Old Oct 28, 2013, 09:26 AM
scootrb4 is offline
Find More Posts by scootrb4
2 Fast 2 Low & 2 Loud
scootrb4's Avatar
United States, CA, Winchester
Joined Nov 2011
In conclusion -
The wing incidence is off. I spoke with another modeler who had this same plane and said he had to fly with down elevator also.
I have moved the LE of the wing down 5mm and it has helped alot but still not enough. The adjustment has improved it's flight characteristics. I will fly it there.
The DLE 30 has plenty of power even on the break-in 32:1 mix
I don't recommend the CMP Zero.
scootrb4 is offline Find More Posts by scootrb4
Old Nov 06, 2013, 06:26 PM
BILLYDSRC is offline
Find More Posts by BILLYDSRC
BILLYDSRC's Avatar
OHIO
Joined Aug 2009
HI All, Im looking for a war bird build for this winter and came across this! I fly Turbine and EDF jets and I have a fix for the eflite 60-120 retracts My Turbine Viper comes in @ 22.5lb dry and i have over 65 flights on it this year without a problem with them!! Ok not here to sell anything just to help out. BTW any good ideas on a 100+" wingspan war-birds out there? P-51,spitfire,P-47... Thanks Billy D
http://www.usarcjets.com/cgi-bin/sho...t%20-%20Struts
Originally Posted by edwin1 View Post
I assembled this plane years back with a rcgf 20cc. Once I finally got the engine running good enough it was a decent flying plane. Things I did was to rip out the servo tray and put in a new one all the way forward up against the wing leading edge bulkhead with a slot cut for the tank, added some 1/8" ply doublers to the wing retract mounting rail ribs (they cut lightening holes in them, very bad idea). My retract rails broke a few times before that mod. The paint chipped on me pretty bad so I refinished it. Turns out ultracoat off white matches rustoleum almond almost perfectly. I had to use a 1/4" x 5" diameter steel plate on the firewall to balance, its awfully short coupled. I'll be curious to see how it balances with the DLE30.
I didnt have to drill my fuse for the stab rods. Dont know whats going on there.
I would HIGHLY SUGGEST to NOT use the eflite 60-120 retracts. Not strong enough. I used them in my H9 B-25 and broke one. Thats only a 14lb plane. Before that, you had to land light because it seemed wobbly. The struts I had used a locking nut to hold the wheel on. It came off on landing. When the strut came down on pavement, the plane swung sideways and busted the metal trunnion in the retract. They use a very poor grade of aluminum. It looks almost like pot metal. E-flite also does NOT sell spare parts. They pretty much leave you hanging. I was fortunate to find a guy on RCG that makes replacement trunnions out of much stronger 6061 aluminum. You can see they are much beefier than the originals. Thats also when I discovered that the frames are not machined very well. The first trunnion fit perfect in the broken retract, the second had a bind problem that took a little filing on both side plates to get to work. Both trunnions were exactly the same when stacked so my only conclusion was the side panel being off. It worked with the original trunnion, but took a small amount of filing to get the better one to work. If I had to do it again, I wouldnt use E-flite retracts. I went back to air robarts and have been happy since.
Edwin
BILLYDSRC is offline Find More Posts by BILLYDSRC
Old Nov 06, 2013, 09:58 PM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
Actually the eflite retracts are doing good in this plane ( 16 flights ) She has no flaps so you come in hot and grease her down..... I think the retracts will last a long time despite the 15 pounds AUW
Friend just maidened an ESM Spitfire near that size. She is nice!
Old Nov 12, 2013, 01:29 AM
DAVETHEDOG is offline
Find More Posts by DAVETHEDOG
QLD, AUSTRALIA
Joined Jul 2009
Good to hear another Zero is in the air, it is great to see other warbirds in the in other than the usual P51_P47 etc.
What's the performance like with the 30cc in? I did consider it for mine but it was a tad to big, can you post some pics of hero in action
DAVETHEDOG is offline Find More Posts by DAVETHEDOG
Old Nov 12, 2013, 08:53 AM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
The DLE30 has plenty of power, all flights so far have been with the break in prop and oil (32-1). Yet it seemed to have lots of pull even with the variable pitch 18x6-10 prop. I think it will have unlimited vertical even with the nearly 15 pound dry weight.
I have 2 gallons run through her and next flights will be with 40:1 redline 2 stroke oil and 8x10 Zoar prop.
This is my first gasser. The motor is a little on the 2 big side but, it fit reasonably well with the stock muffler. I still added over 1.5 pounds to balance. A smaller motor would have just meant more lead and less power. My next gasser is is coming together. Another CMP 120 sz. The FU4 kamikaze hunter.
Although I am somewhat disappointed in the CMP model I have enjoyed the flights. The Zero is a great flying design and the Eflite 60-120 retracts are holding up to good landings. Which is more than we can say for the CMP retract pockets !
Here she is on the left sitting next to a World models Zero. I will try for a few action pics next weekend. Thanks for asking
Old Mar 24, 2014, 02:01 PM
FTIR is offline
Find More Posts by FTIR
Mr Clean
FTIR's Avatar
USA, OH, Xenia
Joined Mar 2007
CMP Zero
Here is a youtube of my buddy flying his CMP Zero four years ago. It is still flying and he flies it a couple time a week. Even used it to compete at the Bob Evans Farm fly-in in Ohio. He also has 1.5# of lead in the front.
CMP Hellcat and Zero (6 min 59 sec)
good luck
FTIR is offline Find More Posts by FTIR
Old Jan 18, 2015, 08:50 AM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
I picked up another of these CMP 120sz Zero Yesterday in the local swap meet.
Old Jan 19, 2015, 06:56 AM
scale_only is online now
Find More Posts by scale_only
# Scale is a way of life
scale_only's Avatar
United States, OH, Avon Lake
Joined Apr 2010
I've had one stashed away in the garage attic for coming up on three yeas now,,, was thinking of doing a Rufe conversion,,, guess I'm getting lazy. I'm currently restoring the world models 50cc I dead sticked last year,, too many projects
scale_only is online now Find More Posts by scale_only
Old Jan 19, 2015, 07:32 AM
scootrb4 is offline
scootrb4's Avatar
Joined Nov 2011
My model needed quite a bit of down elevator for level flight (properly balanced). Another flyer at the field said his had the same trim requirement. I was not happy with that so I changed the wing saddle bringing the LE down to get level flight. Afterwards she was a great flyer.
I ordered the robart gear for the project.
For Sale DLE 30 with header and canister $300 radinstlr Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jul 26, 2013 04:46 AM
Sold Giant Stik rx ready with DLE 30 SWLMI local pick up. flyinjrc74 Aircraft - Fuel - Airplanes (FS/W) 5 Feb 28, 2013 11:57 PM
Sold Wingsmaker aka CMP Zero 60 NIB dlewton Aircraft - Fuel - Airplanes (FS/W) 3 Jan 28, 2013 02:51 PM
Sold Pilot RC 30% Edge 540 With 55 DLE Dale 813 Aircraft - Fuel - Airplanes (FS/W) 0 Jan 27, 2013 09:13 PM
Question DLE 30 what for this fuel Tank for on DLE 30 Johnsmith122 Engines 5 Jan 09, 2013 02:18 PM
