Old Apr 13, 2015, 10:14 PM
psychedvike is offline
Find More Posts by psychedvike
psychedvike's Avatar
United States, MN, Eagan
Joined Aug 2012
Build Log
The Mother of All Vacuum Formers!
I want to share a build log of my latest vacuum former. My use of vacuum formed parts for my scratch built planes has evolved along with my vacuum formers. I started out wanting to be able to form canopies. Now I have ideas for entire fuselages. In the pictures you can see how I started with a box and a shop vac. It worked well but was inconsistent. The second one had the shop vac built in to the top of a file cabinet and guides to maintain a consistent straight pull. This one worked better but it is cumbersome and it takes way too much time to change the plastic sheets. I also really want a stronger vacuum to pull better detail and have a tighter pull around the bottom of the bucks.
The perimeters for this build are that it must be built as cheaply as possible. It needs to give me high quality parts. It must be efficient and easy to use, especially to load and unload the plastic and bucks. It must be able to use sheets that are these sizes: 12ĒX12Ē, 12Ēx24Ē, 24Ēx24Ē, 12x36Ē, and 24Ēx36Ē.
So after much research and scavenging a ton of stuff from the free list on Craigslist, multiple trips to the area thrift stores and a few choice purchases from amazon, Iím ready to attempt to build ďThe Mother of All Vacuum formers.Ē
So if this interest anyone please be patient it might take a few weeks, but the plan is to get it done ASAP.
Before I start the build log these pictures are a short history of my previous vacuum formers. I hope I donít bore everyone.
psychedvike is offline Find More Posts by psychedvike
Old Apr 14, 2015, 02:32 AM
Chad Veich is offline
Find More Posts by Chad Veich
Scale Builder
United States, AZ, Litchfield Park
Joined Jul 2002
Subscribed! Bring it on psychedvike, can't wait.
Chad Veich is offline Find More Posts by Chad Veich
Old Apr 14, 2015, 09:55 AM
ARUP is offline
Find More Posts by ARUP
United States, KY, Taylorsville
Joined Mar 2010
I'm in! My current machine is too small and I wish to get away from using regular oven to heat plastic.
ARUP is offline Find More Posts by ARUP
Old Apr 14, 2015, 11:39 AM
Brner is offline
Find More Posts by Brner
Just Me
United States, OR, Salem
Joined Apr 2006
Subscribed....have built one pretty much along the lines of what you're doing....good luck...
Brner is offline Find More Posts by Brner
Old Apr 14, 2015, 01:41 PM
newguy is offline
Find More Posts by newguy
No retreat no surrender
newguy's Avatar
USA, WI, Milwaukee
Joined Apr 1999
Subscribed-looks like FUN
newguy is offline Find More Posts by newguy
Old Apr 14, 2015, 01:56 PM
foamdave is offline
Find More Posts by foamdave
skumgummi dave
Gresham, OR.
Joined Mar 2004
Lurking and learning...
Dave-
foamdave is offline Find More Posts by foamdave
Old Apr 14, 2015, 10:34 PM
Joined Aug 2012
Vacuum pumps run around $150 to $200 or more so thatís out. Thanks to You Tube I have a free option. Iím using an old refrigerator pump. An added bonus is I can use a lot of the sheet metal and hardware. This one I found on CL for free. If you plan on making your own try to get one that the ad says ďruns but doesnít cool, or needs to be recharged. This way you donít have to have the Freon removed by an AC repair guy (the environmentally conscious way) or cut the line and let the Freon escape into the atmosphere. Stripping the fridge, dissembling it, and then cutting it up really didnít take too long. I plan on using as much free list stuff as possible. I also have some oak and solid core commercial doors I got from a dumpster dive from a remodel of an office building near my house. Iím going to use these too. I have some steel left over from another project, but I missed two different scrap hide a bed frames on the free list. If you see something you have to move fast because the good stuff doesnít stay on there long. Since I didnít want to wait to find more steel I broke down and bought some steel. That upped the cost by $75.
OK sorry for being long winded. Check out the pictures of my progress so far.
Old Apr 15, 2015, 03:25 PM
Star7 is offline
Find More Posts by Star7
Ca. USA
Joined Sep 2008
Wonderful thread, THANK YOU!
Star7 is offline Find More Posts by Star7
Old Apr 15, 2015, 04:10 PM
landeck is offline
Find More Posts by landeck
United States, GA, Sandy Springs
Joined Jul 2008
Why not use tinfoil instead of the chrome paint? It will reflect heat better and should not be damaged by the heat.
Bruce
landeck is offline Find More Posts by landeck
Old Apr 15, 2015, 09:46 PM
Joined Aug 2012
Bruce
Thanks Bruce. I actually thought of that. That's plan B. If the paint doesn't last. It would actually reflect the infrared better.
Old Apr 16, 2015, 10:23 PM
Joined Aug 2012
Todays progress
Well I got a little welding done. Or at least I tried to weld a little. Itís been a while and I never was a great welder. With a little effort Iíve got some of the pieces together. The base could have been made out of wood but since I had a lot of the components to do steel thatís what I went with.
Old Apr 20, 2015, 10:02 PM
Joined Aug 2012
I got some done on the MoAVF over the weekend. Finished the frames and I got lucky enough to find a counter top on the free list. It came along just in time. I also found some square tubing. I wish it came along sooner it would have saved me money. Anyway here are the pictures.
Old Apr 28, 2015, 07:07 AM
ARUP is offline
Joined Mar 2010
Maybe back the tinfoil with some fiberglass insulation?
Old Apr 28, 2015, 08:44 AM
Joined Aug 2012
Hi ARUP
I have fiberglass insulation sandwiched in between the top, outside sheet of sheet metal and the inside top, sheet metal. I didn't make the sides that way. They don't have the inside piece of sheet metal. I got lazy. I might go back and line the sides as you suggest. I think I'll test it and see how hot the sides get and how well it transfers the heat to the plastic. Thanks for the input.
Old Apr 28, 2015, 08:12 PM
JMDESIGNS is offline
Find More Posts by JMDESIGNS
JOE MOCERI
United States, MO, St Charles
Joined Nov 2006
Very nice. I made a small one years ago using a vacuum for the suction and the kitchen oven for the heat source. Worked OK but I had problems with the plastic not pulling tight to the forms, Always had some webbing at the corners. Will maybe try again some day.
A word of caution on using the stationary sander and table saw on the steel. If you use the sander for wood also, the dust from the wood collected in the sander and saw will catch fire from the sparks when sanding steel. My sander caught fire and scared the bejesus out of me. Be careful and clean the dust out prior to making sparks.
Joe
JMDESIGNS is offline Find More Posts by JMDESIGNS
Help! Newbie Vacuum former question wollins The Builders Workshop 5 Feb 05, 2015 08:19 PM
Discussion can you vacuum form foam using a regular vacuum former? John Molnar Jr. Scratchbuilt Indoor and Micro Models 14 Apr 26, 2013 12:22 AM
*EBAY*- Vacuum Formers for sale kayaker43 Aircraft - Electric - Airplanes (FS/W) 0 Jan 09, 2004 08:57 PM
Vacuum former needed ASAP Mike Hall The Builders Workshop 0 Apr 22, 2003 11:27 AM
Vacuum Former kits Fred Bronk Electric Plane Talk 8 Nov 28, 2001 05:20 PM
