Old Apr 01, 2015, 05:31 PM
larry baraniuk is offline
Find More Posts by larry baraniuk
Banff Alberta Canada
Joined Nov 2004
Weight Comparison
Here's a comparison of the weight of the lead ballast ,motor , speed controller. and excess metal that has a total weight of 5.00 ounces that will be replaced by the higher powered motor and 30 Amp ESC that has a total weight of 5.05 ounces.
The stock 3 cell 1300 mah battery is only 10 C that weighs 3.8 ounces and will be replaced by a 30 C - 3 cell 1300 mah battery weighing 3.9 oz. The motor and speed contoller upgrade cost $ 40 (including shipping).
larry baraniuk is offline Find More Posts by larry baraniuk
Old Apr 05, 2015, 11:20 PM
Joined Nov 2004
Upgrade completed and Flies Very Well
The AUW is 33.25 ounces.
I glassed the main wing and put on 2 1/4" Du - Bro wheels.
With an 8 X 3.8 sf prop , I'm drawing 26 amps on a 3 cell , 1300 mah 30 C battery.
My E- meter showed 260 watts output.
My test flight lasted 5 minutes , mostly in cruise mode half throttle and a short burst of full throttle to perform a hammerhead maneuver.
The total flight used up 940 mah.
I'm very satisfied with the results.
Hope to get many flights out of this plane.
Old Apr 06, 2015, 07:59 AM
Rem Fodder is online now
Find More Posts by Rem Fodder
Radio-active flyer
Rem Fodder's Avatar
Canada, ON, Port Hope
Joined Apr 2012
If I can give you a little tip, the landing gear wire will pop out of the plastic fairings with a hard landing and bend the wire up. Using some very fine wire, I use wire sold for fly tying from a tackle store, lace the gear wire to the plastic fairing. Works wonders, I posted a photo someways back in the thread. I'm up way over 350 flights on my old Cub. Now she is on floats permanently. I still like to fly to fly it occasionally, its a fun little aircraft and for the most part is pretty docile. Just keep the speed up during low altitude turns as it will tip stall in the original configuration without any wing washout. A 9" prop will also give a much needed thrust boost, the ground clearance is sufficient with the larger wheels for a bigger prop. I use a 10 x 5 for float flying. Even with that prop, the 1500 mah packs can give a 10 minute flight with capacity to spare. Have fun!
Rem Fodder is online now Find More Posts by Rem Fodder
Old Apr 06, 2015, 10:54 AM
Joined Nov 2004
That's great advice, Thanks! My .46 size Hangar 9 Cub has tip stall characteristics also , so I'm used to watching out for that.
I might add some washout on this little cub later on.
Old Apr 19, 2015, 07:15 PM
justinf307 is offline
Find More Posts by justinf307
United States, WY, Glenrock
Joined Apr 2015
Anyone try dual aileron servos? I just finished putting mine together this evening and it seems the ailerons have a lot of slack. It already has the servo horns so it doesnt seem like it would be too hard to carve out a mount for them.
justinf307 is offline Find More Posts by justinf307
Old Apr 20, 2015, 09:09 PM
Joined Apr 2015
Took my cub out for its maiden today!
It was a little bit to windy but I couldn't help myself. In all honesty it was my first complete take off to landing successful flight. I've been working on teaching myself to fly with an older Great Planes Mini super sportster, but it had an unfortunate incident with a tree. I just couldn't make myself get a real trainer that didnt look scale, so I ended up with with the Cub. I dont have any clubs or fields that arent at least a 30 min drive, so this cub is a great size for the areas I have local. The Cub handled great after getting it mostly trimmed I cruised around making at least 6 or 7 aborted landing approaches before settling down for a decent landing.
Old Apr 20, 2015, 10:25 PM
ory69 is offline
Find More Posts by ory69
....left up, right down !!!
ory69's Avatar
United States, OR, Depoe Bay
Joined Nov 2010
Congratulations, Justin! Welcome to the rewarding, and often challenging world of R/C flying.
ory69 is offline Find More Posts by ory69
Old Apr 21, 2015, 04:41 AM
Gary John is offline
Find More Posts by Gary John
United States, MN, Markville
Joined May 2014
Justin, the FZ Cub is a great plane and flys very well right out of the box. Other than 2" Dubro' tires mine is bone stock and has logged well over 500 landings. I still like to fly it even after adding the FZ Beaver, PZ T-28, PZ-47, and PZ Corsair to the hanger.
Gary John is offline Find More Posts by Gary John
Old Apr 21, 2015, 11:11 AM
Joined Apr 2015
Flyzone Select Scale Super Cub RTF Review
Thanks! I can see this being a very addicting hobby. I've been fascinated by rc planes since I was a kid, but just now getting a chance to fly.
