Old Mar 09, 2007, 10:53 AM
WingmanDan is offline
Find More Posts by WingmanDan
fast chevron foam
WingmanDan's Avatar
United States, CA, Laguna Niguel
Joined Jun 2005
Best nimh charger for slope?
I have been using the stock Tx/Rx charger for years now. Do you guys use something better, especially for trickling multiple slopers at once? I find it quite a chore to keep all my slopers topped off, since nimh batteries "leak". When the wind looks good, the one I want to fly is usually low
Dan
WingmanDan is offline Find More Posts by WingmanDan
Old Mar 09, 2007, 10:57 AM
screamin' eagle is online now
Find More Posts by screamin' eagle
R/C Chronic
screamin' eagle's Avatar
Pacific Palisades, CA
Joined Jul 2004
Sirius Pro charger all the way. You can charge tx and plane, or two planes at once with an adaptor. Totally automated - just plug in and go. No readout means you can't check for false peaks, though.
screamin' eagle is online now Find More Posts by screamin' eagle
Old Mar 09, 2007, 11:00 AM
target is offline
Find More Posts by target
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
You don't have to trickle charge them...
I usually charge my 700 MaH AAA's at .3, so it only takes about an hour to top up from half empty.
I have a MPX 5014, and a Dymond Turbo Charger (NLA). Both display what is put into, and removed from, the packs.
The MPX does LiPo's and Lead-Acid. I like that, due to the fact that I usually bring the small Gel-Cell 12V lead battery with me out to remote F3F races, in case my plane or someone elses, needs topping up.
The triton is a fine charger, as well. All mentioned are 12V input only; you'll need a power source with them.
T
target is offline Find More Posts by target
Old Mar 09, 2007, 11:03 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
That's the reason that I only use the Siruis as a field topper; I make sure a solid load gets into my planes at the shop, the night before with the other types of chargers.
I personally haven't had trouble with my Sirius Charger, but others have.
T
Old Mar 09, 2007, 11:08 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
Also, Dan, do you have a battery tester, like the one that Hitec and Futaba sell?
That is a great investment, for @ $20.00....
I like to check my planes before throwing them of a cliff. But you could also use it at your shop, to see what's left in each plane.
Another thought, is I have heard of guys plugging in a power strip to a wall timer, with all their wall chargers plugged into the strip. They leave their fleet plugged in, and the timer is set to charge an hour or two each day- enough to "maintain" a full battery...
You'd want to make all your flight packs the same capacity, and figure out what the daily loss is, then add a little time to that.
AND use the tester!
T
Old Mar 09, 2007, 11:11 AM
JoeSantora is offline
Find More Posts by JoeSantora
USA, CO, Lakewood
Joined Sep 2002
Take a look at the Super Digipulse. It'll keep up to six packs toped off and ready, and it'll handle packs from 100 to 9000ma.
Joe
JoeSantora is offline Find More Posts by JoeSantora
Old Mar 09, 2007, 11:23 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
That's an Ace charger, right Joe?
I knew there were a few that did multiples, but couldn't remember which it was. I think it does a TX at the same time, if I recall correctly.
Target
Old Mar 09, 2007, 11:32 AM
Mike the Snake is offline
Find More Posts by Mike the Snake
RC LIFER
santa rosa California
Joined Aug 2005
Ripmax Prodegy peak II. $60 and it'll do anything. DC only though.
Mike the Snake is offline Find More Posts by Mike the Snake
Old Mar 09, 2007, 11:35 AM
target is offline
Detail Freak
target's Avatar
Harbor City, CA
Joined Oct 2003
There is a slew of these similar chargers. I think they are all based on the same thing, made by the same Manufacturer; but maybe not...
They all seem very similar to the MPX 5014...
Old Mar 09, 2007, 11:39 AM
R/C Chronic
Joined Jul 2004
I have a MPX LN 5014 as well. Nice charger, but a bit fiddly to program compared to the Sirius Pro.
Target raised a good point, which is that a field tester is a vital complement to any charging system. Even though the Sirius pro doesn't have a readout, by using VoltWatches in planes and a Futaba BR2000 battery checker, I can keep pretty good tabs on each battery's condition at the field, and ensure that it has actually been fully charged.
Like Target, I have not had problems with my Sirius Pro.
Old Mar 09, 2007, 12:03 PM
F3X is offline
F3X
Find More Posts by F3X
F3X
F3X's Avatar
Joined Jun 2001
If you want to charge 2 batteries at the same time and run AC + DC then get the Hobbico Accu-Cycle Elite Battery Cycler.
It is basically 2 MPX 5014 in one case with a AC power supply.
It will charge/discharge on either side of the charger independently and can be bought for near the same as the Sirius. Plus you KNOW what is going on with your batteries.
Hobby People and Tower sell them.
If you can use the single output and want to save a few bucks get the MPX 5014 I have one for 2 or 3 years now and it's all I use. I have them in stock. Call to order. 949-645-7032
F3X is offline Find More Posts by F3X
Old Mar 09, 2007, 12:04 PM
USA, CO, Lakewood
Joined Sep 2002
Target
That's the one. 1-10cells and 100 to 9000ma, up to six at a time
Old Mar 09, 2007, 12:06 PM
slopemeno is online now
Find More Posts by slopemeno
this space for rent
slopemeno's Avatar
Joined Jan 2003
The power strip setup youre thinking of is made by "TME". it uses a bunnch of wall warts that cycle on and off constantly. A friend of mine has been using one since 1995 or so, and he likes it.
slopemeno is online now Find More Posts by slopemeno
Old Mar 09, 2007, 12:11 PM
Pauld109 is offline
Find More Posts by Pauld109
Crashing!Unknown unknowns
Pauld109's Avatar
Near Oxford
Joined Nov 2006
I think the key feature you need is to be able to discharge and charge the cells automatically as in the Prodigy 2 and others. The cells have memories you know!
Paul
Pauld109 is offline Find More Posts by Pauld109
Best NIMH batteries for hacker B20 15L Khosravi 3D Flying 1 Jul 24, 2004 06:24 AM
Astro Flight 112D digital NiCad/NiMH charger for 1-36 cells, 100 mAh-5 amps for $59! Jason M Aircraft - Electric - Airplanes (FS/W) 5 Jun 16, 2004 10:11 PM
Best dedicated charger for Li-Polys Flying Low Batteries and Chargers 0 Jun 11, 2003 09:40 AM
Best Nimh charger Fritz57 Batteries and Chargers 5 Dec 16, 2002 03:11 PM
Best Nimh charger? Alan H. Siegel Electric Plane Talk 4 Jun 19, 2002 06:46 AM
