Old Aug 17, 2012, 09:49 PM
AndyRice_WI is offline
Find More Posts by AndyRice_WI
Helmet...check!!!
AndyRice_WI's Avatar
United States, WI, Prairie du Sac
Joined Sep 2010
JR9503 Flame Out
I was just doing some downloads and uploads (back ups) on my JR9503... I was going to dump a program into an empty file... I chose one that said something like... 1Modulation.
When I did that, the screen just flipped out. Now I've got no power.
Thoughts?
AndyRice_WI is offline Find More Posts by AndyRice_WI
Old Aug 17, 2012, 11:05 PM
tkallev is offline
Find More Posts by tkallev
LSF303 / AMA Life Member
tkallev's Avatar
USA, IL, Wheeling
Joined Jan 2003
Check the fuse on the main board ... you have to take the back off the tranny to get to it.
tkallev is offline Find More Posts by tkallev
Old Aug 17, 2012, 11:39 PM
Helmet...check!!!
Joined Sep 2010
hmmm. ok. I'll do that. Now I'm scared.
Old Aug 18, 2012, 12:37 PM
BigSwede is offline
Find More Posts by BigSwede
Ninja Master
BigSwede's Avatar
United States, CA, Thousand Oaks
Joined Feb 2007
I had something similar happen to a 10X years ago. Replaced the fuse and everything worked fine. If it doesn't fix the problem, know that JR service is great.
BigSwede is offline Find More Posts by BigSwede
Old Aug 18, 2012, 05:57 PM
Helmet...check!!!
Joined Sep 2010
Yes they are. I talked to them this morning... Boxed up to ship. It appears to be a bad LCD display. Off to them on Monday.
Old Aug 20, 2012, 12:52 PM
pete914 is online now
Find More Posts by pete914
pete914's Avatar
United States, VA, Richmond
Joined Jan 2010
This has happened twice on my JR 9303. That board fries easy. If you let the voltage drop too low (i.e leave it on) this will cause same thing.
Bummer but easily fixed ($150 if it's out of warranty)
pete914 is online now Find More Posts by pete914
Old Oct 12, 2012, 01:37 PM
Tom Eutsler is offline
Find More Posts by Tom Eutsler
Tom Eutsler's Avatar
Asheville,NC
Joined Jun 2002
Modulation
Thoughts?
I turned mine at field ,after charging overnight and WOW all my models
had the words Modulation and a bunch of weird sqiggles- tried to turn off Tx
and IT WOULD NOT
So, unplugged battery - called HH this am " never heard of that or seen the problem "
SO it is on the way back to the Jr folks
Tom Eutsler is offline Find More Posts by Tom Eutsler
Discussion DJI WK_M / Axi 2814/22/MGM compro 40A/AR7010/Dx7--on Quad flame wheel to try out.. . alxlc UAV - Unmanned Aerial Vehicles 3 Nov 26, 2012 01:15 PM
Question Nitro engines flame out N.E.R.F Engines 22 Jul 20, 2012 02:43 PM
Sold FLAME OUT! Extinguisher for inside your jet!!! unclegeorge Aircraft - Fuel - Jets (FS/W) 9 Mar 31, 2012 05:59 PM
Sold FLAME OUT! Extinguisher for inside your jet!!! unclegeorge Aircraft - Fuel - Jets (FS/W) 9 Mar 26, 2012 10:03 PM
Close call, flame out, question himagain Electric Heli Talk 2 Aug 11, 2002 09:33 PM