Some of the reviews of the cub and its quirks had me worried, but so far I'm finding it to be a pretty easy to fly plane. I took it out this morning and put a couple packs through it before the wind came up. I spent one of the packs just taking of and landing which help quite a bit.
Old Apr 21, 2015, 12:14 PM
deadzone is offline
Find More Posts by deadzone
United States, CA, San Diego
Joined Oct 2013
Yeah if flies okay in calm, but any kind of wind just magnifies the instability. That said, any Cub is especially challenging to land in wind. But if you can master this plane you will feel like an expert pilot when fly more stable planes.
deadzone is offline Find More Posts by deadzone
Old Apr 25, 2015, 07:54 PM
Joined Nov 2004
I agree that this plane is unstable in high winds but because of that, I also found that it helps to sharpen your flying skills. It's a great harming up plane to start off a flying day .
Old Aug 02, 2015, 10:34 PM
jpurcha is offline
Find More Posts by jpurcha
jpurcha's Avatar
Canada, MB, La Salle
Joined Sep 2004
Has anyone had this problem with their Flyzone Supercub?
I helped introduce our music teacher's son to rc model flying. He had purchased a Flyzone SuperCub. It has been used with another Tactic 404 radio for wireless buddy boxing.
I wasn't at the last flying session, but he has reported the following problem:
" Every second time you go full throttle or if you switch transmitters while the motor is going, the motor stops and the plane beeps but other than that the plane is fine."
Any help would be appreciated.
Jim
jpurcha is offline Find More Posts by jpurcha
Old Apr 26, 2016, 11:37 AM
whowhatwhere is offline
Find More Posts by whowhatwhere
CA...gimme the CA...
whowhatwhere's Avatar
United States, GA, Savannah
Joined Jun 2005
Nearly a year since any activity in this thread...my last post here was in 2012. So who's still flying this guy?
I am...every single session. It's my go-to plane to get the cobwebs out of the brain and loosen up. I have hundreds of flights logged and many more to come. It's one tough plane...I let a guy fly it once and he promptly put it into a tree. Plus I hit the fence at the start of the runway once when I should've had another click of throttle. Not to mention dozens of less than stellar landings....and it still flies like a champ.
I've applied pretty much all the published mods, with a couple of my own. One of the primary mods I implemented was to drill two holes over the TE saddle area and glue a couple 3/8" diameter dowels into the fuse. I then sunk a couple screws to secure the TE of the wing...it seemed kinda loose in the rear with some amount of play. After sinking the dowels the wing is nice and secure.
I also swapped out the stock motor for a PowerUp 450 Sport from Heads Up, mounted on the milled motor mount designed especially for this plane. I'm also using an Electrifly Silver Series 25A ESC that came out of my long gone SE5a.
Some flyers are saying it's not stable in windy conditions, but mine flies SUPERBLY in the wind. I can park it into a breezy headwind and it'll just float around lazily.
I have to say this is one the very best planes I've owned and flew. Once I got it adjusted properly I can't say enough about how much I enjoy flying it.
whowhatwhere is offline Find More Posts by whowhatwhere
Old Apr 26, 2016, 12:41 PM
Radio-active flyer
Rem Fodder's Avatar
Joined Apr 2012
I still fly mine occasionally, but only off of water now that the floats are on permanently. Last time she was flown was late in September last year. It's still a fun plane to fly with the added dimension of water thrown in. Power with the modified 450 is just about right for float flying. After trying to taxi without a water rudder for a number of flights it became necessary to add one. Water handling is much better now as the tendency to weather vane into the wind has been eliminated with the water rudder. Not sure how many flights are on my old Cub, it has to be well past 400 and she keeps on flying. Not bad for a model that some say is a slug.
Old Apr 26, 2016, 01:32 PM
Joined Jun 2005
Hey Rem, I recall you and I discussing this guy quite a bit a few years back. Good to hear that yours is still flying!
I took a few years off where I wasn't flying regularly, but lately I've been going every day after work, weather permitting. This plane does a terrific ROG on takeoff...floats right up and attains altitude with ease. I'm actually spinning an APC 9x4.7 on the 450, which is kinda high according to the motor specs. The HURC page says to avoid WOT too long with that blade. Doesn't seem to matter...I've flown a couple hundred flights on this combo and have had no problems.
I was flying it in a pretty strong crosswind last week and one gust flipped it over sideways after I touched down. Broke the prop but otherwise OK.
But man....I love it when I grease a landing with this guy!
Article Hobby Lobby eRC 90mm F/A 18E Super Hornet EDF Bajora Foamy EDFs 92 Jul 13, 2015 01:57 AM
New Product Hobbico Flyzone Select Scale "Super Cub" coming soon! guapoman2000 Parkflyers 274 Jun 17, 2011 04:03 PM
