Old Apr 07, 2013, 01:38 AM
SoloProFan is offline
Find More Posts by SoloProFan
Fan of just about anything RC
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Help!
Absima Team C Minion alternate body mounting system
Hi
Recently bought the Absima Team C Minion 4WD buggy, based on some rave reviews from other drivers. After some "hiccups" due to a few slips in quality control (one dog bone was too long, wheels needed some adjustment to run true, etc) I've had a few nice drives with it, it handles well and so far I'm pleased with it. Spares are also much cheaper than for most of my other cars, keeping the TCO down, should I break something eventually.
However, the way the body is mounted on the chassis is giving me a headache. Front it uses the classic body mount with body clip, but the rest of the body is held in place with velcro. Normally there is nothing wrong with that, except the self adhesive on the velcro won't stick to the plastic on the chassis for long. I tried cleaning the surface, fixing the velcro with CA, or with Bison contact glue. but the velcro keeps coming loose, and the remaining glue can easily be removed from the surface, leaving it unscathed. The plastic doesn't seem to accept any adhesive, whether it's glue or self adhesive stuff, so I'm loooking at alternate ways to hold the body in place.
Perhaps there are more Minion drivers that ran into the same issue, if so, I'm curious to hear about their ideas. I have some ideas as well, but each requires ordering spare parts from other cars, that may not fit at all.
SoloProFan is offline Find More Posts by SoloProFan
Old Apr 09, 2013, 02:07 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
No Team C 4WD drivers here?
Old Apr 09, 2013, 02:40 PM
SporadicIdiocy is offline
Find More Posts by SporadicIdiocy
Sakura Ultimate graduate
SporadicIdiocy's Avatar
Richmond B.C. Canada
Joined Oct 2007
Have you tried shoe goo? I have modded my turnigy 1/16 buggy to use velcro for the body, I used shoe goo to attach the velcro strips to the plastic chassis and it's holding up fine so far.
SporadicIdiocy is offline Find More Posts by SporadicIdiocy
Old Apr 09, 2013, 03:33 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
I did try a glue that is commonly used here to even glue things to a stone wall, but no Shoe Goo. I believe it's not commonly available in Europe, but I could try buying it online.
I'm also considering putting 2 extra body posts on the rear edge of the chassis, just like you see on many 2WD cars. But that would mean cutting holes in the chassis, and if possible I would like to prevent this.
Old Apr 09, 2013, 10:56 PM
Joined Oct 2007
Well there's Amazing Goop, Zap-a-dap-a-goo and some other Shoe Goo equivalent out there.
Not sure if any is available in the Netherlands though. If all else fails try searching for contact adhesive in a hardware store or bicycle tube glue in a cycling store.
BTW did you try scratching/roughing up or scoring the plastic surface you're trying to glue on? Try scoring a checker pattern on it and then apply the glue.. maybe that'll help with adhesion a little better.
Old Apr 10, 2013, 12:33 AM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Thanks for the added suggestions. The Bison glue I mentioned is in fact a contact glue, that can even glue bricks, at least in theory.
I did try roughening up the surface with sanding paper, and using rubbing alcohol to remove any dirt from the area where the glue should go. When dried, you can simply rub the glue off. I've contacted the manufacturer of the car to ask what kind of plastic was used for the chassis. That would make it easier to find a compatible glue, I guess.
Old Jun 25, 2013, 02:43 PM
BlueBorderRC
A moderator felt this post violated the following rule: Highly Offensive Content (Immediate suspension). It is temporarily hidden while BlueBorderRC edits it.
Old Jun 25, 2013, 03:07 PM
SoloProFan's Avatar
The Netherlands
Joined Jul 2010
Now please count to ten, or further, if needed. This is no way to behave to anyone, not even if the things you accuse me of would have been true, which they clearly are not in this case.
Btw, I now noticed I didn't update this thread with the latest development. I used another type of "contact glue" on the velcro, to secure it to the chassis, and up till now this held. Surprisingly, on a second Minion I have (I use these as my bash cars) there was no issue with the velcro coming loose of the chassis, so perhaps the problem was just limited to my first car, or a certain batch of cars at most.
Though I still prefer horizontally mounted body posts, where you slide the body on, like on the Lazer ZX 5 for instance, this system with velcro comes in second place close to that.
Sold AP Hornet 09 R/C Engine " NIB " with Mount alfajet Aircraft - Fuel - Engines and Accessories (FS/W) 2 Apr 03, 2013 06:06 PM
Sold Team Associated TC4 Body & Parts Buzz_Man Cars - Cars and Parts (FS/W) 1 Apr 02, 2013 05:53 AM
For Sale Team Associated RC18B Buggy team RTR with Mamba brushless system justin4u Cars - Cars and Parts (FS/W) 0 Mar 31, 2013 07:26 PM
Discussion Alternative prop mount for NTM Prop Drive 35-36A 910Kv motor? nikivan Multirotor Talk 7 Feb 20, 2013 09:43 PM
Sold TH Crack Yak Lite Alternative power system NIB rc4u Aircraft - Electric - Power Systems (FS/W) 2 Jan 06, 2013 09:11 PM
