Old Jan 31, 2016, 02:02 PM
BababooeyHTJ is offline
Find More Posts by BababooeyHTJ
Joined Jan 2016
Also, it seems like this thing uses the exact same motors as the nano qx. Just uses a different connector and the motor for the lower gear seems to use a longer stator. Seems like it wouldn't be too difficult to mod the mmw qx motors to work on the mcx2.
BababooeyHTJ is offline Find More Posts by BababooeyHTJ
Old Jan 31, 2016, 02:41 PM
Chap1012 is online now
Find More Posts by Chap1012
Epilepsy Awareness
Chap1012's Avatar
United States, MA, Malden
Joined Mar 2008
Originally Posted by BababooeyHTJ View Post
Thats just it. I'm using a less aggressive throttle curve. On top of that when using a lower servo travel I can sent it into a death wobble way too easily on the long balls on the swashplate. I can't imagine turning up the aleron travel another 25%.
I believe the setting I posted all work in conjunction with one another.
When I had my DX6i I dialed in those exact numbers and never had a problem. I also installed an MSR swash which gave it more throw. I'd fly her outside as long as the wind wasn't too bad.
IE: Motors. Sorry can't help you there. I've always replaced the motors with stock motors.
Mike.
Chap1012 is online now Find More Posts by Chap1012
Old Jan 31, 2016, 03:59 PM
Joined Jan 2016
How hard is it to pull this thing into the death wobble? If you pull on the aileron hard enough during a hover without turning will it do it? I'm just trying to figure out where I'm going wrong here.
I've heard that a cnc swash can really help just due to it eliminating the slop. Just not really sure.
Old Jan 31, 2016, 05:32 PM
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Probably not but, if you were moving forward then yes. You just have to fly the heli until you get to know it's capabilities.
In Bold: This is known as "stick slamming." You have to be smooth with the sticks especially in turns.
Mike.
Old Jan 31, 2016, 10:50 PM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
Just picked up a mcx2. I tried the stock tx for about a minute, gimbals were horrendously stiff. So I setup my dx6i rather quickly. Have all of the rates set to 100 and using a linear throttle curve. Works well. One issue that I am having is that when using the longer balls on the swash if I hit the aleron too hard on one side it can go straight into the death wobble. I knew to expect that but I thought that you should have to hit the aleron during a hard turn in the same direction. I see people even setting up the tx to have the servos go over 100.
Should I be looking at the swashplate? Not really sure where to start.
Death wobble is induced by the way the rudder action works on a coaxial with a flybar. On this coaxial it's always going to happen with hard left rudder. Aileron doesn't even enter the picture. See the vid I posted a few pages back (post #3528) and read the discussion leading up to it for an explanation, starting at #3517.
North_of_49 is offline Find More Posts by North_of_49
Old Jan 31, 2016, 10:58 PM
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
For a newb...yes. For me...Negative
Old Feb 01, 2016, 05:30 PM
Jake8131 is online now
Find More Posts by Jake8131
Jake From Planet Mascoutah, IL
Jake8131's Avatar
United States, IL, Mascoutah
Joined Dec 2010
The MCX2 is notorious for drifting to the left while going forward. You can mix this out. Use this for MIX1:
MIX1
ELE>AIL
-35% 0%
SW: ON
Play with these settings till it goes straight. If it drifts the other way use +35.
Jake8131 is online now Find More Posts by Jake8131
Old Feb 03, 2016, 12:28 AM
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Jake, nice car man
Old Feb 04, 2016, 09:39 PM
Jake8131's Avatar
Joined Dec 2010
Jake, nice car man
Just got her a few weeks ago. 2010 Ford Ranger.
Old Feb 04, 2016, 11:50 PM
Epilepsy Awareness
Chap1012's Avatar
Joined Mar 2008
Sweet
Sold Eflite Blade MSR Plus 2.4ghz Eflite Transmitter soaringcam Aircraft - Electric - Helis (FS/W) 4 Apr 07, 2010 11:27 AM
Sold EFLITE BLADE MSR+BLADE 400+DX6i dhmojo Aircraft - Electric - Helis (FS/W) 7 Mar 29, 2010 11:38 PM
Sold Blade MCX2 LNIB mgroves Aircraft - Electric - Helis (FS/W) 1 Mar 23, 2010 12:17 PM
For Sale Trade, eflite blades for eflite blades....Sell Blade CP Pro NIB with extras. kdill2160 Aircraft - Electric - Helis (FS/W) 1 Sep 02, 2006 10:28 AM
Alert Eflite Blade CX - 2nd Eflite heli jschenck Coaxial Helicopters 26 Oct 24, 2005 02:48 AM
