Old Jan 29, 2016, 05:07 PM
Miniclip12 is offline
Find More Posts by Miniclip12
Joined Jan 2013
Hello, I am having trouble flashing the f20a escs from h-king. I had the same problem as this earlier post
Originally Posted by kiliam View Post
I am having a problem, trying to flash some hobbyking f-20a.
I am using an arduino with arduinosip sketch and i think i have everything well wired but using kkflashtool just gives me this:
Flash the firmware file.
Flashing firmware from file.: C:\Users\cortez\Downloads\tgy_2012-03-01_2e27c08\bs_nfet.hex
C:\Users\cortez\Downloads\kkmulticopterflashtool_0 .60beta10\lib\avrdude\windows\avrdude.exe -C C:\Users\cortez\Downloads\kkmulticopterflashtool_0 .60beta10\lib\avrdude\windows\avrdude.conf -p m8 -P COM3 -c arduino -B 8 -e -U flash:w:C:\Users\cortez\Downloads\tgy_2012-03-01_2e27c08\bs_nfet.hex:i
avrdude.exe: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.02s
avrdude.exe: Device signature = 0x1e950f
avrdude.exe: Expected signature for ATmega8 is 1E 93 07
Double check chip, or use -F to override this check.
avrdude.exe done. Thank you.
Error during writing flash.
Any suggestion?
so I tried the solution of addin the 10uf capacitor here
Originally Posted by alteskind View Post
No, they didnt switch the chip, and it wont brick the ESC, as it wont flash the ESC .
the F-20A has an atmega8.
there is no problem to flash it using an arduino.
but u need a 120ohm resistor or a small capacitor (>10μF ) to disable autoreset on arduino
Reason for your problem: if you try to flash it with an arduino, unless switching arduino auto-reset off, the flashprog will flash your arduino instead of the ESC.
the solution is adding a 20μF capacitor between the RESET and GND lines (at arduino nano )
i used my arduino nano to flash my turnigy 9x, and it worked fine with this patch.
another way to disable autoreset using a resistor is described here. as i didnt have a 120ohm resistor, i did it the capacitor-way
http://www.arduino.cc/playground/Mai...rialConnection
those arduinoos are soooo useful, i like them.
but now I am getting this error:
/Applications/kkMulticopter Flash Tool.app/Contents/Resources/Java/lib/avrdude/mac/avrdude -C /Applications/kkMulticopter Flash Tool.app/Contents/Resources/Java/lib/avrdude/mac/avrdude.conf -p m8 -P /dev/cu.wchusbserialfa130 -c arduino -b 57600 -e -U lfuse:r:/Users/Abhishek/Library/Preferences/kkMulticopterFlashTool//lfuse.hex:r -U hfuse:r:/Users/Abhishek/Library/Preferences/kkMulticopterFlashTool//hfuse.hex:r
avrdude: stk500_recv(): programmer is not responding
avrdude done. Thank you.Error during reading of high fuse.
Flashing of firmware aborted.
I have tried everything and nothing has worked. plz help.im so confused
Miniclip12 is offline Find More Posts by Miniclip12
Old Feb 22, 2016, 03:46 PM
iscle is offline
Find More Posts by iscle
Spain, CT, Barcelona
Joined Mar 2015
Hi, I've got a Red Brick 100a BEC ESC which I bought to use with a e-longboard i'm building. I've tried simonk firmware, which is way better than the stock frimware, but i still can't get it to do what i want.
I want the ESC to be able to brake gradually, because now, when it breaks, it uses full power, but i want to be able to control the brake power with the throttle stick, just like in a RC car. I know it's possible with the simonk firmwre, because this guy has done it (
Redbrick 70a esc brake test (0 min 27 sec)
), but he did modify the firmware to acomplish that.
Does somebody know how can I get that same feature? The ESC he is using is the same as mine, so it should be possible to do it just by modifying the firmware. The firmware for my board is the "rb70a2.hex" one.
Thanks.
iscle is offline Find More Posts by iscle
Old Feb 22, 2016, 05:56 PM
pianori is offline
Find More Posts by pianori
Joined Feb 2007
take out the active braking, dampened light, or oneshot.
That should do it. Also, if you are using a flight controller, like APM make sure to disable the braking option in it firmware.
pianori is offline Find More Posts by pianori
Old Feb 23, 2016, 04:16 PM
iscle is offline
Joined Mar 2015
What do you mean? I've tried almost all the options except comp_pwm or something like that that is regenerative braking and i can't get it to work like in the video....
