Old Mar 24, 2016, 09:59 PM
ocso295 is online now
Find More Posts by ocso295
keeping it legal
United States, MI, Livonia
Joined Jun 2011
70mm 2100kv motors...anyone balancing? 5s okay?
Hey guys...I have a large A10 that came with 2100kv motors and 6 blade fans on it...It was designed to run on 6s....Well...my 6s battery is gone and I have a pair of 5s batteries....also I am trying to get that jet wooosh sound so I bought a set of 12 blade fans and housings My model weighs 2.4kg.....will I be okay running the 5s with both motors?
Anyone balancing these units? I see Don has closed up shop
ocso295 is online now Find More Posts by ocso295
Old Mar 24, 2016, 10:08 PM
4stripes is online now
Find More Posts by 4stripes
4stripes's Avatar
Canada, ON, Burlington
Joined Jan 2009
Sounds like a good match to me. Best to monitor the power with a watt meter to be sure you aren't pushing the ESCs too hard.
4stripes is online now Find More Posts by 4stripes
Old Mar 24, 2016, 10:11 PM
keeping it legal
Joined Jun 2011
TY 4stripes...was just looking at some of your old posts....Do you have one of those dynamic balancers?
Old Mar 24, 2016, 10:21 PM
4stripes's Avatar
Joined Jan 2009
No. A friend let me try his Dynex but I found it a time consuming process compared to more traditional methods. Clocking the fan and then the spinner gives surprising results fairly quickly. Fine tuning with trial weights of duct tape then shows where extra weight is needed in the spinner.
Old Mar 25, 2016, 07:24 PM
keeping it legal
Joined Jun 2011
By clocking you mean mark the shaft and the fan....mount your phone to it with a vibration sensing app...turn it 45degrees..do it again....that?
Old Mar 25, 2016, 07:32 PM
4stripes's Avatar
Joined Jan 2009
Yes and no. Mark a reference position on the fan and adapter or motor if out runner. Run the fan mounted at each of the clock positions to find the smoothest running position. You will notice it running smoother in one particular orientation (exactly opposite to the roughest running position). I use my fingertip to measure the vibration touching the exterior of the shroud. You don't need high power. Don't use high power until you get the fan as finely balanced as possible or it will rub and possibly fly apart.
Sold 70mm 14 blade EDF and motor for 4-5S F106DeltaDart Aircraft - Electric - Jets (FS/W) 2 Mar 07, 2016 07:21 PM
Sold 2x 2970 3000kv motors for 70mm good for up to 5S FISHTROUT Aircraft - Electric - Power Systems (FS/W) 3 Aug 24, 2015 07:25 AM
Sold Losi Xcelorin 1/8 2100KV Brushless Motor & ESC Combo 3-5s Nice 2.0 3.0 Buggy Video! Independentjrc Cars - Trucks and Parts (FS/W) 3 Jan 31, 2015 12:28 PM
Wanted dual 70mm + motors for 5s Setup ricebowl1988 Aircraft - Electric - Jets (FS/W) 0 Apr 20, 2014 11:52 AM
Sold Stock 70mm LX EDF units & 2100KV Motors brandonmoon Aircraft - Electric - Jets (FS/W) 1 Dec 19, 2013 02:57 PM
