Old Apr 17, 2006, 10:35 PM
xFxLxYxExR is offline
Find More Posts by xFxLxYxExR
ParkFlyer
xFxLxYxExR's Avatar
Joined Nov 2005
Thunderpower balancing
Hello everyone,
I recently bought 2 Thunderpower 3s 1320mah 1p packs. Now, i dont have a watt meter and still need to get one and i know thats prety much a need but, do I HAVE to have a balancer for theas 1p packs or is ot mostly for 2p and up? Thanks for your help.
XF
xFxLxYxExR is offline Find More Posts by xFxLxYxExR
Old Apr 18, 2006, 06:28 AM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
You need to balance anything 2S and up no matter what the P.
RC
RC Man is offline Find More Posts by RC Man
Old Apr 18, 2006, 09:27 AM
everydayflyer is online now
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
xFxLxYxExR
More important than a balancer is a watt / amp meter. Do not run your LiPolys at past max. ratings ever and try to stay below 70% of max. rating. Do not discharge below 3.7 V per cell open (resting ,no-load) and they should stay in balance well. You can check each cells voltage and charge each cell separately as a single cell to get them in balance if found to be out. A balancer is convent and is an additional safety device as well but not entirely necessary , especially if you have only a few LiPolys and do not push them to their limits.
Charles.
everydayflyer is online now Find More Posts by everydayflyer
Old Apr 19, 2006, 12:44 AM
ParkFlyer
xFxLxYxExR's Avatar
Joined Nov 2005
ya, i actualy only use 10 amps out of em, rated for 27 amps i belive.
Old Apr 21, 2006, 12:48 AM
Chaser is offline
Find More Posts by Chaser
Chaser's Avatar
Hinesville, Ga
Joined Nov 2005
TP 205 balancer interrogative
Would the TP-205 balancer work with a TP 3S2P 4200 mAh "Pro Lite" 11.1V LiPoly?
Chaser is offline Find More Posts by Chaser
Old Apr 21, 2006, 07:37 AM
Southern Pride
TP-205 Balances 2S-5S Lipolys and the TP ProLite LiPolys which have factory balancing leads plug righ into the 205.
Charles
Old Apr 21, 2006, 08:33 AM
coro is offline
Find More Posts by coro
Slovakia
Joined Apr 2005
But voltage after flight, after some time to rest, is what is also very important - if You will discharge lipos them too deep, unbalance will occur.
Unbalance is in most cases clear sign of damage. Until You will not damage Your Lipos, pack will remain balanced.
Some few unbalance could occut after months of usage or storage, caused by different rate of selfdischarge, but it counts in few single mAh and can be corrected by separate charge of each cell.
What I am allways suggesting, is protection agaist occasional failures (bad charger settings, charge of punctured cell or so), using any device (most balancerrs) that will authoritatively stop charger, or at least, scream loud enough to wake You up in case of any danger.
coro is offline Find More Posts by coro
Old Apr 21, 2006, 10:05 AM
Chaser is offline
Chaser's Avatar
Hinesville, Ga
Joined Nov 2005
Another
Charles
Thanks all for the quick response!
I already have the TP-205, and a 3s1p 2100 PL. Had two 2100 PLs, but left one connected to the receiver on the bench for 24 hours! Of course it was ruined.
I assume from your answer and the statement on the site that the 3s2p charges as a 3 cell that the 205 would work. Thanks.
If I may ask another:
Since I already have a plane for the 2100PLs, I guess I could buy more 3s1p 2100PLs and use them as a 3s2p. How would they need to be connected to become a 3s2p?
Thanks in advance
