Old Jul 31, 2014, 09:37 AM
Bob from MD is offline
Find More Posts by Bob from MD
I fly wood.
Bob from MD's Avatar
United States, MD, Columbia
Joined Jun 2009
get rid of the on/off switch... nothing but trouble waiting to happen! Just plug in when you are ready - remove battery when done..
That was the first thing I did. Put magnets on the hatch cover of the old TD fuse and did the same with the new electric version. It couldn't be easier to get access to the plugs.
Bob from MD is offline Find More Posts by Bob from MD
Old Aug 04, 2014, 08:48 AM
fasteddie123 is offline
Find More Posts by fasteddie123
FastEddie123
United States, MN, Lake Elmo
Joined Nov 2013
Originally Posted by fasteddie123 View Post
Just crashed my Camano on take off...
Gliders tend to climb under power... Its usually a bit windy and I give a good toss under power - no problems ,, but Saturday it was very calm. I gave it a wimpy toss at tooo steep an angle , full power... it started to climb straight up but NO AirSpeed , no elevator control -- rather than do a backflip, I cut power and watched the crash. lesson to learn -- AIRSPEED>>> e123
( It's already fixed : ' ) - )e123
Tested it Sunday - Launched flat out , 50% power - reflex mode ( trailing edge flat - no camber) fly straight out gain speed and ease on power to full.. Much more control... ps new nose mods also cools better now -- was hitting 140f before now 110f - time to go up to a 12x8 from a 12x6... e123
fasteddie123 is offline Find More Posts by fasteddie123
Old Aug 06, 2014, 01:24 AM
christo2977 is offline
Find More Posts by christo2977
christo2977's Avatar
United States, CA, Pasadena
Joined Feb 2014
I love these classic old time gliders. I'm attempting to elec'fy a Thermic - C. It's small, but now we have micro gear, etc. to fit. Anyone else converting old Thermics?
christo2977 is offline Find More Posts by christo2977
Old Aug 18, 2014, 01:11 PM
FastEddie123
Joined Nov 2013
estimating height??
Does anyone know the guestimating formula ??
at arm length an 8ft sailplane is 1/2"(my thumbnail)-- ( assume straight up).. how high is it? Thanks Ed
ps. 100" 4lb Dodgson Camano with a 12x8 prop on Gliderdrive 960 kv motor 3 s at 30 seconds....
Old Aug 18, 2014, 06:48 PM
Nodd is offline
Find More Posts by Nodd
Build something.
Nodd's Avatar
United States, CT, Fairfield
Joined Mar 2012
I'm not sure how to figure that out using math but enjoying a challenge I decided to bang those figures into my CAD software. Baring in mind I eyeballed the geometry onscreen so this isn't likely totally accurate, I got 864 feet (263 meters).
Nodd is offline Find More Posts by Nodd
Old Aug 19, 2014, 07:56 AM
FastEddie123
Joined Nov 2013
Sweet thanks. I was hoping it was near 200 Meters.. I now consider my 12x8 prop to be the ticket to ride with the Gliderdrive 960kv on 3s. ( in the 4lb 100" Camano) !! Just barley gets warm `` 110f motor with outside air at 85f..
Launches in reflex mode seems best, maintains nice speed and climbs well, with a smidgen of down, and occasionally more. In camber mode it just wants to climb too steep and you need to fight it with lots of down elevator, and it kills the speed.
ps - just ordered an altitude telemetry module for my DX6 g2/tm1000 .. e123
Old Aug 19, 2014, 03:47 PM
patmcc is online now
Find More Posts by patmcc
Northumberland, England
Joined Jan 2007
The altitude will be 200 (100"/0.5") x distance between eyeball & thumbnail.
I'm 5ft 11ins tall, when I extend an arm the distance from eyeball to thumbnail is 27", this would make the altitude 450ft (137meters).
For the altitude to be 864ft you'd need arms like a chimp - 4ft 4ins long.
patmcc is online now Find More Posts by patmcc
Old Aug 19, 2014, 04:38 PM
Nodd is offline
Build something.
Nodd's Avatar
Joined Mar 2012
I agree that formula is correct, I did a little poking around.
Just for my own sanity, I figured out what I did wrong in my CAD software. Without getting all technical... I centered my virtual thumb on the X axis which was the mistake. It should have been offset to one side like I'd done with the virtual glider. When I extended a line from the origin 0, 0 through the edge of the centered thumb (27" away) it effectively gave me just half the thumb's width (1/4") to work with. Thus my virtual glider ended up much further away. When I positioned the thumb correctly the CAD software exactly matches patmcc's formula. Thank God for that, now at least I can sleep again.
Something tells me Eddie would prefer my estimate over the correct one though
Old Aug 20, 2014, 08:24 AM
FastEddie123
Joined Nov 2013
I liked them both , and thank you guys for the time spent.
Friday I get my altitude telemetry module ( I think I'll like that the best ) . e123
Old Aug 22, 2014, 05:32 PM
aeajr is offline
Find More Posts by aeajr
Proud member of LISF and ESL
LI, New York, USA
Joined Mar 2003
OK, this thread is about breathing new life into old gliders. So who is flying them in ALES contests?
And who lives within driving distance of Atlantic City.
Come on down to the ALES contest on Aug 30 and/or Aug 31. Should be fun
www.flyesl.org
I will be there. Hope you will be there too.
aeajr is offline Find More Posts by aeajr
Old Aug 26, 2014, 06:24 PM
FastEddie123
Joined Nov 2013
Yep I like altitude telemetry, best thing is - it worked when I plugged it in.(.no b.s. messing around - Spektrum DX6 g2 and tm1000..
.. The altitude I was guessing at was about 400 ft. give or take a week from my memory. I need practice getting 200 meters in 30 seconds.. not sure if I can , but its a goal. e123
Saturday update -100" Camano can get to 200meters easy in 30 seconds , & got 10min 3 seconds and landed within 9ft of target... she works...
( @ 11oz per sq ft loading , a little heavy but can slow down or go "fast" .. and cover lots of ground )eddie123
Discussion SPIRIT 100 SAILPLANE - Bringiing it back to Life rhampton Sailplane Talk 13 Apr 03, 2013 08:56 PM
Discussion For those who advocate against Lipos in sailplanes snakecrew General Aviation 64 Jan 24, 2013 01:10 PM
Wanted Wanted - older floater sailplane (built, crashed or, kit) NY / New England - pick up screeeeeemin Aircraft - Sailplanes (FS/W) 1 Jun 12, 2010 01:20 PM
Wanted looking for an older glider/sailplane baja5bdriver Aircraft - Sailplanes (FS/W) 18 Aug 03, 2009 08:01 AM
Older F5D ships, can I fly those? Nicke Löfmark High Performance 26 Dec 21, 2002 03:56 PM
