Old Jun 15, 2015, 05:16 PM
3DMON is offline
Find More Posts by 3DMON
KK4EHM--FPV Mon!
3DMON's Avatar
United States, FL, Sebastian
Joined May 2005
Originally Posted by tolice View Post
Stinger, don't give up.
I had lots of fun with mine before crashing it very seriously.
It survived 3 or 4 crashes before total destroy
Will make another this year, just need some time to start.
Any HK motor suggestions for the normal size Speedy, with a 4S setup?
I made mine with an inrunner great planes motor and it was fine. Now I want one with an outrunner.
I think this 4400 kv is too large, don't? I have onde of these.
https://www.hobbyking.com/hobbyking/...dProduct=11177
Maybe this?
http://www.hobbyking.com/hobbyking/s...idProduct=8137
It runs on 4S
Too heavy?
http://www.hobbyking.com/hobbyking/s...dProduct=21483
The 2nd one listed would be the better choice. The motor I had for 4s that took it to 138 mph was 65 grams but they no longer sell it now.
3DMON is offline Find More Posts by 3DMON
Old Jun 18, 2015, 06:41 PM
stingeragents is offline
Find More Posts by stingeragents
Joined Jan 2011
I'm trying not to give up. That 4th attempt broke my only 4x4 prop, and I've honestly been put off by the whole project. I'm sure its a great flying plane but I just can't figure it out. I may have to get on hobbyking and order a crap ton of cheapo 4x prop's. Somehow though, I always seem to have this problem with smaller planes. I scaled down a pusher prop f-18 a few years ago that ended up about the same size as the speedy. And for the life of me, attempt after attempt after attempt I could never get it to fly. I'd love to write it off to a newbie mistake, but I've flown for years so I can't. Just never have good luck with smaller planes for some reason.
stingeragents is offline Find More Posts by stingeragents
Old Jun 19, 2015, 01:40 PM
tolice is offline
Find More Posts by tolice
tolice's Avatar
Curitiba, PR, Brasil
Joined Aug 2010
Think smaller, AND FASTER, much faster
tolice is offline Find More Posts by tolice
Old Jun 19, 2015, 04:09 PM
didjital is offline
Find More Posts by didjital
cuckoo for cocoa puffs
didjital's Avatar
United States, FL, Port St Lucie
Joined May 2013
I had the same roll to the left problem with both of mine. I had put such small throws on the plane because of the speed that I was left with not enough to counter the torque roll. I then upped my deflections and found that I needed a boat load of right aileron to get it flying straight. I have probably about .150 to .200" of deflection with subtrim just to counter the torque. I also needed quite a lot of up elevator. My cg is per the plan, and with these changes it flies great, very smooth. Btw, I have a 4400kv running 3s on a 4.5x4.5 prop, and it screams. I also made a full airfoiled wing, but very thin- only about .320" at thickest point. I'll put some pics up tonight...
didjital is offline Find More Posts by didjital
Old Nov 30, 2015, 09:17 AM
Lnk47 is offline
Find More Posts by Lnk47
from France
Lnk47's Avatar
Joined Oct 2010
3D printed Speedy
Hi all,
I was just wondering if someone had already printed this bird with a 3D filament printer ? I've already built one in "6mm foam", I must say it flies very well.
Here where my modeling is so far.
I don't know if this could fly, may be printed with PLA (light & strong).
Question : should I also apply NACA symetric profile on the stabilizator surface ? Thanks
Lnk47 is offline Find More Posts by Lnk47
Old Nov 30, 2015, 09:28 AM
3DMON is offline
KK4EHM--FPV Mon!
3DMON's Avatar
Joined May 2005
Originally Posted by Lnk47 View Post
Hi all,
I'd love to see a 3d printed version of the Speedy actually fly.
I'm pretty sure you would be the first.
I think to get one to fly you will need to scale it up because the wing loading is going to be very high. Using a symmetrical NACA on the stab seems like a good idea.
