carbon fiber...don't quite know if and how he is connected to the commercial company which seems to use his design. Just Google 'elf mini fpv', you will get many hits to look at, there is a video on YouTube showing him molding the fuse pod, test flights..
Dan
Originally Posted by LexusFPV View Post
http://www.rcgroups.com/forums/showthread.php?t=1772167
(double post).
Just wondering who makes these types of gliders for Aerial Photo flying
I really like the glider open front with tractor style prop.
Thank You....
ddruck is offline Find More Posts by ddruck
Old Dec 07, 2012, 11:22 PM
ddruck is offline
ddruck's Avatar
Joined Nov 2006
Much simpler, home made, version of this type would be like this one:
Šarka FPV plane (1 min 30 sec)
Here is a huge thread on building something very similar but simple.
http://www.rcgroups.com/forums/showt...t=881734&pp=50
Old Dec 07, 2012, 11:56 PM
Nodd is offline
Build something.
Nodd's Avatar
Joined Mar 2012
Nodd,
Rubber bands would be the simplest, just stick some dowels through the sides & you're done.
Nylon bolts would need something sturdy to mount to. I'd drill a hole in a couple of small blocks of wood. Stick a blind-nut in there then glue to blocks between the fuselage's plywood sides, one at the LE, another at the TE. Drill holes in the wing then thread in the bolts...
Same deal for mounting the motor & the FPV gear. Just bridge the space between the two plywood sides with wood wherever you need a hard-point.
Old Dec 09, 2012, 12:18 PM
rclab1 is offline
Find More Posts by rclab1
USA: LakeGeorge, New York
USA
Joined May 2010
thats a lot of money for just the plane built....
I guess its worth it if you like it that much.
rclab1 is offline Find More Posts by rclab1
For Sale 60 inch glider not sure who makes this LPU ED3 Aircraft - Sailplanes (FS/W) 3 Aug 30, 2012 04:19 PM
For Sale 60 inch glider not sure who makes this LPU ED3 Aircraft - Electric - Airplanes (FS/W) 1 Aug 26, 2012 03:02 AM
Question Who makes this glider? ((PICS)) Autotechwagon Sailplane Talk 12 Feb 21, 2012 01:03 PM
For Sale sloper glider not sure who makes this, can u help?? ED3 Aircraft - Sailplanes (FS/W) 19 Oct 07, 2010 04:06 PM
Can anyone tell me who makes this glider? macr Electric Sailplanes 5 Nov 01, 2004 04:47 AM
