Old Sep 20, 2015, 04:38 PM
flying ferret is online now
Find More Posts by flying ferret
United States, FL, Sebastian
Joined Aug 2014
urethane over foam umx carbon cub
September 8, 2015 (1 min 55 sec)
the wing is actualy a layer of 1/16 sheet bottom 1/32 top and ribs in between. the tail feathers are 2 layers 1/32 balsa epoxied together with the grain 90 degrees . the foam was lightly wiped with finishing epoxy fine sanded then another coat of finishing epoxy with the excess wiped off . than a fine mist of house of kollor adhesion promoter then orion silver than the red using an infinity airbrush with a .6 needle . than a coat of two part clear urethane , wet sanded than carefully polished each part on my makita polishing wheel . i placed the polishing machine on the floor and held it between my knees then carefully polished each part. and yes it flies even better than stock . and came in at 4.25 oz. the balsa components added most of the weight not the paint.. thanks for looking
flying ferret is online now Find More Posts by flying ferret
Discussion Urethane Coating Foam?. Sunbiz1 Electric Plane Talk 12 Apr 30, 2015 12:39 PM
Discussion 3D-Printed Mold for casting Urethane Foam. methuso Scratchbuilt Indoor and Micro Models 5 Nov 12, 2014 01:11 AM
Discussion Vacuum forming over high density urethane foam-safe or toxic gas release? Ed Waldrep Composites Fabrication 2 Nov 07, 2007 10:50 PM
Question Urethane Foam mgroves Composites Fabrication 0 Feb 13, 2007 12:35 PM
Polyethylene and Urethane foam? hardlock Foamies (Kits) 0 Dec 05, 2001 08:47 PM
