Old May 06, 2011, 08:17 PM
cloaked is offline
Find More Posts by cloaked
Why did I sell them all.
cloaked's Avatar
Australia, NSW, Sutherland
Joined Dec 2010
2x 2S In Series with EC3 and 14AUG wire?
Hey Guys
Im just getting into 4S EDF's and have a few questions.
I ahve not purchased a 4S capable charger yet nor batteries and before I do, I thought I would try out a few existing 2S Batteries in series.
I have the following in mind...
2x Turnigy 2S 2200mah w/EC3 Connectors
I will be creating a Series harness with EC3 Connectors and 14AUG wire.
My question is I know the EC3's are good for 60 amps but will the 14 AUG wire be enough or will I need something like 12 or even 10?
Cheers.
Will
cloaked is offline Find More Posts by cloaked
Old May 06, 2011, 08:35 PM
Hughes500Bob is offline
Find More Posts by Hughes500Bob
Retired CFI Helicopter
Hughes500Bob's Avatar
Southeast PA
Joined Jun 2007
Use the same gauge wire already on your packs. IMO 10 gauge is overkill.
Personally I use Deans Wet Noodle 12 gauge for just about everything!
Bob
http://rcsales.shutterfly.com
Hughes500Bob is offline Find More Posts by Hughes500Bob
Old May 06, 2011, 08:55 PM
cloaked is offline
cloaked's Avatar
Joined Dec 2010
Bob
Cool thanks, the Turnigy Lipos come with 12AUG and I have left over 14AUG, ill try and source some more 12AUG.
Cheers.
Old May 07, 2011, 12:20 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
If you have 14 gauge, use it. The power loss difference between 14 and 12 gauge wire will be negligible and absolutely unnoticed. Losses elsewhere in your power system (batteries, motor) will be magnitudes greater.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old May 07, 2011, 02:48 AM
cloaked is offline
cloaked's Avatar
Joined Dec 2010
Mark
Well the System should be drawing around 40 amps based on others setups.
Screw it Ill give it a go, whats the worse that can happen right?
Old May 07, 2011, 03:16 AM
So. Cal.
40 amps is a walk in the park for 14GA wire.
Power loss difference between 12GA and 14GA in 1 foot of wire is about 1.5 watts at 40 amps. On a 4S system at 600 watts, a 1.5 watt delta would be absolutely transparent.
Mark
Old May 07, 2011, 03:21 AM
cloaked is offline
cloaked's Avatar
Joined Dec 2010
Mark
Love hearing from people with more knowledge then me!
Thanks for the info, Ill let you guys know who much power I get out of the setup.
Now all I have to do is wait for my parcel from HobbyKing
Discussion ESP114 in series with ESP114A is okay, right? merzie Batteries and Chargers 1 Apr 25, 2011 07:36 PM
For Sale 2x Flightmax 1300mah 2S 7.4V 20C - $8 shipped ea. ptt81 Aircraft - Electric - Batteries & Chargers (FS/W) 0 Mar 26, 2011 10:52 PM
Wanted 2s adapter for 2 1C in series elvill Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 1 Mar 25, 2011 10:17 AM
Discussion 2x 12v chargers in series with a 24v Power Supply? cmacclel Batteries and Chargers 3 Jan 21, 2008 02:39 PM
Discussion How To Wire Twin Brushless Motors and ESCS In Series With 2 Lithium Packs LNLP Power Systems 3 Feb 18, 2006 10:01 AM
