Old Jun 15, 2003, 03:27 PM
mad mike is offline
Find More Posts by mad mike
I crash, therefore I FLY!
mad mike's Avatar
Spring Hill, FL
Joined Feb 2003
GWS EPS help for the feeble-minded!
So, I'm sitting here looking at this GWS EPS-400C-D and an EP 1080 prop.
And it occurs to me that I have *no* idea how to put the prop & spinner on! I guess the GWS people thought they'd be dealing with people that had a "higher than room temperature" IQ.
Wrong!
On the output shaft, from the gearbox end, there sits a nut, followed by a flat washer, then a split washer, then the last nut. And the spinner itself, is out on the end.
Where, in this sequence, does the prop go?
If I'd seen a forum titled, "Model Mechanics for Dummies," I'd have posted this question there.
Enlighten me, oh Learned Ones!
Mike S.
(aka "mad mike")
Spring Hill, FL
I crash, therefore, I FLY!
There is no one true way.
mad mike is offline Find More Posts by mad mike
Old Jun 15, 2003, 04:48 PM
STL.SF is offline
Find More Posts by STL.SF
St Charles Flyer
St Charles, IL
Joined Sep 2002
Mike,
The prop, make sure writing is out facing you, goes on the nut by the motor, then the washers, then the last nut and spinner. The first nut fits into a molded nut shaped cavity in the prop.
STL
STL.SF is offline Find More Posts by STL.SF
Old Jun 15, 2003, 05:51 PM
mad mike is offline
mad mike's Avatar
Spring Hill, FL
Joined Feb 2003
STL,
Tried that, it worked, all is Right with the World!
Thank you *very* much!
This one one of those "obvious things" that just seems to be a bit elusive, until it jumps right up and smacks you in the face.
Mike S. <--- once again proving that the only "Dumb Question" is the one that goes unasked!
(aka "mad mike")
Spring Hill, FL
GWS gearing help for a newb Timeetyo Power Systems 1 Jun 21, 2003 01:10 AM
GWS EPS 400C for Slowstick: What gear? Hank_Scorpio Power Systems 10 Apr 09, 2003 05:55 PM
Help make sense of GWS prop chart for EPS-300C sizam Parkflyers 9 Oct 04, 2002 04:27 PM
FS: GWS EPS 300 for Zero rkissin Aircraft - Electric - Airplanes (FS/W) 0 Apr 15, 2002 10:08 AM
GWS inner adpters for GWS IPS & EPS converted with other Propellers! GWS4CEO Parkflyers 5 Dec 12, 2001 12:55 PM
