Old Mar 09, 2002, 10:24 PM
lensrc is offline
Find More Posts by lensrc
lensrc's Avatar
Kansas City area
Joined Nov 2001
Sweet bipe!Whaddya Think?
I just flew this new scratch design tonight for it's first time and I am one Proud Papa!I've been scratch building for a long time,but have never been as sucessful as this one turned out.I set the surfaces at zero,hit the juice and it just rose off the floor with no trim needed!THAT has never happened before!At least not to me.
OK here are the specs-
span 29in
chord 6in
area 348 sq.in
auw 6.8oz with 150mah 7cell ncd(9v app.type w/o metal jacket)
dxa motor w/10 4.7 prop
jeti 5 esc
feather rx
hs55 servos
wing loading 3 oz
It also flew VERY well with my Q830's
So? Waddya Think?
lensrc is offline Find More Posts by lensrc
Old Mar 09, 2002, 10:25 PM
lensrc is offline
lensrc's Avatar
Kansas City area
Joined Nov 2001
pic 2
Old Mar 09, 2002, 10:27 PM
lensrc is offline
lensrc's Avatar
Kansas City area
Joined Nov 2001
pic 3
Old Mar 09, 2002, 10:28 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
It looks good, how does it fly?
Fred Bronk is offline Find More Posts by Fred Bronk
Old Mar 09, 2002, 10:44 PM
lensrc is offline
lensrc's Avatar
Kansas City area
Joined Nov 2001
It flew so good I almost started to cry!No bad tendencies,needed
no trim between low speed and full bore,just climbed a slight bit.Slowed down to a crawl without dipping a wing or any of that type of behavior.It even flew nice and level when the throttle was cut and glided in for a smooth landing.I even let two other guy's fly it and none of us had problems.Dont get me wrong,I'm not one to brag,(well maybe a little!)but I have never had a scratch built fly as good as this.Two flyers here already want me to cut them a kit.I wish I had drawn patterns when I built it!
Old Mar 09, 2002, 10:47 PM
lensrc is offline
lensrc's Avatar
Kansas City area
Joined Nov 2001
BTW this was my first Bipe also.I've never even built a bipe kit.
Old Mar 09, 2002, 10:51 PM
theKAT is offline
Find More Posts by theKAT
theKAT's Avatar
Bloomington, IL (Hell's Cornfield)
Joined Dec 2001
What's the construction material? Source? Plans? :-)
theKAT is offline Find More Posts by theKAT
Old Mar 09, 2002, 10:57 PM
opualuan is offline
Find More Posts by opualuan
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
ok then, how about some plans? looks cool!
opualuan is offline Find More Posts by opualuan
Old Mar 09, 2002, 11:04 PM
lensrc is offline
lensrc's Avatar
Kansas City area
Joined Nov 2001
The material is 3/32 polystyrene(depron?)I will have a small supply of it available soon.As I dont usually have sucess like this with my scratch builds,ie-not attractive,so-so performance,I dont normally create plans.It's also difficult to do using concurrent engineering,LAR principal and KISS princaple to build planes.
I am going to create plans and possibly short kits in the near future(as fast as I can!).I know a fellow who has access to a water jet CNC cutter that will cut almost anything,I think I will send him a sample of the foam and see how well it works.The biggest problem will be digitizing a plan.A hand drawn plan will be no real problem,just take some time.
Old Mar 09, 2002, 11:08 PM
opualuan is offline
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
if you send me a hand-drawn plan (scanned or snail-mailed) I can redraw them in cad for you... construction looks straightforward and simple, that's a good thing.
Old Mar 09, 2002, 11:09 PM
lensrc is offline
lensrc's Avatar
Kansas City area
Joined Nov 2001
I just got the material on monday,built the plane over the last few day's.Will have plans available in a couple weeks,hopefully.
What would a plan for this be worth?I want to be fair,but this is the first time I've had a plane worthy of selling plans for.
Old Mar 09, 2002, 11:11 PM
opualuan is offline
high-speed freak
opualuan's Avatar
San Jose, CA
Joined Sep 2001
like i said, good job, but I don't think you're going to be able to sell any plans... if you kit it, maybe you could sell some... I thought you were planning to share it...
Old Mar 09, 2002, 11:14 PM
lensrc is offline
lensrc's Avatar
Kansas City area
Joined Nov 2001
It is simple.Basic sheet and former.I have to work out a better way of fastening the center cabane to the fuse.the wing bolts on on the bottom,but I used tape on the top.Some suggested velcro but I feel that might loosen during flight.I believe I will lengthen them an use small nylon bolts into the side of the fuse.
Old Mar 09, 2002, 11:16 PM
lensrc is offline
lensrc's Avatar
Kansas City area
Joined Nov 2001
I already have two guys wanting kits and another wants plans,but they did see it fly tonight.
Old Mar 10, 2002, 01:53 AM
Mikey-flies is offline
Find More Posts by Mikey-flies
Alberta, Canada
Joined Sep 2001
I'd like the material. Any news on availability, weight, strength, grain etc?
Mikey-flies is offline Find More Posts by Mikey-flies
Discussion Bought a used TREX whaddya think? Photoflight Mini Helis 5 Nov 02, 2006 05:11 PM
Discussion Whaddya think im-sad Foamies (Scratchbuilt) 25 Sep 15, 2006 12:22 PM
Bipe must think its a pylon racer Doc Data Foamies (Kits) 0 Dec 30, 2004 04:27 PM
Whaddya think.... AirGar Scale Fuel Planes 0 Mar 04, 2003 08:37 AM
My own speed 400 design, whaddya think? g00bd0g Power Systems 7 Jul 18, 2001 02:53 PM
