Old Jul 01, 2002, 05:24 PM
Brian_Bills is offline
Find More Posts by Brian_Bills
Maple Valley WA, USA
Joined Jun 2002
Speed controls???
What is the best speed control for the Speed 300 on the Hornet?
If I get enough money I might upgrade to a Hacker 20-22S Brushless motor. What ESC would be best for that? I would kinda like a governor on it, but its not required.
Brian_Bills is offline Find More Posts by Brian_Bills
Old Jul 01, 2002, 09:00 PM
RMihara is offline
Find More Posts by RMihara
Aerial Shutterbug
RMihara's Avatar
San Mateo, California, United States
Joined Nov 2001
For the Speed 300 get a Castle Creations - Pixie 7P . It is a programmable controller which means you can set the low voltage BEC cutoff to match what battery pack (NiCad, NiMh, Li-Ion) you are using, or turn off the cutoff feature for heli use.
Currently the Schulze 18he or 20he ESC/controller comes in near the top of the list pending release of the new Castle Creations
Phoenix-10 controller. The beauty of this new controller is that it allows you to set the cutoff voltage, current limiting, Brake, Throttle (FP helis/aircraft, and fixed (governor mode) for CP helis) and motor timing. It also will cost less than the Schulze.
Regards,
Roger
Note: error, changed Phoenix-25 to Phoenix-10
RMihara is offline Find More Posts by RMihara
Old Jul 01, 2002, 09:18 PM
Joined Jun 2002
Could you expand on cutoff voltage, current limiting, Brake for the ESC features? I fly a Piccolo and a gasser currently and have no idea what these mean and how to set them.
Old Jul 01, 2002, 09:30 PM
Joined Jun 2002
When will the Phoenix 25 be avaliable and how much will it be?
Old Jul 01, 2002, 11:09 PM
jk is offline
jk
Find More Posts by jk
jk
jk's Avatar
Huntington Beach, CA
Joined Apr 2001
i think that the Phoenix 10H is a large enough BL esc for the Hornet/B20-22s combo. i have an early non-governor Phoenix10 that i've been beta testing and it worked fairly well.
i also have 2 Schulze 18be's and an 18he. i actually prefer the 18be (non-gov) for duration and power out of all of my BL escs though.
jk is offline Find More Posts by jk
Old Jul 02, 2002, 12:58 AM
RMihara is offline
Aerial Shutterbug
RMihara's Avatar
Joined Nov 2001
John thanks for catching my error on the Phoenix controller.
Brian, in regards to your questions;
Battery Cutoff: This is where an ESC will shutdown operation of a motor due to low output voltage from your battery pack. This saves your batteries as discharging them too low can cause irreparable damage.
Current limiting can come in handy if you were to 'stall' out a motor (read crash without shutting down throttle) and will help prevent a meltdown of your wiring/motor/etc.
Brake circuitry is used to stop a motor (works typically by using the back EMF of a motor). Not necessary for a heli but more so for fixed wing aircraft(and cars obviously) where you would want to halt the rotation of the prop for those models without landgear.
If you do get an ESC with a brake, it is highly recommended you either disable the brake circuitry manually or just get an esc without one (or programmable).
For your 'PIC' the above would apply but for your gasser it wouldn't.
These features mentioned only apply to what I've learned about the Phoenix controller so far.
Regards,
Roger
Old Jul 02, 2002, 01:15 AM
Joined Jun 2002
Wouldn't the Phoenix 10 be more suited for the Hornet rather than the 25? The 25 is heavier and looks as though it's "geared" at more amps?
Thanks for your replys
BEC Speed Controls Schweizer fan Electric Plane Talk 3 Jul 01, 2001 06:58 PM
"Tapping Off" Cells for BEC Speed Controls shv2sail Electric Plane Talk 9 Jun 28, 2001 12:20 PM
Who repairs speed controls?? Don Sims Electric Plane Talk 4 Jun 27, 2001 07:34 AM
Dual Speed Controls on a Twin Jet Ben C Power Systems 5 Jun 22, 2001 01:21 AM
Speed Controls Airnut 2 Power Systems 0 Apr 23, 2001 07:16 PM
