Old Mar 22, 2013, 10:06 PM
grfcon is offline
Find More Posts by grfcon
chronic in training
grfcon's Avatar
L.A. beautiful san fernando valley
Joined Nov 2008
Help!
what to use to mask epo using liquitex paint
trying to to diff colors top and bottom... have rubbed epo with denatured alcohol..sprayed first color... masked it with painters tape that I had put on the carpet first to lessen some of its tackyness... but paint still came off when I peeled it... any suggestions??? should I spray a clearcoat over the first colored side then add the tape ????? maybe that would work.. what is a good brand of clearcoat that works with liquitex btw??
grfcon is offline Find More Posts by grfcon
Old Mar 28, 2013, 05:36 PM
wizard of odd is offline
Find More Posts by wizard of odd
wizard of odd's Avatar
Australia, WA, Kalgoorlie
Joined Apr 2011
The problem with EPO is getting paint to adhere to it- the surface needs to be scuffed so the paint can key to it, or you need some kind of adhesion promoter on the EPO.
I'm experimenting with a light coat of (foam safe) 3M Super 77 as an adhesion promoter and, while the verdict is still out, initial results look promising. I started a thread in the Foamies kits section called "Priming EPO- Eureka moment?" which documents some of the experimenting.
wizard of odd is offline Find More Posts by wizard of odd
Help! what is a safe spray can paint for EPO foam ? grfcon Foamies (Kits) 9 Mar 13, 2013 04:47 AM
Question liquitex on epo questions? grfcon Painting and Finishing Tips 0 Mar 03, 2013 10:08 AM
Discussion Paint bleeding under masking on foam. Watdazit Painting and Finishing Tips 11 Feb 22, 2013 11:15 PM
Question What should I use to paint monocote? Rhea The Builders Workshop 6 Feb 08, 2013 03:43 PM
Discussion How to remove decals from EPO planes and what paint can I use on EPO? Stefan_Go Beginner Training Area (Aircraft-Electric) 3 Sep 30, 2012 09:27 AM