If it's not a problem, could you explain it a bit better?
Thanks a lot!
Old Mar 01, 2016, 12:21 AM
Groser1983 is offline
Find More Posts by Groser1983
Russia, Saratovskaya oblast', Balakovo
Joined Dec 2015
HobbyKing YEP 30A
Hi! Fell into the hands of HobbyKing YEP 30A controller. ESC is built on atmega168pa. I drew a diagram of the controller. Could you add it to the firmware? Thanks in advance!
Groser1983 is offline Find More Posts by Groser1983
Old Mar 11, 2016, 06:00 PM
Lob0426 is offline
Find More Posts by Lob0426
Lob0426's Avatar
United States, CA, Susanville
Joined Feb 2013
Having trouble figuring out what is the proper firmware for my ESC's. I think they are a HobbyWing 30A "Guardian. The paper that came with them was in Chinese. They could be "Pentium". I could not find any ESC picture that exactly matched the components on the board.
ESC from RioRand
I had one I connected reverse polarity and does not work. I used a HK flash tool with a HK USBASP programmer. I got the following messages.
Flash the firmware from repository.
Flashing firmware from file.: C:\Users\xxxxxxx\Downloads\RC\kkflash\tmp\tgy.hex
C:\Users\xxxxxxx\Downloads\RC\kkflash\lib\avrdude\ windows\avrdude.exe -C C:\Users\xxxxxxx\Downloads\RC\kkflash\lib\avrdude\ windows\avrdude.conf -p m8 -P usb -c usbasp -B 8 -e -U flash:w:C:\Users\xxxxxxx\Downloads\RC\kkflash\tmp\ tgy.hex:i
avrdude.exe: set SCK frequency to 93750 Hz
avrdude.exe: warning: cannot set sck period. please check for usbasp firmware update.
Reading | ################################################## | 100% 0.00s
avrdude.exe: Device signature = 0x1e9307
avrdude.exe: erasing chip
avrdude.exe: reading input file "C:\Users\xxxxxxx\Downloads\RC\kkflash\tmp\tgy.hex "
avrdude.exe: writing flash (8192 bytes):
Writing | ################################################## | 100% 2.43s
avrdude.exe: 8192 bytes of flash written
avrdude.exe: verifying flash memory against C:\Users\xxxxxxx\Downloads\RC\kkflash\tmp\tgy.hex:
avrdude.exe: load data flash data from input file C:\Users\xxxxxxx\Downloads\RC\kkflash\tmp\tgy.hex:
avrdude.exe: input file C:\Users\xxxxxxx\Downloads\RC\kkflash\tmp\tgy.hex contains 8192 bytes
avrdude.exe: reading on-chip flash data:
Reading | ################################################## | 100% 1.98s
avrdude.exe: verifying ...
avrdude.exe: 8192 bytes of flash verified
Flashing of firmware was successful.
I included a picture of the ESC without the wrapper. The other side is a thick aluminum heat sink.
So do I risk trying this on a working ESC? I do have an extra, not being used.
Lob0426 is offline Find More Posts by Lob0426
Old Mar 15, 2016, 06:30 PM
tascheri is offline
Find More Posts by tascheri
Fly like never crash as always
tascheri's Avatar
Rio de Janeiro
Joined Mar 2007
hi. does anyone know what fw comes with the t-motor 25A opto escs. I needed to turn braking on but I cant' seem to find the right fw on it. tried searching this thread, the internet but no luck. thanks.
tascheri is offline Find More Posts by tascheri
Old Mar 16, 2016, 08:18 PM
happy rc is online now
Find More Posts by happy rc
Joined May 2013
ESC from RioRand
i flashed this esc , it work very boring , speed THR slow . i think should keep orginal firmware .I also looking for orginal this esc
happy rc is online now Find More Posts by happy rc
Old Mar 22, 2016, 06:34 AM
saxon0010 is offline
Find More Posts by saxon0010
saxon0010's Avatar
United Kingdom, London
Joined Feb 2009
Hi All,
Does anybody knows what kind of ESC is this? I would like to flash it, but I dont know, which firmware I can use...
The cover was a simple, yellow blank plastic, no marks on it.
It`s a 30A ESC.