If you get one to fly I hope you'll send me the .stl's so I can print one too.
Looking forward to your progress.
Old Nov 30, 2015, 09:35 AM
Lnk47 is offline
from France
Lnk47's Avatar
Joined Oct 2010
Hi 3DMON, thanks you again for this awesome design !
For sure I will share the STL's.
PLA material is quite light IMAO https://3dlabprint.com/index.php; of course wing-loading will depend on how the surfaces are extruded to make solids. (thickness)
Will work on the project, keep in touch
Old Nov 30, 2015, 11:42 AM
headlessagain is online now
Find More Posts by headlessagain
Reap the wild wind
headlessagain's Avatar
Bristol,UK
Joined Feb 2007
Here's one but a bit larger than the Speedy
https://www.youtube.com/watch?list=P...&v=KJ9iG-FnP0Q
Andy
headlessagain is online now Find More Posts by headlessagain
Old Dec 10, 2015, 02:36 PM
Lnk47 is offline
from France
Lnk47's Avatar
Joined Oct 2010
Sorry guys, bad news here ... the problem is the weight with PLA filament.
I've made some conversions, my airframe would be more than 1kg without electronics !
This is because I have a 3D Printer which can print 1.75mm filament.
I'm pretty sure that with a smaller extruder, I could get thiner layers and less weight.
Here is the Rhino3D attached.
Old Dec 10, 2015, 05:51 PM
3DMON is offline
KK4EHM--FPV Mon!
3DMON's Avatar
Joined May 2005
So what size nozzle are you using right now? I would think a .4mm would do ok.
Old Dec 11, 2015, 04:29 AM
Lnk47 is offline
from France
Lnk47's Avatar
Joined Oct 2010
My 3d printer has 0.4mm nozzle : http://www.sharebot.it/index.php/sha...ation/?lang=en
Even printed in PLA, the expected weight of the naked airframe (no electronics) is expected to be more than 900 grs~1000 grs which is a bit heavy
Old Dec 11, 2015, 07:24 AM
3DMON is offline
KK4EHM--FPV Mon!
3DMON's Avatar
Joined May 2005
Yeah, I think the only way to make it happen with the Speedy is to scale it up then.
Old Dec 11, 2015, 02:22 PM
Lnk47 is offline
from France
Lnk47's Avatar
Joined Oct 2010
I don't actually know how much it will be necessary to scale it up.. May be 120% from the original ?
I've made some tweaks, with a sample full fuselage part (test), of 1.3mm thickness.
(actually don't know if this PLA thnickness could be strong enough)
My 3D printer software gives always positive values of + ~10%.
This is a bit more encouraging at 160grs.
I also expect to make some parts in foam (stab & rudder) not to give extra weight to the tail.
Old Dec 11, 2015, 07:11 PM
3DMON is offline
KK4EHM--FPV Mon!
3DMON's Avatar
Joined May 2005
1.3mm thick is probably why it's coming out so heavy. I made a 3d printed fuse for a different design some time ago and I did a double layer wall for a .8mm thickness. Strategic placement of a cross brace made in plenty strong.
Build Log Stinger - Sport, Propjet, Free Plans *Video* Bogard Foamies (Scratchbuilt) 90 Jun 06, 2012 09:16 AM
Off Site Spitfire by Taylor, Plans and parts RC Models Aircraft - Fuel - Airplanes (FS/W) 3 Oct 27, 2007 03:39 PM
FoamtanaS by Lee Ulinger Video by Zak west N81U 3D Flying 35 Oct 17, 2005 05:01 PM
Stella -- 3D by Stevens Aero (video) sukhoi26mx 3D Flying 86 Sep 10, 2004 11:57 AM
First flight by downlink: aerial video, patience & bandwidth needed (slow server)... Arp Aerial Photography 26 May 06, 2004 10:15 AM
