Old Mar 31, 2007, 05:19 PM
paul sant is offline
Find More Posts by paul sant
SGT. Sant TNARNG
n-e tennessee
Joined Jan 2006
Help!
blade cp down
i was flying my bcp the other day and heard a loud pop. then the heli then went into an uncontrolable spin. thought i had lost my tail rotor motor, but now everything but the main motor works. changed out main motors but no joy. is my 4in1 trashed again? thanks Sgt.Sant TNARNG anyone???
paul sant is offline Find More Posts by paul sant
Old Mar 31, 2007, 09:38 PM
jtspin is offline
Find More Posts by jtspin
Reno, NV
Joined Dec 2005
Does your 4-in-1 smell burnt? You probably blew a MOSFET. You can try plugging your main motor into the tail motor slot to check it out. You can replace the MOSFET in the 4-in-1 if you're good with a soldering iron. I don't have a BCP, so I don't know the part number, but I'm sure others can help.
-JT
jtspin is offline Find More Posts by jtspin
Old Apr 01, 2007, 12:17 AM
SGT. Sant TNARNG
n-e tennessee
Joined Jan 2006
i have another 4-in-1 that flashes red gn red gn, won't arm, can i cannablize it ? whats the MOSFET? i guess i need to put a fuse in? i use two 3cell 1320mAh li-poy's in it.
Old Apr 01, 2007, 12:20 AM
SGT. Sant TNARNG
n-e tennessee
Joined Jan 2006
i have another 4-in-1 that flashes red gn red gn, won't arm, can i cannablize it ? whats the MOSFET? i guess i need to put a fuse in? i use two 3cell 1320mAh li-poy's in it. first 4-in-1 lasted over a year, only a month on this one.
Old Apr 01, 2007, 12:26 AM
stirlingnut is offline
Find More Posts by stirlingnut
zagnutz fiend
stirlingnut's Avatar
tulsa,ok
Joined Jul 2004
Hey paul,try a new crystal in your 4n1 that flashes red/green. I had one go bad this evening in between flights! Kinda weird,and acted just as you describe.
'nut
stirlingnut is offline Find More Posts by stirlingnut
Old Apr 01, 2007, 12:48 AM
SGT. Sant TNARNG
n-e tennessee
Joined Jan 2006
i was gonna try that and hobby town usa sold me ch59 that they said would work but i don't think will work with the bcp cause it's not listed under replacement parts. only 17,19,21,50,52+54 i guess are the only ones that will work?? hobby town also sold me a motor awhile back they said would work with my piccolo, it burned up my piccoboard.
Old Apr 01, 2007, 12:53 AM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
You must use an 8T pinion motor with your 11.1v 1320mah lipo. Or else you'll keep toasting your 4-in-1. Don't repair your 4-in-1. It doesn't always work or last long.
Gino CP is offline Find More Posts by Gino CP
Old Apr 01, 2007, 01:27 AM
SGT. Sant TNARNG
n-e tennessee
Joined Jan 2006
thanks Gino , gotta get a 8t pinion ! gotta go brushless too !
Old Apr 01, 2007, 11:37 AM
dbercot is offline
Find More Posts by dbercot
Is it windy outside?
dbercot's Avatar
Fort Wayne, IN
Joined Sep 2006
I've repaired a few 4 & 1's, it's hit or miss. If the circuit board isn't too toasted you can get a MOSFET soldered on with little effort. Many times the board is so bad there's no saving it. Either way, it's a bit of work to fix and will keep you on the ground until you get parts. Maybe it's time to look into seperates.
As for the pinion, it should be OK to run 9T pinions, according to the manual, but definitely NOT 10T pinions. Am I wrong Gino??
dbercot is offline Find More Posts by dbercot
Old Apr 01, 2007, 11:49 AM
Gino CP is offline
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
9T is on the borderline. It depends on how cold your climate is and how good the components are on the 4-in-1. The manual does acknowledge that battery runtime is less with a 9T. I'll side with caution on this one.
As for the 4-in-1 , I've repaired a few. After the repair, they work. Heli hovers. Then after some time, it fails again. Second repair, no dice. Motor won't spin. That is why I stopped replacing fets and diodes. I am not qualified to check the rest of the components.
Old Apr 01, 2007, 02:17 PM
BowerR64 is offline
Find More Posts by BowerR64
BeeZaur 480
BowerR64's Avatar
Parkville Mo.
Joined Dec 2004
Caps usualy pop, and sometimes batterys will pop and vent.
If the heli is drawing to many amps to fast the battery can overheat, gas builds up inside and they they vent wich can sometimes pop. They work kinda like a thermastat on a car.
BowerR64 is offline Find More Posts by BowerR64
Old Apr 01, 2007, 04:53 PM
dcg9381 is offline
Find More Posts by dcg9381
United States, TX, Austin
Joined Feb 2007
I had exactly the same thing happen.. Heli immediately wouldn't take any control input and was spinning like a top from about 13' up.
I was running a stock motor, 10t, flatblades, with a heatsink. I had a 9A fuse in-line to the motor.. Obviously I was overloading something. I might get ambitious and do some load testing.
I'm planning on running the AEK kit now, but with flat blades - that's a 9T motor with the 11.1V lipo.. Sounds like this is still borderline.
Options are soldering a resistor inline to drop the current draw or buying another $10 motor.... I'd like to keep it in the air the 4-in-1's aren't cheap.
I haven't tried replacing 4-in-1 components yet..
dcg9381 is offline Find More Posts by dcg9381
Old Apr 10, 2007, 05:54 PM
tor_kamata is offline
Find More Posts by tor_kamata
Crashin 1 plane at a time
tor_kamata's Avatar
Ohio
Joined Jul 2006
I have the same story not more than an hour ago. I was up about 20 feet it shot up about another 10 on it's own and stalled out, and now the main motor will not spin. I thought it was the brushes but the motor tested out fine. Came in the house and started checking the forums.
tor_kamata is offline Find More Posts by tor_kamata
Old Apr 10, 2007, 08:19 PM
SGT. Sant TNARNG
n-e tennessee
Joined Jan 2006
back airborne
bought another 4 in 1 , 3rd one now, $70 bucks at hobby town usa. new motor with 8t pinion. hope this one last . whats a good computerized transmitter for helicopters ? how $$ ? i want to go brushless and get my piccolo/huey back in the air. i have a bunch of old cd-rom motors , are they worth the trouble? i'm back airborne in my bcp/hughes 300 so i'm happy for now.
Old Jun 17, 2015, 10:32 PM
Sgt.Sant is offline
Find More Posts by Sgt.Sant
Sgt.Sant's Avatar
Joined Jun 2015
thats me
that's me
Sgt.Sant is offline Find More Posts by Sgt.Sant
Discussion Tuning down a blade CP mtm87tx Micro Helis 5 Jul 09, 2006 07:08 PM
Blade CP yoyos up and down while hovering taildragger1589 Micro Helis 122 Jan 25, 2006 08:22 PM
Calming down the Blade CP for the newbie Cable Guy Micro Helis 10 Nov 16, 2005 04:45 PM
Blade CP Tail wagging up/down??!! beemer Micro Helis 6 Aug 05, 2005 07:20 AM
Blade CP balooning up & down! AirMicro Micro Helis 2 Jun 09, 2005 12:14 PM
