Old Jul 07, 2008, 10:07 AM
sparks is offline
Find More Posts by sparks
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Parkzone T-28 Trojan modification thread
I looked for a thread that covers just modifications to this great flying model and couldn't find it.
Just a whole bunch of "I have to get one" and "it flys like a dream"
SO. lets keep this one on modifications.
Originally I bought the plane to do stupid things with due to it's forgiving nature.
I really don't want to risk my scratch built models "having fun" and this one should satisfy my watch this moments.
The first stupid thing I did was leave the model in the car when I went in the hobby shop. I was only there for 20 minuets but came out to see this.
Brand new plane with only three flights . . .melted.
So don't fault me for cutting on a new model after all I didn't start this.
sparks is offline Find More Posts by sparks
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
mod #1
With the canopy off the first thing to do is get rid of that huge Charlie Brown looking guy.
I'm not to happy about having to do the tooling for a replacement canopy but it was faster than trying to locate, order, and receive one.
The next thing was to put a more proper sized guy there and why not make it two?
Micro balloon / epoxy finishing resin filled the spaces in-between the melted bumps.
Old Jul 07, 2008, 10:08 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Mod #2
This is a Navy plane and the approaches look too airforce to me so I added fowler flaps.
It was simple to cut the foam free; the trick is to cut it at an angle using a blade guide. This one is balsa sanded to 14 degrees. The purpose is to form the separate airfoil a fowler flap has.
With the flaps taped in position I used a dremel tool to dig out slots for the hinges.
A piece of aluminum tubing aligns them while the epoxy sets up.
A sharpened piece of piano wire was used to run the push pull wire to the bell crank bays. I'm not going to lie, it was a pain to get them in position.
On the good side the main gear plates were not exactly bonded in place very well.
Old Jul 07, 2008, 10:09 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Mod #3
What good is steep slow approaches with out a retractable tail hook?
This was as easy as taking a bite out of the tail with a razor and sanding the foam to shape.
When you cut into the fuselage a hole is formed leading all the way to the servo mounts.
All I did was laminate a 1/16 wire between a pair of light ply hooks. I cut another pair to match the fuselage and drilled them for a pivot pin.
From there it was a matter of running a push pull wire to a separate servo. I didn't support the wire because I wanted it to have some spring to it and it helps save the servo.
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
Mod #4
The stock motor looks fine but I thought mine looked better so I formed one and installed it with silicone. not much to say here except that it fit well.
I stretched a line across the parking lot with a small sand bag at the ends. Small foam beads hold the line 1/4 inch above the ground so I can catch it. This system worked well years ago with my SIG Kouger so I had to try it with a park flyer.
I have video of my attempted "deck landings" and I'm trying to edit out the totally lame ones.
Then I'll have to learn how to post it.
Not to worry I'll post the funny ones too.
Old Jul 07, 2008, 10:34 AM
raz is offline
raz
Find More Posts by raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
Those are some sweet mods alright. Ever think about making some more pilots to sell (unpainted)? I'd buy one if you do.
raz is offline Find More Posts by raz
Old Jul 07, 2008, 11:03 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
The pilot part number is 1005-14 available from DARE designs.
http://www.darehobby.com/accessories/pilots.htm
That's if that's all you want, but the better deal is through me.
The problem is I don't want to do custom orders.
I didn't plan to make a "up-grade" set for this model but sets are easier.
So. . . . .
Canopy made from .030 PETG , Two pilot figures and a cowl with the dummy motor molded in and made with thicker material .040
One box ready to go for $18 shipped in the US.
USPS priority.
Check or money order will be fine
If you want to use Pay pal the account is parkflyerplastics@att.net
Please be sure to make a note of the parts you want.
Contact me at sparky2@att.net if you are out of the US for shipping details.
Old Jul 07, 2008, 01:02 PM
ian_ryeng is offline
Find More Posts by ian_ryeng
uh oh...
ian_ryeng's Avatar
Newmarket Ont. CA
Joined May 2008
Those are some great looking flaps.
Good job!
ian_ryeng is offline Find More Posts by ian_ryeng
Old Jul 07, 2008, 01:06 PM
raz is offline
raz
raz
Sportin my new 'do'
raz's Avatar
USA, CA, Eureka
Joined Dec 2004
That's a great deal for 2 pilots, canopy and a motor for $18.00 shipped. I will be contacting you next payday.
Old Jul 07, 2008, 02:04 PM
RC.F22.Raptor is offline
Find More Posts by RC.F22.Raptor
RC.F22.Raptor's Avatar
Joined Mar 2008
Other than the pilots, did you make any changes to the inside of the cockpit?
RC.F22.Raptor is offline Find More Posts by RC.F22.Raptor
Old Jul 08, 2008, 10:46 AM
ktrails is offline
Find More Posts by ktrails
United States, TN, Signal Mountain
Joined Sep 2007
Wow! I'm impressed. You make is sound so easy! Makes me want to spend time in your workshop learning the tricks of the trade!
ktrails is offline Find More Posts by ktrails
Old Jul 18, 2008, 11:54 AM
sparks is offline
RC 4 Life
sparks's Avatar
Fort Worth, TX USA
Joined Feb 2001
sorry it took so long.
The only change to the cockpit was cutting the small hump behind the pilots seat away to make room (and a panel) for the guy in the back.
Old Jul 18, 2008, 02:58 PM
Prof100 is offline
Find More Posts by Prof100
Prof100's Avatar
Canton, Michigan USA
Joined Jul 2007
You put a new dimension to modifying the Trojan with your craftsmanship. It is simply terrific. Take a bow.
Prof100 is offline Find More Posts by Prof100
Old Jul 18, 2008, 06:55 PM
coololdude is offline
Find More Posts by coololdude
socal
new motor
I've installed a new 3536c turnigy and man this plane rips I haven't found a fave prop yet.....it's between 11x7 or 10x7....if flys well with both one climbs and the other is fast.....and its fun with the flaps
coololdude is offline Find More Posts by coololdude
Old Jul 18, 2008, 09:42 PM
finchkid24 is offline
Find More Posts by finchkid24
100% addicted to RC :)
finchkid24's Avatar
USA, CA, La Verne
Joined Feb 2008
nevermind.
finchkid24 is offline Find More Posts by finchkid24
Discussion Parkzone T-28 Trojan Thread Part 2 darenm Parkflyers 32777 Apr 30, 2015 09:49 PM
Article ParkZone T-28 Trojan RTF Review Jim Walker Electric Warbirds 883 Apr 24, 2015 12:30 PM
Discussion Parkzone T-28 Trojan Thread Edge767 Parkflyers 6527 Jun 04, 2008 05:29 AM
Wanted Parkzone T-28 Trojan webejpn01 Aircraft - Electric - Airplanes (FS/W) 4 Oct 25, 2007 02:48 PM
Discussion New Parkzone T-28 Trojan pnp Spurwood Electric Warbirds 4 Oct 23, 2007 04:05 PM
