Old Aug 18, 2003, 03:02 AM
Stan Myers
Stan Myers
Guest
n/a Posts
[RCSE] Will 3M clear tape do any damage to a molded wing?
I recently purchased a used molded sailplane the previous owner had taped
the wing surfaces at the tip-main panel junction. Is this tape to protect
the surface when applying tape to hold the tips to the center panel?
Stan
All outgoing email is virus scanned by Norton
RCSE-List facilities provided by Model Airplane News. Send "subscribe" and "unsubscribe" requests to soaring-request@airage.com. Please note that subscribe and unsubscribe messages must be sent in text only format with MIME turned off.
Old Aug 19, 2003, 03:13 AM
Andrew E. Mileski
Andrew E. Mileski
Guest
n/a Posts
Re: [RCSE] Will 3M clear tape do any damage to a molded wing?
> the surface when applying tape to hold the tips to the center panel?\
Usually. Prevents the paint comming off with frequent tape removal.
I don't know about 3M clear, as I use cheap vinyl electrical tape
from Home Depot which is more gooey than sticky... comes in colors
too. The goo comes off with orange cleaner.
Andrew E. Mileski
Ottawa, Canada
http://isoar.ca/
Discussion How do I fix a twisted molded wing? Pitchspeeder Composites Fabrication 15 Jan 15, 2007 05:39 PM
How do you join a hollow molded wing? I'm Rick James Composites Fabrication 6 Jul 31, 2005 11:44 AM
Question How do you prep a molded wing for horn? hbielich High Performance 2 Aug 20, 2004 12:33 AM
3M Clear Duct Tape chemsurfer Electric Plane Talk 9 May 10, 2003 09:59 PM
What tape do I use to hold a wing together RandyK1 Electric Sailplanes 6 Oct 22, 2002 08:58 AM
