Old May 15, 2015, 07:25 AM
jetigm is offline
Find More Posts by jetigm
Joined Aug 2009
Help!
Current sensor @ MOSTET's
This is high power current sensing module for the Ardupilot.
The question is - may I use a MOSFET's in parallel against of the current sensing resistor? I want to design a custom Power Module with the cut off protection to save the LiPo when fully discharged. So I think to use a MOSFET's as a current sensor and at the same time as a key to cut off the load.
Conceptually - is it possible to do in this way?
jetigm is offline Find More Posts by jetigm
Old May 15, 2015, 11:02 AM
speedyb_tx is offline
Find More Posts by speedyb_tx
speedyb_tx's Avatar
United States, TX, Van Alstyne
Joined Dec 2014
Are you wanting to make a LiPo discharger ?
or just LiPo voltage sensing
speedyb_tx is offline Find More Posts by speedyb_tx
Old May 15, 2015, 11:42 AM
jetigm is offline
Joined Aug 2009
The question is closed. The resistance of a MOSFET's highly depends of it's temperature so large inaccuracy will be in the current sensing system.
Old May 15, 2015, 02:09 PM
speedyb_tx's Avatar
Joined Dec 2014
so are you going to give up on the project, or seek the correct way of doing it ?
Sold FrSky X Serie s.port Telemetry Lipo, GPS and 150a Current Sensor divemasterphil Aircraft - General - Radio Equipment (FS/W) 2 Apr 18, 2015 03:16 PM
Discussion FrSky Current Analog Current Sensor jsut210 Radios 4 Dec 07, 2014 10:29 AM
Discussion Difference between Tiny OSD III w/ 60a Current Sensor vs 80a current sensor? sonicweapon FPV Equipment 1 Nov 02, 2013 05:22 PM
Sold GPS and Current Sensor For Cyclops OSD's Johnnymeg FPV Equipment (FS/W) 0 Jun 23, 2013 11:56 PM
Help! BLACK STORK OSD current sensor's photo fotopilotas.lt FPV Talk 1 May 07, 2010 11:33 AM
