Old Sep 19, 2010, 04:53 PM
Ben_E is offline
Find More Posts by Ben_E
Go FASST or go home...
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Mc Donnel Douglas MD83 - Scratch build from depron
My passion is for airliners, and I have a few already and if you want an rc airliner you have to build it yourself, so here goes! I have had the plans for a while, and while waiting for Windriders Boeing 737 this will be my "waste of time" in the weeks to come!
Plans are from www.scale-parkflyer.de and the specs are as follows:
  • Wingspan: 1300 mm (51")
  • Fuse length: 1670 mm (65")
  • Target RTF weight: 1100 grams (39oz)
  • Wingloading 45 g/dm˛
Video:
http://www.rcmovie.de/video/3d5b9bad...-Airliner-MD83
Lets begin! If you think that cutting a lot of depron parts is a pain in the a this is not a build for you, because there is a lot of pieces to cut, in my opinion maybe too many. But the plans are very well made, and a lot of though has obviously been put into it. There is also a 72 page build manual (unfortunately only in german - I'm getting very fond of google translator)
Fuselage is first, and uses conventional stringers and formers method, nothing difficult, just time consuming...
I realised that this is not a small parkflyer, the fuse is long!
I let the pictures speak for itself
Next step is to glue the formers, and add the side stringers, the the fuse is going to be covered with 3mm depron.
So that's the start, more to come!
Ben_E
Ben_E is offline Find More Posts by Ben_E
Old Sep 20, 2010, 12:46 AM
Rudi is online now
Find More Posts by Rudi
Rudi's Avatar
Österreich, Oberösterreich, Laakirchen
Joined Jan 2001
Hi Ben_E,
I have the B-24 plan from the same guy. Hope to build it soon. I like the technic he use but I will mod. some details. I will watch you build very close.
Greetings from upper austria
Rudi
Rudi is online now Find More Posts by Rudi
Old Sep 20, 2010, 07:17 PM
Flexserve is offline
Find More Posts by Flexserve
Avoid The Ground!
Flexserve's Avatar
United States, FL, Tampa
Joined Sep 2008
Looks great! It's wonderful to see all these models start appearing! Just awsome!
I really like the 83 because of it's high tail and bus like appearance in the sky demands attention from the ground.
Need DC-10 Kit and 727 to make a nice rounded airline.
There are already lots of 747, A380 kits.
fabio used these exact engines on his 727 and one quit on him, be careful there are reports that these EDF units are not quite up to par.
Flexserve is offline Find More Posts by Flexserve
Old Sep 21, 2010, 04:41 PM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
The build continues! Now the fuse is getting closer to look like a fuse. The stringers are now in place, and I have now run out of pieces...
More cutting to do!
Ben_E
Old Sep 21, 2010, 06:06 PM
SkylineFlyer is offline
Find More Posts by SkylineFlyer
Hawk Fanatic
SkylineFlyer's Avatar
United States, KY, Louisville
Joined Jul 2008
Subbed. Thanks and don't give up mid stride.
SkylineFlyer is offline Find More Posts by SkylineFlyer
Old Sep 21, 2010, 06:16 PM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Thanks!
Only if the Windrinder 737-700 turns up on my doorstep in the middle of the build. Really hope so but it won't happen
Ben_e
Old Sep 22, 2010, 12:38 AM
carrerars is offline
Find More Posts by carrerars
carrerars's Avatar
Joined Aug 2008
Ben_e that looks very cool !
Do you think there is a chance to put two 64mm fans -from my crashed exec. jet - into this one?
Markus
carrerars is offline Find More Posts by carrerars
Old Sep 22, 2010, 01:23 AM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Markus
Sorry Markus, I don´t think so. I´m afraid they are too heavy...
Ben_E
Old Sep 22, 2010, 08:54 AM
kimhey is offline
Find More Posts by kimhey
kimhey's Avatar
nřtterřy, NORWAY
Joined Mar 2006
Great!
You inspired me so much that I ordered the plans too
450 grams of thrust from the fans you are planning to use, is probably on 4 cells....
Will find out for myself, as I ordered them too XD
Thinking of retracts as well.
Kim
kimhey is offline Find More Posts by kimhey
Old Sep 22, 2010, 09:20 AM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Kim
I´m going to use the weekend to figure out how I can get these installed into the plane
Ben_E
BTW - here is a norwegian build blog here!
Old Sep 24, 2010, 03:41 PM
Scale-Parkflyer is offline
Find More Posts by Scale-Parkflyer
Joined Dec 2006
Hi Ben
see my new Video from a south Germany Flight show:
http://www.rcmovie.de/video/f433e622...2010-E-Meeting
greetings,
Frank
Scale-Parkflyer is offline Find More Posts by Scale-Parkflyer
Old Sep 27, 2010, 04:26 PM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
First the stringers on the side was glued to the formers. To secure that the fuse ends up straight, I taped a wooden stick to them before I glued it to the formers.
I have been thinking of how to form the depron to the fuse I used a hairdryer and a glass mug with approx the same diameter. Slightly and gently heating the depron - and it stays in shape long enough to be glued to the fuse.
Here are some pictures of the progress!
Ben_E
Old Oct 02, 2010, 10:06 PM
SilentHunter is offline
Find More Posts by SilentHunter
SilentHunter's Avatar
United States, Death Valley
Joined Aug 2003
Neat little maddog, updates?
SilentHunter is offline Find More Posts by SilentHunter
Old Oct 03, 2010, 05:46 AM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Have been working on the retracts. I have to prepeare the nose wheel, and the retracts mounting at this stage. The retracts are micro retracts from HK, and it's a jewel
The weight of the nose gear retracts including mounting plate is a mere 22grams.
Ben_E
Old Oct 03, 2010, 03:31 PM
Ben_E is offline
Ben_E's Avatar
Bergen, Norway
Joined Nov 2002
Some more progress!
In order to get a good and firm nose gear mount I have doubled opp the spars with 6 mm depron. In addition I have used some carbon to stiffen it up and to distribute the load when landing. The weight penalty was not that bad either, I'm now at 154 grams (5,4oz) That includes also the 3mm depron sheeting on the top of the fuselage.
Ben_E
Build Log 100" Douglas DC-6A Scratch build AlexanderB Giant Electric Planes 1665 Feb 02, 2016 07:43 AM
Discussion Scratch-build depron Beaufighter leccyflyer Electric Warbirds 6 Apr 19, 2010 07:07 PM
Discussion Scratch built Depron Ki-61 Hien "Tony" plans and build log Low Pass Foamies (Scratchbuilt) 68 Mar 28, 2010 01:56 AM