I try to Google it, but I cant find this at all...
Saxon
saxon0010 is offline Find More Posts by saxon0010
Old Mar 22, 2016, 07:14 AM
TheQuestor is offline
Find More Posts by TheQuestor
Official Stupid Question Asker
TheQuestor's Avatar
United States, TX, San Juan
Joined Mar 2013
Originally Posted by saxon0010 View Post
Hi All,
It`s a 30A ESC.
Saxon
looks like a hobbypower 30A
Description:
TheQuestor is offline Find More Posts by TheQuestor
Latest blog entry: QTipToo.8 Part 5
Old Mar 22, 2016, 08:41 AM
saxon0010's Avatar
Joined Feb 2009
Thanks!
Attachment 8822831
Old Mar 26, 2016, 02:35 PM
amisoftau is offline
Find More Posts by amisoftau
Joined Mar 2016
Originally Posted by 0ggeeee View Post
Hey!
.equ I2C_ADDR = 0x50 ; MK-style I2C address
.equ MOTOR_ID = 1 ; MK-style I2C motor ID, or UART motor number
"MK-style" is I think referring to "Mikrokopter", who may have pioneered I2C interface ESC's.
Docs from them re. their ECS's or I2C usage should be relevant.
Hope this helps.
amisoftau is offline Find More Posts by amisoftau
Old Mar 29, 2016, 06:48 PM
nLights is offline
Find More Posts by nLights
Joined Mar 2016
Rw.rc opto blheli 20a lipo 2-4s
Trying to figure out what BLHeli firmware could possibly match with this ESC.
Label reads RW.RC OPTO BLHELI 20A LIPO 2-4S
Front
Processor: ATMEL MEGA8A
Transistors: E23
Back
Regulator: 78L05
Mosfets: AON7788
Any thoughts/suggestions?
nLights is offline Find More Posts by nLights
Old May 01, 2016, 04:52 AM
webeng is offline
Find More Posts by webeng
webeng's Avatar
Joined Dec 2013
Red Brick 50A
Hi guys,
bit of a noob taking on the flashing an ESC challenge. I've got a Red Brick 50A speedie and was wanting to go for Simon K firmware since it was making my Turnigy 2826/6 motor run a bit rough. I tested with another speedie and it was ok, so time to upgrade the firmware.
So firstly I followed the procedure laid down here from RC Tutor and managed to get AVRdude working with my USBasp programmer. I used his downloadable file tgy_2012-03-21_6af38a2.zip which contains a rb50a.hex file and after I finished my speedie no workee
The good news is that the magic smoke didn't come out and I've made further attempts using the only other hex file I could find with the same result. Now my speedie does next to nothing. It does power up the BEC circuit ok but makes no sound whatsoever at any time.
Anyone wanna not see a grown man cry?
webeng is offline Find More Posts by webeng
Old May 01, 2016, 09:04 AM
ABLomas is offline
Find More Posts by ABLomas
g0t rabb1t?
ABLomas's Avatar
Lietuva, Vilnius
Joined Jul 2011
Ancient version (seriously, 4 years? Rapidflash will get you latest hex in seconds), but still.
This does not looks like redbrick 50A (RB50A from ESC sheet: http://0x.ca/sim/esc/HK_RB50A/img_7577.jpg)
If you limited power to ESC, i would try rct50a firmware, but if not... Then go trace atmega legs to FET's (https://github.com/sim-/tgy/wiki/Ide...-configuration).
ABLomas is offline Find More Posts by ABLomas
Discussion Rctimer 30A esc cutting out with KK board Efliernz Multirotor Talk 2 May 26, 2011 02:20 PM
Sold FS: Tricopter Parts- HK401b, Pentium 30A ESC, rctimer 750kv motors pwu_1 Aircraft - General - Miscellaneous (FS/W) 2 Jan 18, 2011 09:58 PM
Sold RCTimer 2826-6 + ESC 30A New in packaging will trade as well Pics Added! planebldr Aircraft - Electric - Power Systems (FS/W) 4 May 25, 2010 09:54 PM
Discussion RCTimer 30A Programmable ESC hunter7193 Power Systems 8 Jan 02, 2010 02:27 PM
For Sale Several New ESC's - 10a, 20a, 30a - Reduced Callen9345 Aircraft - Electric - Power Systems (FS/W) 0 Apr 20, 2009 02:31 PM
